POV-Ray : Newsgroups : povray.binaries.images : potplant 37.8k Server Time
15 Jun 2026 03:29:49 EDT (-0400)
  potplant 37.8k (Message 11 to 16 of 16)
Subject: Re: potplant 37.8k
Date: 29 Jun 2000 09:48:33
Message: <395b53b1@news.povray.org>
"Ian Witham" <ian### [at] hotmailcom> wrote in message
news:395b2f95@news.povray.org...
| >   You could vary them slightly with a
| > 'turbulence' added in: pigment {image_map{} turbulence 0.05} for close ups
| That's a great idea, but I've also used the same leaf images for
| bump_map's... if I add the same amount of turbulence to the image_map and
| bump_map will they still line up?
Yep, if scale, rotate, translate are the same too.  Just be careful not to
turbulate into chaos.
Example:
    pigment {image_map {png "c:\images\IEerror.png"
       // interpolate 2 // smooth it
        once   // don't tile image, just one copy
       // filter all .75  // make 1st color mostly transparent
       // transmit 1, .75  // make 2nd color mostly transparent
      // transform it to unit-size (-1 to +1)
      translate -0.5*(x+y) // center on the origin
      scale 2              // make it 2 units across
     turbulence .125
    normal {bump_map {png "c:\images\IEerror.png"
                 } bump_size 2 // raise or lower relief
     turbulence .125
    finish {ambient .125 diffuse .75 specular .25 roughness .075}
Date: 29 Jun 2000 12:34:07
Message: <395B78F0.FE3211B4@faricy.net>
Mmm, plantalicious! Just listen to the other people, the dirt is too
saturated and crank up the area lights...
Date: 29 Jun 2000 14:26:54
Message: <395b94ee@news.povray.org>
Ohhhh... you mean a "potted plant."  I was expecting.... oh, never mind.
Eric
Date: 30 Jun 2000 01:35:31
Message: <395C30A8.A8414C39@pacbell.net>
"Lt. Kettch" wrote:
> (he thinks), Gillis Trans has mastered hacking into POV Ray to make a
Gillis Trans ? Interesting mispelling :)
Try Gilles Tran.
Date: 30 Jun 2000 03:41:17
Message: <395C4EA3.3510FE67@aol.com>
Oops.
Date: 30 Jun 2000 21:30:28
Message: <395D4819.16C06613@faricy.net>
lol
