POV-Ray : Newsgroups : povray.binaries.images : xwing, nearing completion... Server Time
15 Jun 2026 03:27:47 EDT (-0400)
  xwing, nearing completion... (Message 11 to 20 of 33)
Subject: Re: xwing, nearing completion...
Date: 29 Jun 2000 17:50:12
Message: <395BC422.6C8E068D@aol.com>
Yes, the Air Force washes its planes. Why, I'm not sure, maybe to increase its life
span.
Date: 29 Jun 2000 17:53:12
Message: <395BC4D6.CB02FB58@aol.com>
The best I have is the inside of a Micro Machine X-Wing. One of the one that
has luke and artoo that you can put in it, than fly around and beat the
stuffings out of Vader..
Date: 29 Jun 2000 20:24:27
Message: <3tpnlssj1s7p0snquhjgmhtvdnns7cg867@4ax.com>
On Thu, 29 Jun 2000 13:48:18 -0800 "Lt. Kettch" <AKK### [at] aolcom>
>span.
  I think that's the reason. Keeping the surface clean probably removes
contaminants that will ruin the finish coating on the metal, which in
turn protects the bare metal from corrosion in the harsh environment of
flight.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 29 Jun 2000 23:24:24
Message: <395c12e8$1@news.povray.org>
"Lt. Kettch" <AKK### [at] aolcom> wrote in message
news:395BC422.6C8E068D@aol.com...
> sure, maybe to increase its life span.
Maybe just to keep people busy.  When I was in the Navy we had a Marine
detachment on board (I was on the aircraft carrier USS Kitty Hawk).  They
had an old F4.  It never flew, but the jarheads were always taking it apart,
painting it, and generally just getting in the way messing with it.
Eric
Date: 30 Jun 2000 01:48:44
Message: <395C33C0.9ABAE16F@pacbell.net>
> >span.
> flight.
They keep it clean to reduce drag which improves flight effeciency and
fuel comsumption. On some of the jets that can exceed mach 2 or better
even finger prints can cause enough drag to be noticable.
Date: 30 Jun 2000 09:52:34
Message: <395ca622@news.povray.org>
ryan constantine <rco### [at] yahoocom> wrote in message
news:395B24F5.88D9E917@yahoo.com...
> i've knuckled down the last several days and i'm nearly finished.
Whoa!  Looking very nice!
You might want to put a few "war defects on it."  Ya know, like maybe a
laser burn or something.  Or maybe I'm asking for too much too soon ;-)
I can't wait to see this when it's done!  May the force be with you, Ryan!
-Ian
Date: 30 Jun 2000 23:14:40
Message: <32oqlsk8hpjaanl0038o04qh9q5rj6c520@4ax.com>
  Ack! The more obvious answer... even on race cars, taping over of gaps
between body panels can eke out another few miles per hour from a
production-type body design. These improvements are sure to be more
significant as speed increases.
Alan
Date: 1 Jul 2000 06:25:34
Message: <395dc71e@news.povray.org>
Of, course there's no such drag in space so no reason to keep your xwing
clean...
Ian
Inkwell: Ian's Homepage
http://www.topcities.com/cartoon/inkwell/index.htm
Ken <tyl### [at] pacbellnet> wrote in message
news:395C33C0.9ABAE16F@pacbell.net...
increase its life
> > >span.
> > flight.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 1 Jul 2000 09:41:48
Message: <395DF45F.C65B6BA5@attglobal.net>
> clean...
I'm pretty sure that since X-wings can go faster than light even the
traces of hydrogen and helium gas found in space will cause some drag.
Francois Labreque | Rimmer: "Let's go to red alert!"
     flabreq      | Kryten: "Are you sure, Sir?  You realize it
        @         |          actually means changing the bulb!"
  attglobal.net
Date: 1 Jul 2000 10:31:25
Message: <395e00bd@news.povray.org>
If you've jumped to hyperspace how much faster do you need to get? Is there
a range of faster than light speeds for cleaner than clean space ships?  I
would have thought such a twist in the space-time would bring you to your
destination at the same instant you leave -- but in star-wars they entered
hyperspace and then had time to sit around playing chess, practising light
sabre duelling, drinking coffee etc.  Perhaps this is because the Millennium
falcon was such a grubby thing.  It looks as though the clean spaceship vs.
dirty spaceship debate has been thrown wide open.
Ian
Inkwell: Ians Homepage
Francois Labreque <fla### [at] attglobalnet> wrote in message
news:395DF45F.C65B6BA5@attglobal.net...
> > clean...
