POV-Ray : Newsgroups : povray.binaries.images : Re: fix single image on surface Server Time
25 Aug 2025 23:54:32 EDT (-0400)
  Re: fix single image on surface (Message 1 to 7 of 7)
Subject: Re: fix single image on surface
Date: 13 Aug 2000 12:45:16
Message: <3996D0BA.8D6C3D2F@schunter.etc.tu-bs.de>
Jens Strohmeyer wrote:
> hello !
> i need to know how to fix a SINGLE image
> to a surface, e.g. how to fix a bitmap on a special
> position on a cylinder. can anyone help ?
> thanks in advance !
> jens
Don't know, what you exactly mean, but you can add "once" to an image_map to
avoid tiling.  Example:
  image_map {
    png "test.png"
    once
Furthermore you can translate and scale it like every other texture.
BTW, povray.general or povray.newuser would be more appropriate for such
questions.
Date: 13 Aug 2000 13:41:39
Message: <3996ddd3@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:3996D0BA.8D6C3D2F@schunter.etc.tu-bs.de...
to
|   image_map {
|     png "test.png"
|     once
    map_type 2 // for putting on cylindrical objects and such
    filter 255, 1 // palette entry 255 will be clear (use 256 color image
only though)
The thing to keep in mind is to use a image which is ready to apply.  What I
mean by that is, if you want it only partially on the object like a bottle
label instead of a can label you will need to set the applicable part of the
image into another larger image and then set that images background color to
be clear.  That will then wrap fully around the cylinder and leave the
intended portion only on one area, otherwise it will get put 360 degrees
around (and 1 unit tall from 0 to 1 y without further scaling/translating).
If you can't use a paletted image then the next best thing would be planar,
or map_type 0 (default), instead and place it by scaling and translating.
It just won't wrap onto the object very well if so.
| questions.
Yep, certainly post a binary (image) when posting new to this group please
Date: 14 Aug 2000 04:06:35
Message: <3997a88b@news.povray.org>
I'll post code on the use of these first two images, resulting in the third,
on povray.text.scene-files. This was accomplished on a mesh, but cylinders
or what-have-you work the same way.
Look for "Fuse" on p.t.s.f.
Grim
Download 'FuseInsig.png' (5 KB) Download 'ss1.png' (5 KB) Download 'Fuse.jpg' (12 KB)
Preview of image 'FuseInsig.png'
Preview of image 'ss1.png'
Preview of image 'Fuse.jpg'
Date: 14 Aug 2000 05:00:25
Message: <3997B529.4186A23A@enst.fr>
> to
> |   image_map {
> |     png "test.png"
> |     once
> only though)
	Or a combination of frequency and radial (frequency to "scale" the
image to the right scale and radial to only show the wanted part).
Date: 14 Aug 2000 12:38:55
Message: <3998209f$1@news.povray.org>
AFAIK frequency doesn't work with images.  With MegaPov however you could
scale the image and then apply a spherical or cylindrical warp.
ZK
http://www.povplace.be.tf
Date: 14 Aug 2000 13:40:05
Message: <chrishuff-76F461.12410914082000@news.povray.org>
In article <3998209f$1@news.povray.org>, "Zeger Knaepen"
I think he was talking about using frequency in a radial pigment_map.
Date: 14 Aug 2000 18:08:01
Message: <39986dc1@news.povray.org>
could
Hey, do you mind?
Every day I have to say at least one silly thing, or I get
superintelligent...
Something my environment couldn't handle, I think...
Hmmmm....
Had a long day today... :-)
ZK
