POV-Ray : Newsgroups : povray.binaries.images : Pre-POV 3.5 Candle lit scene [~48KB Jpg] Server Time
15 Jun 2026 07:07:00 EDT (-0400)
  Pre-POV 3.5 Candle lit scene [~48KB Jpg] (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Pre-POV 3.5 Candle lit scene [~48KB Jpg]
Date: 24 May 2000 03:59:15
Message: <392b8bd3@news.povray.org>
"Sigmund Kyrre Aas" <as### [at] studntnuno> wrote in message
news:392B7830.CB90A039@stud.ntnu.no...
| Very nice. I'm curious about your mirror finish: it seems to dissipate
light
| around the candles.
I was happy the way that turned out, thanks.  I wanted it to do that but
it was still guesswork.  So what I did was to use a non-black pigment
and diffuse >0 plus a specular highlight but I really couldn't say what
caused it most.  There was no need to make any adjustment.
| If I was to criticize; the shadows look a bit bright and the candle
lights
| have somewhat sharp edges.
Criticize all you want.  There is a shadowless light having the color of
the candle light except dimmer, maybe not dim enough.  Keep in mind
there is also Moonlight coming in at a shallow angle from the right side
too, however I couldn't say for certain whether all this light is the
cause for lack of darker shadows rather than ambient in the table and
room.  I suspect it's a combination.
About the sharpness of the candle flames, don't get me started on that.
Do you realize how long I tweaked on just those flames?!  ;-)  Seriously
though, I doubt I could change them much without finding myself with
very different and unwanted flames.  But good to hear your opinion.
Date: 24 May 2000 04:05:52
Message: <392b8d60@news.povray.org>
"Alan Kong" <ako### [at] povrayNO-SPAMorg> wrote in message
news:e32nis41raknq86up35p75ev30afi8e1q7@4ax.com...
|   Nice image, Bob. Did you put a normal on that table top? Looks good
| that way.
Thanks, it's pretty simple, turbulent wood pigment + normal.
|   I would have expected a little bit more light reflected onto the
table
| from the mirror and candles due to photons but maybe it has to do with
| the angle of the mirror or the relative brightness of the table.
Well, you noticed the worst part about this thing.  Metallic objects
refused to show photon caustics.
Actually I had the spiral patterned disc at center showing a shininess
onto the table at upper right side during one point in the early stages
of rendering this.  I also had brighter candle holders too but no
photons reflecting off of them at the same time as that.  It has me a
bit perplexed to say the least.  Par for the course as usual.
Date: 24 May 2000 04:32:41
Message: <392b93a9@news.povray.org>
Glad you got inspired by my humble attempts!
I like your candles. How did you make the flames?
Where does the shadow on top of the mirror's frame come from? Is it from the
Window?
For the dust: Yes, that's a good idea. I threw a little media in my scene
and I think it does what I was after, but being of the "fantasy-kind", I'll
probably make more dusty scenes :-) I'm just setting up povray to render my
scene again in high quality which will probably take about ten hours (the
rendering, not the setting up :-)). I'll post the result.
Marc-Hendrik
Date: 24 May 2000 04:35:58
Message: <392b946e@news.povray.org>
Bob Hughes schrieb in Nachricht <392b88dc@news.povray.org>...
>Hmm, you're right, slope texturing would be best.  Guess Marc-Hendrik
>doesn't use MegaPov though (yet!).
MH
Date: 24 May 2000 05:11:47
Message: <392b9cd3@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:392b93a9@news.povray.org...
Yep, it helps, believe me.
Scaled spherical media method 3 in MegaPov 0.5 using a double media
statement within single interior, that's pretty much it, less the
tweak-tweak-tweak part.
from the
| Window?
Yes, window pane border.  Which remained in place while I moved the Moon
around instead.  Try that in real life!
scene
I'll
render my
(the
As long as you haven't quit there's always hope. <g>  But you would
really be doing yourself a favor by doing some investigation into
M.P.0.5.  Like Samuel suggested the slope dependant texturing should be
perfect for applying a layer of dust texture over things.  Maybe
Tony[B], among others, has done that.
It can be tricky to understand the workings however.
Subject: Re: Pre-POV 3.5 Candle lit scene with soft glow PP [~48KB Jpg]
Date: 24 May 2000 20:59:57
Message: <392C7ACF.D6A15620@online.no>
I like the cover of the book. How did you make that ?
Nice moon detail. But where is the man ? :)
But I think the mirror frame could need some work.
(And maybe only one candle showing in the mirror
would be enough/better.)
Tor Olav
mailto:tor### [at] hotmailcom
Date: 25 May 2000 00:46:23
Message: <392cb01f@news.povray.org>
"Tor Olav Kristensen" <tto### [at] onlineno> wrote in message
news:392C7ACF.D6A15620@online.no...
That's a ridged multi-fractal, and a pretty lame excuse for one at that.
My first try at it.  Actually there are 2 of them there to make it
fancier.  Same, except the top part is scaled to be thin.
 Ignore the Moon surface.  It's only a 'spotted' pigment pattern there.
Yep, I won't argue over that.  In fact, notice how the mirror is
symbolic of a moon itself and the candles align at the wicks in both
reflection and otherwise?  I over-composed, didn't I?  :-)
Date: 28 May 2000 21:13:18
Message: <slrn8j3cnv.9to.sjlen@zero-pps.localdomain>
Hmmm.  Beautiful, the colouring of the candle flames is great,
but seems to get a bit flattened as reflected by the mirror.
The moon is very good.  I always like seeing your work.
What's that black thing on the table?
 10:22pm  up 3 days,  9:16,  1 user,  load average: 2.26, 2.12, 2.04
Date: 28 May 2000 21:13:19
Message: <slrn8j3dbp.9to.sjlen@zero-pps.localdomain>
The candel on the right seems to be leaning over in thes second
image. And I still don't know what the back thing is.
Date: 29 May 2000 01:57:30
Message: <393206ca@news.povray.org>
"Steve" <sjl### [at] ndirectcouk> wrote in message
news:slr### [at] zero-ppslocaldomain...
I was just about to reply to your other reply  ;-)
That "thing" is just that, a thing of unknown meaning etc.  It was actually the first
thing I did in this scene, using a image and bump map for the spiral (can't really
tell,
I know...) on the top of it.  Unfortunately I keep thinking it's a ladies compact (?)
for makeup application and all because of the mirror there.  Well, it's not.  Nothing
inside :-)
Glad you like it and anything else I might have done.
To answer about the leaning candle from your other posted reply well it's perspective
camera with angle of 50 (around 67 tends to be about like direction 1 old style
syntax).
I often use 30 to 25 or even less to keep circles and lines from distorting.  Reason I
don't sometimes is because people always seem to like the wide angle perspective
camera.
It's another one of those personal preferences that exists bountifully in this medium
of
3D rendering we do.
I had to go back and look again to see about the flat flame.  Seems so like you say.
However it must be the turbulence of the media used, since the mirror is perfectly,
er,
flat.
Now you have me wondering if the angle of the mirror would make things flatter or not
:-)  Doubtful.
