POV-Ray : Newsgroups : povray.binaries.images : Not a submarine Server Time
18 May 2026 11:18:07 EDT (-0400)
  Not a submarine (Message 21 to 22 of 22)
Subject: Re: Not a submarine
Date: 6 Aug 2000 01:26:25
Message: <398CF830.38BC3033@home.com>
I've Seen one of those...   I know a guy who works on them.....  now if
he could "slip" me some of the blue prints..........
Doug Eichenberg wrote:
>  No, it's not a submarine!Something I'm doing for work... thought I'd
> share it.  The original is much larger in resolution, so some of the
> smaller details (like the threading) don't show here.  It's a cut-away
> model of an injection molding assembly.  It was created in AutoCAD
> from blueprints, then exported as a series of .3DS files.  I imported
> the .3DS files into PolyTrans and converted them into a POV
> smooth_triangle mesh.  The final POV file was a whopping 57.6 meg.How
> it works: The plastic (in pellet form) is fed into the large hole at
> the upper left and the cylinder is heated by the heater bands that are
> wrapped around it.  The temperature ranges from 300-900 degrees
> fahrenheit, depending on the resin used.  The screw spins inside the
> cylinder and forces the melted plastic out the nozzle orifice and into
> a mold.  That's the basic synopsis, anyway.  The vertical cylinders
> are thermocouples.
> Doug Eichenberg
> http://www.nls.net/douge
> dou### [at] nlsnet
Date: 8 Aug 2000 20:03:38
Message: <39909fda$1@news.povray.org>
Can you say "corporate confidentiality?"   :)
Doug Eichenberg
dou### [at] nlsnet
