POV-Ray : Newsgroups : povray.binaries.images : potplant 37.8k Server Time
15 Jun 2026 03:29:50 EDT (-0400)
  potplant 37.8k (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: potplant 37.8k
Date: 29 Jun 2000 06:51:56
Message: <395b2a4c@news.povray.org>
| "Ian Witham" <ian### [at] hotmailcom> wrote in message
news:395a4789@news.povray.org...
| Hi there,  I'm new to the pov-ray newsgroups... but you seem like a friendly
enough crowd.
Hi Ian.  Friendly? Yes.  That is, until HTML is used to post messages...
plain text is preffered due to the wide variety of newsreader programs people
use here.  Please have a look at posting guidelines at
povray.announce.frequently-asked-questions.  That can help in the future.
| With this in mind I have decided to offer this here picture for criticism.
Don't hold back, tell me how to |make it the best pot plant ever... I was
going for something like a Cantonese Lace. I used SplineTree |and some scanned
leaves for the plant, h.f. for the dirt, and csg for the pot.
I don't know much about plants, this one looks good far as branching and leaf
placement goes, just a bit thinned-out looking.  The detail to the leaves is
nice, even though not very visible here.  You could vary them slightly with a
'turbulence' added in: pigment {image_map{} turbulence 0.05} for close ups or
larger renders.
|The area light shadow of the foliage looks even grainier on a less compressed
image.. how can I fix |this? (make nice soft shadows)
It may be that the area light is near and wide.  If the light/plant distance
were 10, for example, with a plant size of around 1 then I'd have used a
'area_light <1,0,0>,<0,1,0>,4,4 jitter adaptive 1' (situated facing the plant)
but no more than that.  Every situation is different though.  Were you using
MegaPov then adding in 'orient' 'circular' would help it greatly.
I like the bowl, the dirt could use some color variation of sharp contrast at
a small scale using a granite patterned colormap for example.
Date: 29 Jun 2000 07:14:29
Message: <395b2f95@news.povray.org>
friendly
> enough crowd.
yeah sorry... already been told off for that one!  :-)
criticism.
scanned
leaf
is
with a
or
> larger renders.
That's a great idea, but I've also used the same leaf images for
bump_map's... if I add the same amount of turbulence to the image_map and
bump_map will they still line up?
compressed
It was, and I've fixed it now, thanks.
Date: 29 Jun 2000 08:33:45
Message: <395b4229@news.povray.org>
nice plant, looks like a miniature tree.
weird though, oe didnt show the usual paper clip attachment, i nearly
missed it !
friendly enough crowd.
criticism.  Don't hold back, tell me how to make it the best pot plant
ever... I was going for something like a Cantonese Lace. I used
SplineTree and some scanned leaves for the plant, h.f. for the dirt, and
csg for the pot.
compressed image.. how can I fix this? (make nice soft shadows)
  Ian
Download 'iso-8859-1' (2 KB)
Date: 29 Jun 2000 09:09:56
Message: <395b4aa4$1@news.povray.org>
Rick schrieb in Nachricht <395b4229@news.povray.org>...
weird though, oe didnt show the usual paper clip attachment, i nearly missed
it !
Instead OE copied the hole HTML-Message including the pic. Could be good to
uncheck "options"-"send"-"use same format for reply" (or something like
that).
Marc-Hendrik
Date: 29 Jun 2000 09:48:33
Message: <395b53b1@news.povray.org>
news:395b2f95@news.povray.org...
Yep, if scale, rotate, translate are the same too.  Just be careful not to
turbulate into chaos.
Example:
    pigment {image_map {png "c:\images\IEerror.png"
       // interpolate 2 // smooth it
        once   // don't tile image, just one copy
       // filter all .75  // make 1st color mostly transparent
       // transmit 1, .75  // make 2nd color mostly transparent
      // transform it to unit-size (-1 to +1)
      translate -0.5*(x+y) // center on the origin
      scale 2              // make it 2 units across
     turbulence .125
    normal {bump_map {png "c:\images\IEerror.png"
                 } bump_size 2 // raise or lower relief
     turbulence .125
    finish {ambient .125 diffuse .75 specular .25 roughness .075}
Date: 29 Jun 2000 12:34:07
Message: <395B78F0.FE3211B4@faricy.net>
Mmm, plantalicious! Just listen to the other people, the dirt is too
saturated and crank up the area lights...
Date: 29 Jun 2000 14:26:54
Message: <395b94ee@news.povray.org>
Ohhhh... you mean a "potted plant."  I was expecting.... oh, never mind.
Eric
Date: 30 Jun 2000 01:35:31
Message: <395C30A8.A8414C39@pacbell.net>
"Lt. Kettch" wrote:
> (he thinks), Gillis Trans has mastered hacking into POV Ray to make a
Gillis Trans ? Interesting mispelling :)
Try Gilles Tran.
Date: 30 Jun 2000 03:41:17
Message: <395C4EA3.3510FE67@aol.com>
Oops.
Date: 30 Jun 2000 21:30:28
Message: <395D4819.16C06613@faricy.net>
lol
