POV-Ray : Newsgroups : povray.binaries.images : Fast Grass (grass.jpg 82 kb bu) Server Time
15 Jun 2026 05:15:23 EDT (-0400)
  Fast Grass (grass.jpg 82 kb bu) (Message 11 to 18 of 18)
Subject: Re: Fast Grass (grass.jpg 82 kb bu)
Date: 23 Jun 2000 13:31:05
Message: <39539FB4.8F2888B5@aol.com>
"Tony[B]" wrote:
> Interesting... I've never seen little stalks like that at the bottom of
> grass. Looks good for a far off effect, on hills and stuff.
Me neither. I was trying to make the tall kind of grass, but as I mentioned to
Alan, it looks like bird feathers instead.
~Sam
Date: 23 Jun 2000 13:34:01
Message: <3953A064.3E966CF9@aol.com>
Christoph Hormann wrote:
> Thats's pretty fast, BTW, you are using the same computer as me :-)
The same computer, really? I bet mine crashes more though...
> A little variation in blade bending would be nice, even though that
> would probably destroy the efficiency...
Yes, it would render a lot slower if I did that, unless I used scale z*n to
do it.... hmmm......
> IMO it would also be a good idea adding that eval_pigment construction
> to other similar macros.
> Christoph
It would be great if someone could figure out how to use it for trees.
~Sam
Date: 23 Jun 2000 13:56:46
Message: <chrishuff-2ED3F5.13011323062000@news.povray.org>
In article <3952db8e@news.povray.org>, "Bob Hughes"
<per### [at] aolcom?subject=PoV-News:> wrote:
> But I still don't understand anything about eval_pigment yet.
It is quite simple:
A pigment simply defines a color for each point in space, using a color,
image, or pattern + color_map. The eval_pigment returns the rgb color of
the pigment at a specified point of space.
Since a color is basically a vector, you can use this to pattern
interesting displacements like wind-blown grass, rock placement in a
stream, smoke particles, etc...you can get much more variation and
control than you would get with just turbulence.
Personal Web page: http://chrishuff.dhs.org/
Date: 23 Jun 2000 14:00:21
Message: <chrishuff-EFC2BE.13044623062000@news.povray.org>
In article <39539F62.51B7B1C8@aol.com>, STB### [at] aolcom wrote:
> I've got to remember how to animate,
Try adjusting phase while translating the pigment...maybe add some
turbulence to the pigment too.
Date: 23 Jun 2000 14:02:22
Message: <chrishuff-2EBBCE.13064823062000@news.povray.org>
You could use eval_pattern() or eval_pigment() to control the branch
number and probability according to a pattern...and you could have
recursion stop when one goes below a certain threshold. Could make some
interesting topiary.
Date: 23 Jun 2000 14:40:38
Message: <3953AFFF.6F9A4753@aol.com>
He forgot to mention it doesn't test for all colors in a scene, it tests
for a pigment you feed it. By the, Chris, how would use use eval_pigment
for smoke?
~Sam
> It is quite simple:
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> TAG Web page: http://tag.povray.org/
Date: 23 Jun 2000 15:55:35
Message: <chrishuff-6B59FF.15000223062000@news.povray.org>
> for smoke?
With smoke, it could be used to make a "swirly" effect depending on a
pattern, or you could just use it to turbulate the particles a bit. Or
you could use it as "wind", and fake the wind currents near objects and
the ground.
Date: 23 Jun 2000 16:09:02
Message: <3953C4B8.7C2B34B@aol.com>
Hmm, sounds interesting. Might have to try that sometime.
~Sam
> > for smoke?
> the ground.
