POV-Ray : Newsgroups : povray.binaries.images : Flight over mountains and lakes [~53KB Jpg] Server Time
18 May 2026 09:59:19 EDT (-0400)
  Flight over mountains and lakes [~53KB Jpg] (Message 17 to 26 of 26)
Subject: Re: Flight over mountains and lakes [~53KB Jpg]
Date: 27 Jul 2000 14:14:01
Message: <39807be9@news.povray.org>
Oh, okay, I had it in mind the RMF type was set apart from the rest.  Thanks
for telling me, too lazy to look up in the MegaPov html file myself.
Date: 27 Jul 2000 14:15:59
Message: <39807c5f@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-F3C93D.13042127072000@news.povray.org...
| > The RMF isn't also usable as a pigment, is it?
| Any isosurface function is useable as a pattern, and any pigment can be
| used in an isosurface function.
Thanks to you too for the quick reply.  I somehow had put the RMF into it's
own category outside the rest in my mind.
Date: 27 Jul 2000 14:25:05
Message: <39807E8D.D94468BC@schunter.etc.tu-bs.de>
Bob Hughes wrote:
> You're right on the mark with that comment Greg.  The circumventing of a
> need for smooth height fields to do this sort of thing may make the HF
> obsolete, dare I say.  The one drawback is the need to get a fine enough
> 'accuracy' apparently, among other things I might not know about, which can
> slow things up.  The 'eval' and 'method 2' are superb additions.
> Oh, yeah.  Yes, just the isosurface with ridged multifractal function and a
> water plane, some ground fog, sky_sphere too.  A little detailed info:  24
> by 24 unit square isosurface used with the camera traveling about 3 units at
> a height of 0.41*y average above the water level.
> Bob
Even though your scene shows the strength of isosurface terrain very good i have
to disagree about heightfields becoming obsolete.
IMO, their strength is where you apply many functions to the surface that would
take very long to render as an isosurface and most erosion functions would be
nearly impossible with isosurfaces, because they often use iterative algorithms.
Date: 27 Jul 2000 14:47:09
Message: <3980827D.85A674C0@my-dejanews.com>
The point is that every time I started to mess with HF's, I wallowed in indecision
about the resolution. If I made it too coarse, I could never do an animation later
of a flyby close up or balls bouncing off of it or a man hiking up it. If I made it
finer, it still wasn't going to be fine enough for whatever use I haven't thought up
yet.
Isosurfaces have the same appeal over HF's that vector art has over 2d  bitmap
painting, and really, 3D over vector and bitmap painting.  When I do my rolling
algorithm, I set up my isosurface in an INC. When I need to accurately compute
normals for the traces which determine particle trajectories, I set my
accuracy=0.00001, when I trace, it's 0.01 or 0.001.
Vector programs didn't render bitmap painting obsolete, per se..............
> > Bob
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 27 Jul 2000 14:56:18
Message: <398085DE.B855F6DC@schunter.etc.tu-bs.de>
> yet.
I usually do the HF in several resolutions and use low for the test renders and
high for the final versions.  It's also possibe to combine two Heightfields, one
for the large scale and one for details in the foreground.
Agreed, but I like bitmap painting :-)
Christoph, who also likes vectorizing photographs...
Date: 27 Jul 2000 17:15:06
Message: <3980a65a@news.povray.org>
Very very nice!
One comment - isn't the long vision a bit unrealistic? I'm not sure, but I
think it would be far more realistic if a lot of fog were added.
Greetings,
Rune
Updated July 23: http://rsj.mobilixnet.dk
3D images, include files, stereograms, tutorials,
The POV Desktop Theme, The POV-Ray Logo Contest,
music, 350+ raytracing jokes, and much more!
Date: 27 Jul 2000 18:52:04
Message: <3980BB3D.9AAAF0B9@faricy.net>
Very nice render Bob! Is this a glacial area?
I'd say it's too even; the flat areas and the peaks have a pretty constant
elevetion. Otherwise realistic...
Date: 27 Jul 2000 19:31:37
Message: <3980c659$1@news.povray.org>
> Since the animation was so garbled I figure a nice still image should be
> uploaded.
> Bob
Kind of what I picture the dragontail mountains to look like...
I think they're caleld Dragontail mountains, from the game Daggerfall. Mmmm,
Arena 3 is comming out next year.
ross.
Date: 27 Jul 2000 21:31:05
Message: <3980e259@news.povray.org>
"Rune" <run### [at] inamecom> wrote in message
news:3980a65a@news.povray.org...
| Very very nice!
And I had thought there was plenty of ground fog in there  :-(
I was kind of thinking of high base elevation for the lakes to begin with,
that's why the air is very clear.
Date: 27 Jul 2000 21:33:13
Message: <3980e2d9@news.povray.org>
news:3980BB3D.9AAAF0B9@faricy.net...
Thanks, guess I should have used Zpaint  :-)
Don't think this could be glacial until a second isosurface were added, and
I'm not thinking of doing that.
