POV-Ray : Newsgroups : povray.binaries.images : q on isodonuts Server Time
18 May 2026 09:41:29 EDT (-0400)
  q on isodonuts (Message 1 to 5 of 5)
Subject: q on isodonuts
Date: 9 Jul 2000 23:37:56
Message: <39694514@news.povray.org>
Well, I have been playing around with isosurface donuts, and found something
puzzling.  The attached image (source code below) is of three isosurface
torii (donuts) that have, so far as I can tell, mathematically equivalent
functions.  Can anyone see why these functions produce different results?
Please excuse the inconsistent notation in the code--> I am still messing
with it, and have not prettied it up.
A Puzzled (like that's news) Quadhall
tre### [at] ww-interlinknet
#version unofficial MegaPOV 0.5;
light_source { <+0.00,+5.00,+0.00> 1 shadowless}
camera { location <+0.00,+7.50,+0.00> look_at <+0.00,+0.00,+0.00> }
#declare major=+1.00;
#declare minor=+0.25;
#declare a = function{sqrt((x^2)+(z^2))-major}
#declare b = function{atan2(z,x)*6}
#declare c = function{cos(5*atan2(y,a)+b)}
#declare d = function{sqrt(y^2+a^2)-minor+(.5*minor)*c}
//one
isosurface
 function {d}
 contained_by{sphere {0,2}}
 eval
 method 1
 max_gradient +1.00
 threshold 0
 pigment{color rgb 1}
 translate<-2.5,0,2>
#declare a = function{abs(sqrt((x^2)+(z^2))-major)}
//two
isosurface
 function {d}
 eval
 method 1
 max_gradient +1.00
 threshold 0
 translate<-2.5,0,-2>
#declare pre_a = function{sqrt((x^2)+(z^2))-major}
#declare a = function{abs(pre_a)}
//three
isosurface
 function {d}
 eval
 method 1
 max_gradient +1.00
 threshold 0
 translate<2,0,0>
Download 'plate_7.jpg' (25 KB)
Preview of image 'plate_7.jpg'
Subject: Re: q on isodonuts
Date: 10 Jul 2000 06:46:15
Message: <3969A905.12D25650@online.no>
The first and second expressions are mathematically
NOT equivalent:
sqrt(x^2 + z^2) - major  <>  abs(sqrt(x^2 + z^2) - major)
But, as far as I can see, the second and the last
expressions are equivalent and should produce the
same results (if my assumptions about function
and isosurfaces are right).
A tip for further debugging:
You might try to render each of the isosurfaces
independently, with ALL the code for the other
two commented out, to see if the results are
still the same.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 10 Jul 2000 08:43:30
Message: <3969c4f2@news.povray.org>
Oooh...
Date: 10 Jul 2000 14:26:12
Message: <396A1393.6C09BD89@faricy.net>
I don't know, but the code looks a bit excessive. I define torii by
sqrt((sqrt(x^2+z^2)-major)^2+y^2)-minor
First it creates a cirle of sorts around the y axis, then takes the distance
from that circle. It works with negative radii too, so you can get just the
spindle of a spindle torus.
Date: 10 Jul 2000 16:11:55
Message: <+wcExCAcyia5EwoN@econym.demon.co.uk>
These two are not the same. As far as MeagPov is concerned, first one is
the same as
  #declare a = function{abs(sqrt((x^2)+(z^2)))-major}
Note the different position of the final closing round bracket. With
this fixed, the two images are identical.
There's something peculiar going on here. It's interesting to note that
#declare a = function{pre_a}
renders like the other two, but
#declare a = function{(pre_a)}
and
#declare a = function(pre_a)
show the peculiar effect.
*However* the peculiar effects only occurs when you use "method 1",
which has been known to sometimes get things wrong. In fact "method 1"
gets all these isodonuts completely wrong. To see what they should
really look like, use "method 2" and *either* "eval" or "max_gradient
4.1". When you do this with the second and third donuts, they become
identical.
(If you use both "eval" and "max_gradient", MegaPov seems to use the
max_gradient you supplied and ignore the "eval". If you use "eval", it
will work out what the max_gradient should be - this may cause the
processing to take a little longer. If you specify a max_gradient, don't
lie about the value or you may get ragged holes.)
Mike Williams
Gentleman of Leisure
