POV-Ray : Newsgroups : povray.binaries.images : How I made the Maze Ball Image. Server Time
28 Apr 2026 02:08:00 EDT (-0400)
  How I made the Maze Ball Image. (Message 1 to 10 of 15)
Subject: How I made the Maze Ball Image.
Date: 19 Jul 2000 00:35:31
Message: <397530D0.859D1020@home.com>
Since a number of you have asked how I made that image here is a very
rough description.
What I did was I downloaded a Maze making program off the internet,
these just make 2D mazes. Then I saved the images and went into
Photoshop to play with the image, adding Gausian Blurring until I got a
good heightfield image. Then I saved it as a TGA file and went into
HF-Lab, there I previewed the image and saved it. Then I used Orb-Cyl to
take the TGA heighfield to map it around a sphere. I used RAW output.
Then I opened the RAW file in Rhino 3D and exported Moray/Povray UDO/INC
files.
Subject: Re: How I made the Maze Ball Image.
Date: 19 Jul 2000 04:00:31
Message: <39755F47.A6FAC6A@inapg.inra.fr>
> files.
Another way to do this is isosurfaces (with Megapov) :
#declare r0=0.2;
#declare hfs=function{pigment{image_map{png "mazepic" map_type 1 interpolate
2} }}
#declare Maze=isosurface{function{x*x+y*y+z*z + r0*(1 - hfs(x,y,z))}
threshold 1 eval max_gradient 60 contained_by{sphere{0,1}} texture{txtMaze}}
(the max_gradient may have to be changed)
(http://www.mediaport.net/Artichaud/Tran/english/gtp1214e.htm)
Also, there's a great maze pigment function by SamuelT (look for "Re:Tuesday
evening enigma", Feb 10, 2000) that can be used to generate the map.
Possibly, it could be done in one pass (without the blurring of the maze
texture), but I haven't tried it.
G.
Date: 19 Jul 2000 15:28:32
Message: <39760222.CAF83601@home.com>
Thanks for letting me know! Unfortunately Isosurfaces are beyond me:-( I really
need to learn more Math, though I am in grade 12.
> > files.
> #declare r0=0.2;
> 2} }}
> G.
Date: 19 Jul 2000 15:29:11
Message: <39760249.ABC24954@home.com>
Man you images are incredible!!!
> > files.
> #declare r0=0.2;
> 2} }}
> G.
Date: 19 Jul 2000 18:35:00
Message: <slrn8nca62.g96.steve@zero-pps.localdomain>
Don't feel bad about that, I need to lear more maths, and I left school 16
years ago and have done 8 years of further education (full time) after that.
I understand maths in my own way but then someone like Chris Huff comes along
and just blows my mind with the stuff he understands at such an age.
 10:41pm  up 4 days, 21:07,  2 users,  load average: 1.64, 1.40, 1.22
Date: 19 Jul 2000 22:09:11
Message: <39765E99.46FEAFAC@hotmail.com>
> #declare r0=0.2;
> 2} }}
Really you should use image_pattern (esp with palletized images) because
image_map works differently to height-fields.
I found this out when I was trying to recreate a height-field scene with
isosurfaces (to make it smoother).  The lower parts (river) seemed to dip way
too much, which was because the values of red/green colours (used by image_map)
were lower than the palette index (used by image_pattern) and when I changed
over to image_pattern the correct shape occurred for both palette & rgb images.
Bye
Pabs
Date: 20 Jul 2000 10:45:28
Message: <chrishuff-54FB01.09460220072000@news.povray.org>
In article <slr### [at] zero-ppslocaldomain>,
> school 16 years ago and have done 8 years of further education (full
> time) after that. I understand maths in my own way but then someone
> like Chris Huff comes along and just blows my mind with the stuff he
I'm almost 18(within a week, actually)...and my math isn't *that* good.
I still tend to blunder through things by trial and error, I only know
what trigonometry I have learned by using POV-Ray, and I barely know
what calculus *is*. :-(
Date: 20 Jul 2000 10:46:03
Message: <chrishuff-66C2A8.09463720072000@news.povray.org>
In article <39760222.CAF83601@home.com>, Thomas Lake <tla### [at] homecom>
> I really need to learn more Math, though I am in grade 12.
Isosurfaces really don't require any advanced math...just simple algebra
and the ability to predict the points where an equation will be equal to
a certain value. A little knowledge of trigonometry could help, but
isn't really necessary.
Date: 20 Jul 2000 11:19:06
Message: <394F8BBC.3D0C3D1B@exmail.de>
> Come visit my web site:-) : http://www.geocities.com/~thomaslake/
may be a stupid question, but what is Orb-Cyl??
Robert
Date: 20 Jul 2000 11:29:10
Message: <3977195A.F691F4D0@pacbell.net>
> Robert
It is a utility that will allow you to wrap a HF around a cylinder
ora sphere. It doesn't work like POV-Ray's HF object rather it
creates a mesh object to achieve the effect.
http://shell3.ba.best.com/~beale/gforge/
