POV-Ray : Newsgroups : povray.binaries.images : Fireplace scene started [~39KB Jpg] Server Time
15 Jun 2026 03:29:49 EDT (-0400)
  Fireplace scene started [~39KB Jpg] (Message 11 to 17 of 17)
Subject: Re: Fireplace scene started (marble pattern) [~19KB Jpg]
Date: 27 Jun 2000 15:52:37
Message: <39590605@news.povray.org>
Bob, that last post was awesome! :)
Have you tried to reproduce glowing portions of the wood? I know these
texture/object definitions get out of hand quickly, but this is SO close! ;)
Grim
Subject: Re: Fireplace scene started [~39KB Jpg]
Date: 27 Jun 2000 16:06:56
Message: <39590960.29F4E60A@schunter.etc.tu-bs.de>
Bob Hughes wrote:
> Hi everyone.  Someone (or 2) had brought up the subject of "fire" once again,
> so...
> Here's two renders, first done with radiosity and second without (and a few
> minor changes made).  The radiosity has promise but it sure changes everything
> so I can't really judge by a non-radiosity rendering test.  All takes time as
> you all know.  Anyway, 2h18m for radiosity, 1h33m without.  Two area lights
> used and function 'func_9' for the isosurfaced logs, a turbulent gradient y
> media for the fire itself.
> Is it any good at all, is the question.  What do you think?  Never mind the
> compression artifacts and general scene please  ;-)
> Bob
I especially like the brick walls of the fireplace.  Fire itself looks very
convincing - I don't know much about media.
One thing I miss is the ashes below the grate (is that the right word?).  Maybe
some isosurface using crackle pattern ...
Date: 27 Jun 2000 17:21:37
Message: <39591ae1$1@news.povray.org>
The flames now convince even me :-)
That blue is indeed not right (to me) - why should it be under the logs? Mix
it up with the lower part of the flames if possible. Hm, perhaps it would be
good to put some red and orange in parts of the pigment of the logs? They
are glowing ... or is it already in there?
Hope I can get sometime as near to 'reality' as you are with this one.
Marc-Hendrik
Date: 28 Jun 2000 04:05:34
Message: <3959b1ce@news.povray.org>
"GrimDude" <vos### [at] yahoocom> wrote in message
news:39590605@news.povray.org...
Thanks, I think it's something seen differently by different people.  It
actually already does have glowing red parts on them, kind of blending into
the flames.  I used a 'spherical' pattern to apply a 'texture_map' of
'crackle' in the central part and 'onion' then 'wood' for the outer parts.
Radiosity is wreaking havoc on the fire and logs causing the textures to all
but disappear.
Date: 28 Jun 2000 04:09:24
Message: <3959b2b4@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:39591ae1$1@news.povray.org...
Hope so too, I can't go it alone.  Glad you are liking it.
There is a bright red 'crackle' pattern included into a 'spherical'
'texture_map' on the logs but radiosity is changing much of the way it looks
to where you can't really see the log texture very well.
Another render has finished so I'll be uploading that.
Date: 28 Jun 2000 04:14:46
Message: <3959b3f6@news.povray.org>
"Tor Olav Kristensen" <tto### [at] onlineno> wrote in message
news:39590504.85E83E96@online.no...
| I don't know anything about radiosity or media, but I know that logs burn
| better if they are stacked vertically and when there are several of them.
| Nice flames. The ones in the bottom image looks best.
Well, that would be the non-radiosity one  ;-)  I've since changed the logs a
bit but not much different from these.  I probably should put some effort into
placing the logs, they weren't checked from all sides first.
Maybe you will like the next one I'm about to post too.  It didn't go exactly
right at all though  :-(
Date: 28 Jun 2000 04:33:22
Message: <3959b852@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in message
news:39590960.29F4E60A@schunter.etc.tu-bs.de...
Maybe
I'd call it a "grate", yeah.  The high viewpoint of the camera combined with
very low logs is hiding the ashes and hot embers a lot.  There actually is a
'granite', 'crackle', 'granite' pattern there using a 'spherical'
'texture_map', much the same as I did with the log texturing.  I went with
trying to get a reflection off of the outer hearth instead... a mistake I
guess.  Hmm, no one going to mention it's all one-piece slabs around the
fireplace?  Okay by me  :-)
