POV-Ray : Newsgroups : povray.binaries.images : Source code available ! Server Time
15 Jun 2026 00:10:35 EDT (-0400)
  Source code available ! (Message 11 to 14 of 14)
Subject: Re: Source code available !
Date: 24 Jul 2000 20:04:18
Message: <chrishuff-A7F5B4.19045824072000@news.povray.org>
In article <397CCD13.CC1D3546@spiritone.com>, Josh English
<eng### [at] spiritonecom> wrote:
> Duh. I should have thought about that. Except for the small fact that I
> don't think I've run into density maps before... attached is a simple ugly
> planet and some rings that aren't much better.
They might also be useful as isosurface functions...there would be some
interesting possibilities.
Date: 24 Jul 2000 21:33:16
Message: <397CECD8.CA12AC63@pacbell.net>
> Josh
It generally helps to use smaller color values in a density map
than in a color map. If you use too high a number the colors wash
out such as seen in your posted image. Try dividing them by 3
and see how they look.
Date: 24 Jul 2000 23:47:03
Message: <chrishuff-49FBB4.22474424072000@news.povray.org>
In article <397CECD8.CA12AC63@pacbell.net>, lin### [at] povrayorg
Of course, this depends on the thickness of the media, the way the
colors layer on each other, and the color used for the media, which acts
as a multiplier for the density, etc. If the media is low density or if
the distance you see through it is small, you need to use higher color
values.
It can also help if the colors vary more than they do in the pigment,
since the media will tend to blend them together in areas.
Date: 25 Jul 2000 07:08:06
Message: <slrn8npo7k.84f.steve@zero-pps.localdomain>
Looks like you could do some good water using this
method.
 12:58am  up 9 days, 23:24,  2 users,  load average: 1.21, 1.06, 1.02
