POV-Ray : Newsgroups : povray.binaries.images : something to share... Server Time
6 May 2026 03:20:38 EDT (-0400)
  something to share... (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: something to share...
Date: 6 Jul 2000 05:47:38
Message: <396455ba@news.povray.org>
> Oh, and I figured it out using a pencil, paper and calculator, and the
> rotations I came out with were <45.0,0.0,35.26439>.  This was using
> nothing more complicated than basic trigonometry and Pythagoras' theorem.
okay okay.. as so many of you have pointed out it isn't all that tricky
after all <hangs his head in shame> :-(
Date: 6 Jul 2000 14:09:50
Message: <3964C951.BCF19E94@faricy.net>
Wait, wait, I have a *really* hard one! What would it look like if you took a
regular octahedron, aligned opposite points on the y-axis, and spun it? Only
kidding, of course... (not to self--shut up)
Date: 6 Jul 2000 19:59:34
Message: <MPG.13cee44d91e1e70989729@news.stmuc.com>
On Wed, 05 Jul 2000 21:20:20 -0500, David Fontaine wrote...
> Jamie Davison wrote:
> > <grin>
> <grin>
> *cough cough*
> I will not tolerate imperfection! Rotate <45,0,asin(1/sqrt(3))> ;-)
Nope, I came to it through Rotate <45.0, 0.0, atan(1/sqrt(2))>  :)
Or you could have used Rotate <45.0, 0.0, acos(sqrt(2)/sqrt(3))  But
that's just silly.
They all give you the same result, so who cares <grin>
Using the (admittedly crap) windows calculator, the following came out of
the two simpler methods:
asin(1/sqrt(3)) = 35.2643896827546543153770003300188
atan(1/sqrt(2)) = 35.2643896827546543153770003300188
Is that perfect enough?  Or do you require anally retentive levels of
precision?  ;)
Bye for now,
     Jamie.
Date: 6 Jul 2000 19:59:37
Message: <MPG.13cee5927eb494c498972b@news.stmuc.com>
On Thu, 6 Jul 2000 21:32:47 +1200, Ian Witham wrote...
It wasn't too easy either...  I took me a sheet of paper and a fair
amount of cursing before I remembered enough of my maths to figure it
out.  It's just too easy to sound glib and self satisfied when you've got
the answer sitting in front of you while you compose the posting to the
NG :)
Having a copy of Moray to display and verify the transformations didn't
hurt either <grin>
Oh, and I did a quick scene with 3200 cubes rotated at .1 degree
intervals, but got bored waiting for it to render :)
Bye for now,
     Jamie.
Date: 7 Jul 2000 03:58:49
Message: <39658db9@news.povray.org>
David Fontaine wrote in message <3964C951.BCF19E94@faricy.net>...
a
Only
Or how about a regular hexahedron?  :-)
Mark
Date: 7 Jul 2000 14:43:03
Message: <39662311.4FB6DFFD@faricy.net>
Of course, it really should be written as asin(sqrt(3)/3)...
> that's just silly.
> precision?  ;)
Date: 7 Jul 2000 14:45:18
Message: <39662398.E66B2AB1@faricy.net>
> a
> Only
> Mark
Oops, should be NOTE to self (missed the 'e')
Did you know that any four non-consecutive points on a cube define a regular
tetrahedron? :) Of course, there's only two ways to do that on a cube.
Date: 7 Jul 2000 17:57:51
Message: <MPG.13d06093c0d16c39989731@news.stmuc.com>
On Fri, 07 Jul 2000 13:36:02 -0500, David Fontaine wrote...
Why?  It all comes out the same in the end, so use the syntax you like
and can understand.
Or am I missing something here?  Admittedly, my mathematics goes up to
about halfway through 'A' Level, when we hit the more complex end of
calculus and statisitcs, whereupon my brain fell over, so I could easily
be missing something.
Bye for now,
     Jamie.
Date: 8 Jul 2000 00:16:48
Message: <98mams4f58mj2tm6973cpovlr95ol61jri@4ax.com>
On Fri, 7 Jul 2000 22:51:16 +0100, jam### [at] dh70qdu-netcom (Jamie
>and can understand.
Well, 1/sqrt(3) = sqrt(3)/3
It's just that the latter is the rationalized, more acceptable form of
it.
Peter Popov ICQ : 15002700
Date: 8 Jul 2000 10:39:34
Message: <MPG.13d11f78e2c31b11989732@news.stmuc.com>
On Fri, 07 Jul 2000 07:14:47 +0300, Peter Popov wrote...
> >and can understand.
> it.
OK, so I *was* missing something :)
I think I'll stick to the incorrect syntax myself, as if nothing else, it
helps me remember where in the calculations I got the value from. (if you
could see the average page of scribbling and trigonometry, you'd
understand why I need help remembering such things <grin>)
Bye for now,
     Jamie.
