POV-Ray : Newsgroups : povray.binaries.images : ingo's erosion for heightfields (3x12k) Server Time
29 Jun 2026 07:52:58 EDT (-0400)
  ingo's erosion for heightfields (3x12k) (Message 1 to 7 of 7)
Subject: ingo's erosion for heightfields (3x12k)
Date: 28 Jul 2000 17:35:32
Message: <3981FCB3.6BA32CCD@schunter.etc.tu-bs.de>
I just managed to rewrite ingo's df3 erosion idea for heightfields (I hope i
understood it right, i'm not totally sure) and it works really good!
The following 3 pictures are my first try: the first one is the original, the
second one is after 6 runs and the third after 12 additional runs (each run
taking only 240 ms on a 128x128 HF)
There probably is some more work to do (for example the edges) but IMO, it looks
really promising.
Download 'erode_a1.jpg' (12 KB) Download 'erode_a2.jpg' (12 KB) Download 'erode_a3.jpg' (12 KB)
Preview of image 'erode_a1.jpg'
Preview of image 'erode_a2.jpg'
Preview of image 'erode_a3.jpg'
Subject: Re: ingo's erosion for heightfields (3x12k)
Date: 28 Jul 2000 18:06:53
Message: <8F805F98seed7@204.213.191.228>
>hope i understood it right, i'm not totally sure) and it works really
>good!
Wheee, cool.
One remark, compare image one and three. Look for the highest mountain
peak on the right. Despite the erosion, they seem to have the same
absolute height.
Ingo
Date: 28 Jul 2000 18:28:31
Message: <3982091D.28D64DE6@schunter.etc.tu-bs.de>
ingo wrote:
> Wheee, cool.
> absolute height.
Sure it has, because i rescale to fit range after the calculation :-) (makes it
easier to program because you don't have to think about range checks).
I will probably also try it without rescaling soon...
BTW, i also tried it with higher resolution HFs and it often gets very grainy.
Changing the water/erosion amount helps a bit, but it's still a problem.
Date: 28 Jul 2000 19:12:40
Message: <chrishuff-8E20CD.18132628072000@news.povray.org>
In article <3982091D.28D64DE6@schunter.etc.tu-bs.de>,
Please do...it should look much more realistic.
Try applying a small amount of blur after each erosion...
Date: 29 Jul 2000 00:22:01
Message: <39825be9@news.povray.org>
Not conducive to animation as is, I suppose you meant about the graininess.
I was wondering about the lake heights (or depths) since they should be
filling in as erosion goes on making for a higher surface level.  Appears
what you have showing here is a base, or sea, level although intermediate
elevations are filling in.  So were a disc of water placed in that central
valley then it would need raising along with the HF changes.  I'm just
thinking out loud about how it might go for such things.
Date: 29 Jul 2000 02:59:21
Message: <398280DA.2B7238D0@schunter.etc.tu-bs.de>
I will try it.
Already did that and it helped a lot, even though it's still somwhat bumpy.
Date: 29 Jul 2000 02:59:31
Message: <398280E5.B7093E6D@schunter.etc.tu-bs.de>
> Bob
I think there are some significant differences to ingo's 3d-erosion, behaviour
is also very unpredictable, so i will have to try some
improvements.
