POV-Ray : Newsgroups : povray.binaries.images : Fun with eval_pattern (vincent.jpg 119kb) Server Time
15 Jun 2026 06:18:14 EDT (-0400)
  Fun with eval_pattern (vincent.jpg 119kb) (Message 11 to 11 of 11)
Subject: Re: Fun with eval_pattern (vincent.jpg 119kb)
Date: 9 Jun 2000 18:56:40
Message: <394176C7.BA341114@aol.com>
That's pretty wacky. I've found that using the crackle and granite pigments gives
interesting results. Also, you can find almost any image you want on the internet.
Christoph Hormann wrote:
> I just tried the same myself (I hope you do not mind me using your idea
> ;-) and was quite impressed by the amount of possibilities in just very
> few lines of code.
> The only difficulty is to find an adequate image_map/pattern...
> This one reminds me of domino-stones.
> Christoph
> SamuelT wrote:
> > I placed the cylinders in a 2-dimensional array with #while loops. Each
> > cylinder is rotated in the z-axis according to the value of the color it
> > landed on. For example, if the value of the color is zero, then it rotated 0
> > degrees. If the color had a value of one, the cylinder rotated 180 degrees.
> > There are no absolute blacks or whites in this image, though. Each cylinder
> > was given the color tested for that point in space. There are about 19,200
> > objects in all.
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
