POV-Ray : Newsgroups : povray.binaries.images : Alpha Channel Help Server Time
14 Jun 2026 19:46:06 EDT (-0400)
  Alpha Channel Help (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Alpha Channel Help
Date: 3 Aug 2000 16:17:32
Message: <3989d35c@news.povray.org>
Alan <man### [at] freeukcom> wrote in message news:39899c3d@news.povray.org...
> GrimDude <vos### [at] yahoocom> wrote in message
> news:39893874@news.povray.org...
> > I use palletted png's, limited to 256 colors. Masking is achieved by
> > defining transmit for each pallette value intended to be transparent. In
> the
> > example Alan posted, you could get away with 16 color png's.
> Don't know how much this applies, but the png used in the scene I posted
was
> 24-bit, as are all mapping png's I use.
> Alan.
Thanks, but no go...  The problem you spotted is fixed by my max_trace_level
of 40, but the problem I'm having seems to be a different one...
-Chris-
Date: 3 Aug 2000 17:23:19
Message: <chrishuff-813F14.16241303082000@news.povray.org>
In article <3989d35c@news.povray.org>, "Chris S."
> max_trace_level of 40, but the problem I'm having seems to be a
> different one...
Like I said before, it looks like a "hollow" issue. Make your fish
objects "hollow" and see if the problem is still there.
Date: 3 Aug 2000 18:45:58
Message: <3989f626$1@news.povray.org>
Chris Huff <chr### [at] maccom> wrote in message
news:chrishuff-813F14.16241303082000@news.povray.org...
> > different one...
Thanks, but no change.  I tried using the hollow boxes...no luck.  Triangles
and polygons still show the same problem...
-Chris-
Date: 3 Aug 2000 19:27:30
Message: <chrishuff-6B1410.18282603082000@news.povray.org>
In article <3989f626$1@news.povray.org>, "Chris S."
> Triangles and polygons still show the same problem...
Maybe a finite-vs-infinite fog problem? Try putting something behind the
fish, so the background isn't an infinite distance away.
Date: 3 Aug 2000 20:04:16
Message: <398a0880@news.povray.org>
news:chrishuff-6B1410.18282603082000@news.povray.org...
Already tried, no good.  It actually seems to be showing up properly against
the fog, but incorrectly with foreground images.
-Chris-
Download 'scene_06aaa.jpg' (16 KB)
Preview of image 'scene_06aaa.jpg'
Date: 4 Aug 2000 04:00:33
Message: <398a7821@news.povray.org>
Could you post the source you used?
Grim
Date: 4 Aug 2000 11:12:36
Message: <398add64@news.povray.org>
news:398a7821@news.povray.org...
> Grim
Sure, it's in p.b.s-f
-Chris-
Date: 6 Aug 2000 04:41:55
Message: <398d24d3@news.povray.org>
I'm not an expert at paint packages, but it looks to me as if your included
image has transparency set for every color within the image. Is this what
you meant to do? I think you would achieve the effect you are after, if you
would set the background of your image as transparent, only.
Keep on tracing!
Grim
Date: 6 Aug 2000 16:24:51
Message: <398dc993@news.povray.org>
news:398d24d3@news.povray.org...
included
you
Well, yeah, that would be the ideal solution...but PS removes any
transparent backgrounds when the file is not saved as a .psd.  As to all my
colors being transparent...if you rendered the file in p.b.s-f the fish part
is showing where the background is "general" not.  The problem I seem to be
having is the background, which I want 100% transparent, is at points
showing up less then 100% creating slightly light boxes appear around the
fish.
I guess I'll live but this problem sure is annoying...
-Chris-
Date: 11 Aug 2000 21:38:25
Message: <347.258T1120T9324165PeterC@nym.alias.net>
Chris:
        Have you tried using a 32-bit targa (TGA) file?  I
was working with alpha channels back and forth between
PovRay and PhotoShop and found that PNGs didn't work but
32-bit TGAs did.
        To make and save a TGA with an alpha channel in
PhotoShop is a PITA but it *is* possible and povray reads
the resulting file correctly.
Pete
