POV-Ray : Newsgroups : povray.binaries.images : Two glowing crystaloids (39kb) Server Time
10 Jul 2026 10:26:32 EDT (-0400)
  Two glowing crystaloids (39kb) (Message 1 to 10 of 15)
Subject: Two glowing crystaloids (39kb)
Date: 2 Aug 2000 10:51:00
Message: <39883558.155C880B@mail.wh2.tu-dresden.de>
Hello,
this one was inspired by David Fontaine's faceted twisted torus and
especially by David Heys' reply.
Any comments?
Download 'badcrystal.jpg' (38 KB)
Preview of image 'badcrystal.jpg'
Subject: Re: Two glowing crystaloids (39kb)
Date: 2 Aug 2000 11:17:22
Message: <39883B84.BDC59FCF@interlog.com>
Michael Zier wrote:
> Hello,
> Any comments?
Any possibility of animating this?  Perhaps with the two extreme top and
bottom points moving down along the central axis and actually turning
the thing inside out with the camera moving in towards the centre?  That
would cause ( imagination here ) the glowing gas to be ejected outside
and the viewer would be left inside looking out at swirling gas.
Just a thought.
Date: 2 Aug 2000 11:54:53
Message: <3988444d@news.povray.org>
Simply gorgeous. :{)
David
Date: 2 Aug 2000 13:47:02
Message: <39885E9B.49E5E5C9@mail.wh2.tu-dresden.de>
Well, I just don't have any idea, how to animate the media in an
realistic way. Just to cycle through the phase property would look ugly.
BTW, there could be a kind of non-linear transform in future versions of
POV, e.g.
transform {
 non_linear {
  x=f_x(x,y,z)
  y=f_y(x,y,z)
  z=f_z(x,y,z)
this could be very useful in modifying patterns used in media densities.
Just a thought, too.
Anyway, if anyone has any idea of animate media realistically, let me
know.
> Just a thought.
You must have a very great imagination...
Date: 2 Aug 2000 15:03:11
Message: <chrishuff-8A0260.14040402082000@news.povray.org>
In article <39885E9B.49E5E5C9@mail.wh2.tu-dresden.de>, Michael Zier
You could translate the pattern a bit, apply turbulence, and then
translate it back. Control the distance you translate it using the clock
variable, and you could get a kind of animated turbulence.
You could also combine several patterns(using isosurface functions),
each with different rates of rotation/translation.
> POV, e.g.
> transform {
>  non_linear {
>   x=f_x(x,y,z)
>   y=f_y(x,y,z)
>   z=f_z(x,y,z)
There is already a way to apply non-linear transforms to patterns:
warps. And I have been working on a way to do exactly what you describe,
using the displace warp and a new pigment which takes an isosurface
function for each color component.(I actually have it coded, but haven't
tested it yet.)
> know.
You could do it with a bunch of particles. :-)
Date: 2 Aug 2000 15:56:06
Message: <39887CDC.B5F608EE@mail.wh2.tu-dresden.de>
> tested it yet.)
Thanks, I'll give it a try.
Date: 2 Aug 2000 17:21:03
Message: <398890bf@news.povray.org>
"David Heys" <sou### [at] gcinet> wrote in message
news:3988444d@news.povray.org...
ditto that.
Date: 2 Aug 2000 19:10:18
Message: <3988AB4A.A237D059@home.com>
Wow I really like this!! Only comment I can make is that the spheres at the
joins look a little too big to me. This is only a concern if you are striving
for realism. Either way it is a great image:-)
Michael Zier wrote:
> Hello,
> Any comments?
Date: 2 Aug 2000 23:38:18
Message: <3988E74A.4299CFD2@faricy.net>
Michael Zier wrote:
> transform {
>  non_linear {
>   x=f_x(x,y,z)
>   y=f_y(x,y,z)
>   z=f_z(x,y,z)
That is already possible with MegaPOV for pigment and isosurface functions.
Date: 2 Aug 2000 23:40:22
Message: <3988E7C3.9B81A6FD@faricy.net>
Cool, now make a cluster, where no glass panels intersect, instead they are
cut off where crystal overlap and new vertices are added. :-)
