POV-Ray : Newsgroups : povray.binaries.images : Millennium Falcon Server Time
15 Jun 2026 00:10:34 EDT (-0400)
  Millennium Falcon (Message 23 to 32 of 32)
Subject: Re: Millennium Falcon
Date: 15 Jul 2000 23:16:29
Message: <397128C4.AEBEDCEE@yahoo.com>
oh, and i always use radiosity for final renders.  if you think the
underlying color of my xwing isn't white enough (and if you look at the
texture in moray it is very white), you should see it without radiosity.
besides, the shadows just seem better to me than low-intensity fill
lights do.
ryan constantine wrote:
> what do you know, that's pretty much the way i lit my last scene.  i
> used light groups via megapov.  the sun was the main light and affected
> all objects.  and there is a fill between the planet and the xwing that
> only affects the xwing.  i've studied photography a little and i
> recommend it to anyone creating images in any medium.  your advice is
> sound mr. day.  however, model showcases are the exception to this rule
> of thumb wouldn't you agree?  scenes deserve great lighting but when
> showing off of models there should be enough light to see by.  because
> of the stars, i'd say this was a scene.
> "H. E. Day" wrote:
> > Zeger,
> > This is a wonderful model.  The only beef I've got is with the lighting.
> > Let me share a secret with you.  The secret to great lighting is to *never*
> > (and I do mean never) put a main light *anywhere* near the camera. This
> > mistake is what makes those newbie 3DS and Lightwave rendering look so
> > crappy.Here is what I suggest.
> > FaintFillLight          Main Light
> >         Object
> > Camera
> > This is a top view of a lighting scheme that works pretty well.  The faint,
> > "fill" light (try <.2,.2,.25> and shadowless) would be at your current main
> > light location. Take the main light you have now and move it over to the
> > other side of the model.  Also, bring it closer to the front.  You can even
> > leave the intensity at 1.5.  Or, alternatively, you could change the
> > intensity to 1 and make a .5, shadowless, light at the same location.  This
> > will give a slight radiosity effect with no render overhead.
> > I'm sorry if I sounded preachy, but this is the single lighting mistake
> > that bugs me the most.
> > H.E. Day
Date: 16 Jul 2000 23:51:01
Message: <3971343A.7D4B1205@earthlink.net>
Most excellent... My applause... I wish my hand codes were as detailed as
you have done here... =)
> > I like it... Keep going...
> Tnx
> > Hand code...?
> Completely hand-coded.
> ZK
> http://www.povplace.be.tf
Date: 16 Jul 2000 23:56:49
Message: <39713596.7DE43352@earthlink.net>
In 14 days you should get about eighty frames done at 4hrs/frame...
Try 320X240... Usually makes a good movie size...?
Zeger Knaepen wrote:
> > You could always just try to imagine it is in an action scene then.  Or
> use a
> > tiny, microscopic, resolution.
> Or let it render while I'm on vacation.  When I come back (2 weeks later)
> I'll see it has finally reached frame 10 of 100 :-)
> > Bob
> ZK
Date: 17 Jul 2000 07:10:55
Message: <3972e9bf@news.povray.org>
Moon47 <rdm### [at] earthlinknet> schreef in berichtnieuws
39713596.7DE43352@earthlink.net...
You've actually been calculating it? :-)
How bored can you be :-)
320*240 is small.  I would go for at least 400*300.
But you forgot one thing: when doing an animation, it would probably fly
close by the camera.  A close-up won't render that 'fast'.
But, then again: there would be frames where the falcon looks like 2 pixels
ZK
Date: 18 Jul 2000 22:41:30
Message: <3973C6F0.E299513B@earthlink.net>
No not that bored... That is just my usual setting for an animation... Fair
resolution w/ fair speed ratio... Also minimal size for posting a still... Not
very detail sensitive although... =(
> ZK
Date: 18 Jul 2000 23:42:58
Message: <39751D1C.77E0@pacbell.net>
I found out how long patch objects take to parse when I was doing test
renders of my yet-to-be-finished Pod House. 740+ objects took about 3
hours to parse, followed by just over one hour to render. I'm trying to
figure out how to best replace as many of them with things like height
fields. Hopfully that will yeld more reasonable parse/render times.
Ken Matassa
Date: 19 Jul 2000 05:08:30
Message: <39756F17.1CA0696E@yahoo.com>
wow! 3 hours!  i would've done something about it a long time ago.  good
luck with your conversions!
> Ken Matassa
Date: 19 Jul 2000 12:55:32
Message: <3975dd84@news.povray.org>
3973C6F0.E299513B@earthlink.net...
Fair
Not
Have you ever posted a still of 320*240?  For an animation it might be ok,
but for a still?
I don't know...
ZK
Date: 19 Jul 2000 23:54:35
Message: <39752991.B389CB2A@earthlink.net>
Yes when i am testing for feed back... I usually don't spend too much time on
test renders until i am done with and am satisfied with the main body of the
image... I then add detail or suggestions if i receive any.., Then if i am
really into the image or want to see finer overall detail i expand the rez...
> Fair
> Not
> but for a still?
> I don't know...
> ZK
Date: 6 Aug 2000 03:07:25
Message: <398D0FA1.AF5860FB@home.com>
True but as someone who uses moray almost exclusively, but with an
understanding of Pov-Ray code, I can tell you that Moray REALLY helps when it
comes to things like scene composition and visualization, it helps you make
good use of the available camera view:-)
> Paul Vanukoff <van### [at] primenetcom> schreef in berichtnieuws
> 3970bb5c$1@news.povray.org...
> > One word: "Damn."
> Why?  It's a lot easier than using Moray!  You can use macros, while-loops
> and randomized objects!
> > Paul Vanukoff
> ZK
