POV-Ray : Newsgroups : povray.binaries.images : xwing, nearing completion... Server Time
15 Jun 2026 07:06:22 EDT (-0400)
  xwing, nearing completion... (Message 4 to 13 of 33)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: xwing, nearing completion...
Date: 29 Jun 2000 07:09:26
Message: <395b2e66@news.povray.org>
"ryan constantine" <rco### [at] yahoocom> wrote in message
news:395B25F1.6F4F3D80@yahoo.com...
| <embarrassed >by the way, in all my test renders, i didn't notice that
| the half circles at the end of the laser canons overlap.  until now.
| oops...</embarrassed>
I was going to mention that if you hadn't.
The texture, overall, just seems too dull to me.  Has the look of being in a
dimly lit hanger or something I guess it is.  Should the lighter parts be
brighter, more reflective, specular, or whatever?  The red painted part is
likewise.  I'm just going by memory of the movies, I realize these tended to
be weather-worn and they were also in various states of cleanliness too I
believe.  I'm just saying this looks coated in dust, as is.  Wait, that's what
I'm trying to say, it looks to have been stored away for several years.
You have a great project going there, hope you make time for some play too.
Date: 29 Jun 2000 08:33:47
Message: <395b422b$1@news.povray.org>
> on more thing... does anyone have pictures or blueprints or the like of
> the inside of the cockpit?  i'd like to make two versions, one as seen
> from outside (low detail) and one as seen from inside (high detail).  if
> i can't find pics, then i'm just going to do the low detail version and
> move on to something else (like animations).
try getting some screen shots from star wars, then making your own, i did
have some cockpit stickers with my toy x-wing, but alas that is gone into
the hands of a grubby (and somewhat tubby) collector.
Date: 29 Jun 2000 08:37:29
Message: <395b4272.453955@news.povray.org>
ryan constantine <rco### [at] yahoocom> wrote:
> i've knuckled down the last several days and i'm nearly finished.
Great modelling!  What did you use as reference material?
Jeff Lee         shi### [at] gatenet        http://www.gate.net/~shipbrk/
  "The only thing that helps me maintain my slender grip on reality
  is the friendship I share with my collection of singing potatoes."
Date: 29 Jun 2000 12:34:30
Message: <395B7B73.B4F8BF0C@aol.com>
Great modelling. It needs one more thing to make the texture complete, IMO.
It needs to have big, dark burn marks where circuitry has shorted out from
time-to-time.
~Samuel
ryan constantine wrote:
> i've knuckled down the last several days and i'm nearly finished.  i'm
> replacing the current fuselage, and i still have the landing gear and
> cockpit (maybe- on that last one) to do, but as you can see, the
> textures are about there.  the fuselage in this pic is the old one (as
> is the nose) and has to be two copies of a solid mesh, cut in half, with
> different inside_vector statments.  not pretty.  it was made in spatch
> as is the remake.  the remake breaks it up into three seamless
> sections.  the nose will be brought in as a patch and has the cutout
> already in it.  the middle section has the cockpit cutout as well as the
> landing gear bay, and the rear has the wing hole, the top and rear
> detail cutouts, and the cargo hatch.  those last two sections will be
> solid meshes.  all textures are procedural including the squad
> striping.  when i finish, i'll clean everything up and post both moray
> and pov versions of the source.
Date: 29 Jun 2000 14:51:30
Message: <395b9ab2@news.povray.org>
Very nice model.  Is it just me or is the ship made out of concrete?
Eric
Date: 29 Jun 2000 15:24:05
Message: <395BA1DB.B75E55E6@yahoo.com>
the ships don't have any metallic shininess or anything.  they actually
have a lot of "dirt" or whatever all over them.  i'm not so sure it
would be realistic (the air force washes planes right?) but that's how
they were in the movies.  i actually need to add some darker stains as
well.  the models i based my textures on look almost exactly the same as
my image, while another model i have pictures of looks to have been
given liberal sprays of matte black spray paint and is quite dark
overall.  i like the lighter color.  perhaps i should post a comparison
pic next time.
> Bob
Date: 29 Jun 2000 15:32:12
Message: <395BA3C2.CBBD324F@yahoo.com>
you'll see in previous posts that i used the last model produced and
dial calipers accurate to the hundreth of an inch (guessing the
thousandths) as the main source.  i also have about 30 pictures gleened
off the web including some a guy took at the smithsonian.  and last but
not least, i used some books i have and my brother's cd rom.  there were
about a dozen models used in production of the films and no two are
alike.  i therefore had to make judgments as to what i liked the best.
i also compared the movies on vhs.  overall i tried to make things match
the full size version the actors sat in.  there are over 1100 objects in
the model.  i would have to say that i used the videos the most.
Date: 29 Jun 2000 17:50:12
Message: <395BC422.6C8E068D@aol.com>
Yes, the Air Force washes its planes. Why, I'm not sure, maybe to increase its life
span.
Date: 29 Jun 2000 17:53:12
Message: <395BC4D6.CB02FB58@aol.com>
The best I have is the inside of a Micro Machine X-Wing. One of the one that
has luke and artoo that you can put in it, than fly around and beat the
stuffings out of Vader..
Date: 29 Jun 2000 20:24:27
Message: <3tpnlssj1s7p0snquhjgmhtvdnns7cg867@4ax.com>
On Thu, 29 Jun 2000 13:48:18 -0800 "Lt. Kettch" <AKK### [at] aolcom>
>span.
  I think that's the reason. Keeping the surface clean probably removes
contaminants that will ruin the finish coating on the metal, which in
turn protects the bare metal from corrosion in the harsh environment of
flight.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
