POV-Ray : Newsgroups : povray.binaries.images : pov and psp planets Server Time
15 Jun 2026 01:29:23 EDT (-0400)
  pov and psp planets (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: pov and psp planets
Date: 12 Jul 2000 14:10:11
Message: <396CB4D9.6F1FB4D0@unforgettable.com>
ryan constantine wrote:
> here are some planet image maps i made in paint shop pro
The shadows seems a bit bright.. a thick atmosphere and/or moonlight can
help spread the light around a little, but generally, shadows in space
are very, VERY dark (you'd be amazed just how weak ambient starlight is
by itself).
Date: 12 Jul 2000 14:25:09
Message: <396cb805@news.povray.org>
"Andrea Ryan" <ary### [at] global2000net> wrote in message
news:396C72C4.44097E4E@global2000.net...
| Could spots that look like Jupiter's Great Red Spot be made?
Yes, in a way, using the 'black_hole' warp in the pigment.  Problem is you
need a color for it already present in the gradient color map, and it's just
not easy to work with in my experience anyway.  A layered texture could do
fairly well but then you don't get the good transition from lines to spot you
could get with the warp.
Date: 12 Jul 2000 17:20:39
Message: <396ce127$1@news.povray.org>
Not intentionally moving in on you Ryan but I've posted my idea of Jupiter at
povray.text.scene-files, can't miss it, subject says "Jupiter-like".  Nothing
perfected about it at
all, something for anyone to tinker with though.
Date: 12 Jul 2000 17:46:09
Message: <396CE66F.D1AD3870@yahoo.com>
i was thinking it would be cool if there were a "spin" and a "wind"
pattern or warp in povray.  what you would do is use it in a layered
texture.  all other layers would define the patterns and colors, and
then the wind and spin would streak it in a certain direction.  wind
would be linear and spin would be axial.  any programmers out there
reading this?
> Bob
Date: 12 Jul 2000 17:48:33
Message: <396CE700.763B007E@yahoo.com>
say hello to mister gamma.  on my monitor, the shadows ARE very dark.
no color at all.:(  maybe i should do that gamma test someone mentioned.
> by itself).
Subject: Re: Jupiter&Io 8kbbu
Date: 12 Jul 2000 19:48:59
Message: <396D0181.F4FC77D9@global2000.net>
Each band can be given turbulence by having a layered texture that are partly
transparent except for
some bands.  There will be one texture for each color of band.  Each texture will have
different
amounts of turbulence.
Here is a image of Jupiter and Io using image_maps.
Now I'm off to POV-Ray to try out the layered texture idea.
Brendan
Download 'jupiter.jpg' (9 KB)
Preview of image 'jupiter.jpg'
Date: 12 Jul 2000 22:55:37
Message: <chrishuff-18F203.21555912072000@news.povray.org>
In article <396CE66F.D1AD3870@yahoo.com>, ryan constantine
> reading this?
I have done a "push" warp, which displaces a texture in a specified
direction by an amount depending on how close it is to the center of the
warp. I am also planning a spin warp, which would be similar to what you
described, but would have a spherical range of effect.
Date: 13 Jul 2000 01:48:40
Message: <396D5891.F1196F3C@unforgettable.com>
Ah, of course. The gamma.
(I'm on a Mac.)
Date: 13 Jul 2000 02:38:27
Message: <396D6294.C0CA442A@yahoo.com>
win98 here.  that explains it.  assumed gamma of 2.2.
> (I'm on a Mac.)
Date: 13 Jul 2000 05:04:05
Message: <396d8605@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-18F203.21555912072000@news.povray.org...
Which leads me to ask about nonuniform scaling of warps.  I tried in vain to get the
Great Red Spot
to flatten out.  Only succeeded in moving it around.
This wind idea is a good one for sure, sounds like a matrix kind of thing.
