POV-Ray : Newsgroups : povray.binaries.images : Icy coast 2 (101 k) Server Time
29 Jun 2026 07:55:10 EDT (-0400)
  Icy coast 2 (101 k) (Message 1 to 10 of 29)
Subject: Icy coast 2 (101 k)
Date: 24 Jul 2000 15:55:32
Message: <397C9F3C.D3A126AE@schunter.etc.tu-bs.de>
second version,
I increased resolution of the ice heightfield, and changed textures for water
and ice, looks much *colder*, doesn't it ?
The ice is with transparency, no media, the water is RMF now, with transparency
too and angle dependant reflection.
I did not yet work on the sky, it looks more like overcast weather now, so i
should add some clouds...
I also tried radiosity, but it did not change anything :-( is there any tutorial
on outside radiosity?
Comments still welcome,
Download 'arctic_02.jpg' (101 KB)
Preview of image 'arctic_02.jpg'
Subject: Re: Icy coast 2 (101 k)
Date: 24 Jul 2000 16:44:13
Message: <397caa9d$1@news.povray.org>
This is really coming along.  I would think twice before changing
anything (and make sure you keep a snapshot of your source as
of right now because I think you will want to come back to it :-)
In particular I would not change the sky.  I live in Canada and I
can tell you that cold days are normally cloud-free.  In fact if you
add some clouds I bet your scene will feel "warmer".
Perfect just the way it is!
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:397C9F3C.D3A126AE@schunter.etc.tu-bs.de...
> second version,
water
transparency
i
tutorial
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 24 Jul 2000 17:14:07
Message: <chrishuff-B55B4B.16144724072000@news.povray.org>
In article <397C9F3C.D3A126AE@schunter.etc.tu-bs.de>,
> for water and ice, looks much *colder*, doesn't it ?
> transparency too and angle dependant reflection.
It looks great now! Like a photo...and I only see one "spike" of ice,
and that one looks like it is connected to a floe, which would explain
why it doesn't tip over.
> now, so i should add some clouds...
I agree, some clouds would help. Or just change to color of the sky to a
medium blue-gray, like an even cover of clouds.
> any tutorial on outside radiosity?
Did you remember to turn it on? Simply specifying the radiosity options
in global_settings isn't enough.
Date: 24 Jul 2000 17:15:42
Message: <397CB207.4102E2E8@schunter.etc.tu-bs.de>
Already to late :-) But honestly, if I would document every change, I would
never come along.
Thanks, I never thought about a sky totally covered by clouds, but NTL, i think
it needs at least a bit of structure and some dust on the lower part.
Date: 24 Jul 2000 17:27:10
Message: <397CB4B8.BB40BE41@schunter.etc.tu-bs.de>
Did I miss one :-) In fact they disappeared accidently, I don't really know what
change was responsible.
You are right, forgot +QR, even though, program output is a bit irritationg: the
megapov/official incompatibility warning for radiosity also appears, when it's
switched off...
Date: 24 Jul 2000 18:25:12
Message: <397CC24D.21B154CE@kivisalo.net>
See the dome image as an example what to expect from radiosity.
news://news.povray.org/3947AB86.1450F605%40kivisalo.net
K.K.
Date: 24 Jul 2000 18:33:39
Message: <5jgpnssi5g47a1omu7m02n8275o23r6ilg@4ax.com>
On Mon, 24 Jul 2000 23:27:20 +0200 Christoph Hormann
>switched off...
  Hi, Christoph. Any time radiosity is specified in the global_settings
block, you will receive the 'experimental feature' warning, whether or
not you've actually turned on the radiosity feature during the render.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 24 Jul 2000 19:48:46
Message: <397cd5de@news.povray.org>
Whoa, this is very good scenery.  I like the snow-atop-ice look of the
bergs.  The water could still use a clear pigment with 'interior
{fade_color}' to do the filtering.
Date: 25 Jul 2000 02:34:53
Message: <secqns4maulouu3b3m5fa9gar8t5kun78j@4ax.com>
On Mon, 24 Jul 2000 23:15:51 +0200, Christoph Hormann
Nay, just make it bluish and getting lighter along te vertical.
Peter Popov ICQ : 15002700
Date: 25 Jul 2000 02:34:54
Message: <iicqnssofqlq7f81u58rdijs9ke8bvd2g7@4ax.com>
On Mon, 24 Jul 2000 21:55:40 +0200, Christoph Hormann
Stunningly realistic!
