POV-Ray : Newsgroups : povray.binaries.images : Fast Grass (grass.jpg 82 kb bu) Server Time
17 Jun 2026 06:04:53 EDT (-0400)
  Fast Grass (grass.jpg 82 kb bu) (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Fast Grass (grass.jpg 82 kb bu)
Date: 23 Jun 2000 13:28:27
Message: <39539F15.833BFFE3@aol.com>
Alan Kong wrote:
> On Thu, 22 Jun 2000 18:32:39 -0700 SamuelT <STB### [at] aolcom> wrote:
> >What do you think? Is the grass fast?
> Samuel's clouds do cast
> shadows upon his sea of grass, so vast,
> until such time when clouds have passed
> reminding us that forever nothing will last.
It was a valid question. I really don't know if it is fast for grass or
not. It's the fastest I've been able to get grass to render, but perhaps
there are faster ways?
>   Okay, I'm not a poet. How about the source for your grass scene,
> Samuel?
I will, one I get it to look more like grass, and less like green bird
feathers :) Plus, the code is at home, and I am at work right now....
~Sam
Date: 23 Jun 2000 13:29:44
Message: <39539F62.51B7B1C8@aol.com>
I've got to remember how to animate, but my computer currently crashes when I try
to play an avi file.
Bob Hughes wrote:
> "SamuelT" <STB### [at] aolcom> wrote in message news:3952BE36.8E44BAC1@aol.com...
> | Here's some fast-rendering grass I came up with today.  The whole scene
> | (5000 blades of grass, 25001 objects) took only 1 minute, 57 seconds
> | with aa on. I'm running an AMD k6-2 500 mhz processor with 128mb ram.
> | P.S. I rotated and scale the grass according to a hidden pigment to
> | simulate wind effects.
> It's fast if that's render + parse time, I think so anyhow.
> I realize now that it isn't just made up of a zero-sided box and a single
> triangle as I first thought, silly me.  But I still don't understand anything
> about eval_pigment yet.  I'll get around to it someday though.
> If you have this ready to animate (or not) I'm sure it would look fantastic if
> it were.
> Bob
Date: 23 Jun 2000 13:31:05
Message: <39539FB4.8F2888B5@aol.com>
"Tony[B]" wrote:
> Interesting... I've never seen little stalks like that at the bottom of
> grass. Looks good for a far off effect, on hills and stuff.
Me neither. I was trying to make the tall kind of grass, but as I mentioned to
Alan, it looks like bird feathers instead.
~Sam
Date: 23 Jun 2000 13:34:01
Message: <3953A064.3E966CF9@aol.com>
Christoph Hormann wrote:
> Thats's pretty fast, BTW, you are using the same computer as me :-)
The same computer, really? I bet mine crashes more though...
> A little variation in blade bending would be nice, even though that
> would probably destroy the efficiency...
Yes, it would render a lot slower if I did that, unless I used scale z*n to
do it.... hmmm......
> IMO it would also be a good idea adding that eval_pigment construction
> to other similar macros.
> Christoph
It would be great if someone could figure out how to use it for trees.
~Sam
Date: 23 Jun 2000 13:56:46
Message: <chrishuff-2ED3F5.13011323062000@news.povray.org>
In article <3952db8e@news.povray.org>, "Bob Hughes"
<per### [at] aolcom?subject=PoV-News:> wrote:
> But I still don't understand anything about eval_pigment yet.
It is quite simple:
A pigment simply defines a color for each point in space, using a color,
image, or pattern + color_map. The eval_pigment returns the rgb color of
the pigment at a specified point of space.
Since a color is basically a vector, you can use this to pattern
interesting displacements like wind-blown grass, rock placement in a
stream, smoke particles, etc...you can get much more variation and
control than you would get with just turbulence.
Personal Web page: http://chrishuff.dhs.org/
Date: 23 Jun 2000 14:00:21
Message: <chrishuff-EFC2BE.13044623062000@news.povray.org>
Try adjusting phase while translating the pigment...maybe add some
turbulence to the pigment too.
Date: 23 Jun 2000 14:02:22
Message: <chrishuff-2EBBCE.13064823062000@news.povray.org>
You could use eval_pattern() or eval_pigment() to control the branch
number and probability according to a pattern...and you could have
recursion stop when one goes below a certain threshold. Could make some
interesting topiary.
Date: 23 Jun 2000 14:40:38
Message: <3953AFFF.6F9A4753@aol.com>
He forgot to mention it doesn't test for all colors in a scene, it tests
for a pigment you feed it. By the, Chris, how would use use eval_pigment
for smoke?
~Sam
> It is quite simple:
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> TAG Web page: http://tag.povray.org/
Date: 23 Jun 2000 15:55:35
Message: <chrishuff-6B59FF.15000223062000@news.povray.org>
> for smoke?
With smoke, it could be used to make a "swirly" effect depending on a
pattern, or you could just use it to turbulate the particles a bit. Or
you could use it as "wind", and fake the wind currents near objects and
the ground.
Date: 23 Jun 2000 16:09:02
Message: <3953C4B8.7C2B34B@aol.com>
Hmm, sounds interesting. Might have to try that sometime.
~Sam
> > for smoke?
> the ground.
