POV-Ray : Newsgroups : povray.binaries.images : Diamond ring Server Time
18 May 2026 14:16:54 EDT (-0400)
  Diamond ring (Message 1 to 10 of 19)
Subject: Diamond ring
Date: 31 May 2000 03:54:24
Message: <3934C436.59597EF6@dod.no>
A girl would love to get this... alas, the diamond is too bright, and I
don't understand why. :-(
  +47 90 62 71 78          DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
  azo### [at] dodno, Ducati M600              Ubesudlet: Aldri eid en J&%#PS.
Download 'ring.png' (58 KB)
Preview of image 'ring.png'
Subject: Re: Diamond ring
Date: 31 May 2000 06:09:40
Message: <3933963C.543AAFE0@earthlink.net>
it looks as though it is on fire, glowing, lit intensively from above or all
of the above...
Date: 31 May 2000 11:42:12
Message: <slrn8ja3tv.30o.sjlen@zero-pps.localdomain>
The diamond looks way too bright.
  2:00pm  up 13:31,  2 users,  load average: 2.05, 2.09, 2.08
Date: 31 May 2000 13:44:30
Message: <39354f7e@news.povray.org>
Hey, maybe that is what a diamond looks like to a girl.
Date: 31 May 2000 20:19:12
Message: <3935ac00@news.povray.org>
Usually 'ignore_photons' is used within a glass (or similar) objects photon statement.
That's what appears to be wrong here.
Date: 31 May 2000 23:11:58
Message: <3935d47e@news.povray.org>
The diamond looks like a light source itself!
Date: 1 Jun 2000 11:16:47
Message: <39367E59.780F3E3A@hotmail.com>
Nice ring.
But the surface seems a little bit uneven.
Is it made of "white" gold ?
The source for the diamond I posted to
povray.binary.scene-files has several light
sources strung up inside the diamond shape.
So if that is the code you are using, then just
use Diamond instead of LitDiamond.
Or just decrease the 0.15 number in the DimLight
declaration to make the lights dimmer.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 4 Jun 2000 15:01:08
Message: <393AA77B.25263E31@kyrre.net>
statement.
Diamonds become white in pov for some reason, regardless of photons. The
attached image uses no photons, only difference is max trace: 15 for the
left one and 4 on the right. Any idea why?
    pigment {color rgb <.81,.88,.97> filter .94 }
    interior {
         ior 2.417
         fade_power 1000 fade_distance 15
    finish { reflection_min .03 reflection_max .5 reflection_falloff 1 }
sig
ICQ 74734588
Download 'cut1.jpg' (11 KB)
Preview of image 'cut1.jpg'
Date: 4 Jun 2000 16:43:48
Message: <nnfljsk5irulssr3p8tasvserfbg6m17tm@4ax.com>
On Sun, 04 Jun 2000 21:01:15 +0200, Sigmund Kyrre Aas
Any ray that exceeds the max_trace_level is given the background color
which is black by default (but you can change it, of course).
Peter Popov ICQ : 15002700
Date: 4 Jun 2000 17:05:06
Message: <393AB1D3.D13C3152@kyrre.net>
Background is black, diamond becomes white as max trace level increases.
ICQ 74734588
