POV-Ray : Newsgroups : povray.binaries.images : Proximity and media Server Time
29 Dec 2025 12:54:00 EST (-0500)
  Proximity and media (Message 1 to 3 of 3)
Subject: Proximity and media
Date: 16 Jul 2000 10:27:53
Message: <3971C51C.F4C48A5D@skynet.be>
This is an attempt to use MegaPOV's proximity pattern in conjuction
with media.  It leads to very interesting results, tough it's
slooooow (well, text object + sampled pattern + sampled media =
expected slugginess).  I might try with other objects...
Dirty code and image follows.
#version unofficial MegaPov 0.5;
camera {location <50,50,100> direction z*2 look_at <0,0,0>}
#declare Obj1=//box {<0,0,-5>,<15,15,5> pigment {Red}}
                text {ttf "trebuc.ttf","Neon",.1,0 pigment {OrangeRed*2}
scale 17 rotate y*-180 translate x*10}
object {Obj1}
#declare Sp1=
sphere {0,50 hollow
  pigment {White transmit 1}
  interior {
    media {
           method 2
           intervals 8
           samples 2,8
           //confidence
           //variance
           //ratio
           //absorption rgb <,,>
           emission rgb 0.02
           //scattering { Type, COLOR [ eccentricity Value ] [
extinction Value ] }
           density {
                        proximity {
                        Obj1, 10
                        type 1 method 0
                        sides 1
                        sample_weighting <0, 0, 0>
                        samples 10
                        max_density 1
                        sample_bailout 30
                        type 1 //0 : dist moyenne, 1 plus petite
distance,
                               //2 somme des longeurs de tous les
vecteurs du point aux samples,
                               //3 : type 0 avec un falloff
                        method 0 //0 : random dans bbox, 1 : random, 2
randbb si hors de la bb, sinon rand.
                        sides 1  //0 faces internes, 1 faces externes, 2
les deux.
                        }//fin prox
                  color_map {[0 White+Orange][1 Black]}
                  //scale 40
           }//fin media
           }//fin interior
object {Sp1}
light_source {<400,500,300> White*2}
Download 'proximedia.jpg' (7 KB)
Preview of image 'proximedia.jpg'
Subject: Re: Proximity and media
Date: 17 Jul 2000 04:53:34
Message: <3972c98e$1@news.povray.org>
nice, but neon it aint !
Date: 21 Jul 2000 16:32:06
Message: <chrishuff-1978FC.15324121072000@news.povray.org>
In article <3971C51C.F4C48A5D@skynet.be>, Fabien Mosen
Well, I have been trying to think of a way to reduce the "grainyness"
problem without requiring too many samples...maybe by initially doing 2
groups of samples, measuring the difference between their results, and
optionally making additional samples if they are too different...or
something like that.
What would be nice would be the ability to reuse samples, which would
not only be smoother, but a lot faster...but to do that well would
require a "pre-trace" stage, similar to radiosity, and would consume a
lot of memory. And I have no idea how to do it...
