POV-Ray : Newsgroups : povray.binaries.images : Stargate (10124x768, 148 KB) - stargate.jpg (0/1) Server Time
18 May 2026 10:49:37 EDT (-0400)
  Stargate (10124x768, 148 KB) - stargate.jpg (0/1) (Message 1 to 10 of 49)
Subject: Stargate (10124x768, 148 KB) - stargate.jpg (0/1)
Date: 26 Jun 2000 16:09:02
Message: <3957c5ca.3520857@news.povray.org>
I know it's still missing a couple of details, but it's not too bad, I
think.
Rendered with unofficial OS/2 PM compile of 3.1g Linux sources.
Jeff Lee         shi### [at] gatenet         http://www.gate.net/~shipbrk/
Subject: Stargate (10124x768, 148 KB) - stargate.jpg (1/1)
Date: 26 Jun 2000 16:16:38
Message: <3957c63e.3637078@mailhost.gate.net>
Download 'stargate.jpg' (148 KB)
Preview of image 'stargate.jpg'
Subject: Re: Stargate (10124x768, 148 KB) - stargate.jpg (0/1)
Date: 26 Jun 2000 16:17:19
Message: <3957c81e.4117178@news.povray.org>
Uh, that's *1024* by 768, of course...
Date: 26 Jun 2000 16:35:08
Message: <39581362.6AEE748A@home.nl>
> think.
Missing detials? Not too bad?
It's great!
Remco
Date: 26 Jun 2000 16:45:18
Message: <3957c0de$1@news.povray.org>
Everything about this (lighting, textures, composition) is amazing!
Hand coded?  400 hours on your Athlon?  Beautiful!
"Jeff Lee" <shi### [at] gatenet> wrote in message
news:3957c5ca.3520857@news.povray.org...
> think.
Date: 26 Jun 2000 16:50:38
Message: <3957C2F2.4AFCEE10@yahoo.com>
was this done in pov?  i was just watching sg1 the other night and was
thinking about someday doing a model of this.  what did you use for
textures?  have you attempted the iris or the gate effects?  way back
when someone posted a 'star gate' i was disappointed when i clicked on
it and it wasn't this stargate.  good job.
> think.
Date: 26 Jun 2000 16:54:28
Message: <3957C3D7.427D61DA@yahoo.com>
by the way, aren't you the guy that did the fabulous original enterprise
(orbit.pov)?  i've changed the halo in that to use media and am
currently using a derivative of your clouds in a planet i'm working on
(will actually post later today).  i don't think you post very often do
you?  how long does it take you to do a project?  i'd be interested to
know some of your texturing methods (modelling isn't a problem).  again,
good work.
> think.
Date: 26 Jun 2000 16:55:48
Message: <3957C2CC.7F658EA3@online.no>
> think.
I'm impressed !
Especially I like your work with the cables and the pipes.
Only one little detail bothers me: There are some symbols on the
"wheel" that is covered by the "V-cut outs".
Tor Olav
mailto:tor### [at] hotmailcom
Date: 26 Jun 2000 17:01:48
Message: <3957d270.6756873@news.povray.org>
Thanks!
Yes, hand coded.  I think it took about 12 hours to render on an AMD
K6-2/500.
Date: 26 Jun 2000 17:15:29
Message: <3957d2ab.6815917@news.povray.org>
Yes; my own compile for OS/2, but using the official Linux 3.1g sources.
> what did you use for textures?
It's all texture{} statements.
It is capable of producing the rippling "water" effect, but I haven't
added in the iris or worked on the "whoosh" yet.  (All the chevrons are
independently animatable and lightable, and of course the glyph ring
turns.  It can also be set to resemble the prop from the original movie,
which was slightly different from the one on the TV series.)
> (orbit.pov)?
Yeah, that was me, thanks for remembering it.  My Enterprise model is
currently under revision, because the blueprints I worked from weren't
entirely accurate in places, and it will soon (I hope) be joined by a
Klingon D7.
> i don't think you post very often do you?
Not really, no; I have to juggle 3D work with a whole bunch of other
hobbies.  If I can put together one really nice image that I'm happy
with every few months, I consider myself lucky.
Depends on the scope.  In this case, the Stargate itself took about two
weeks, and the reproduction of the set took about a month and a half,
whenever I could squeeze in a couple of hours at night.
> i'd be interested to know some of your texturing methods (modelling
> isn't a problem).
Any textures in particular?  What I seem to be doing most frequently is
to create a "clean" and "dirty" version of a particular texture, and
then make a bozo composite of the two, adding turbulence and raising the
omega and lambda, then scaling the resulting texture between 2-5 times
longer in the Y direction, depending on how "streaky" I want it to look.
