POV-Ray : Newsgroups : povray.binaries.images : Crown of diamond (50KB) Server Time
6 May 2026 08:33:27 EDT (-0400)
  Crown of diamond (50KB) (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Crown of diamond (50KB)
Date: 29 May 2000 07:05:12
Message: <39324EAC.5A5ECB87@kyrre.net>
Steve wrote:
> I've started to render this, but can't get any photon effects.
> If someone could alter the code and add the photons and repost
> the code in p.b.sf or p.t.sf I'd be glad to render it.
Try scale 3 on the diamond. Photons seems to dislike small objects.
In addition I have this:
global_settings {
    photons { count 10000 autostop 0 max_trace_level 50}
    max_trace_level 55
Variable reflection looks good, but is much slower than regular reflection.
I've also abandoned dispersion and attenuation. i.e. not much fun left :/
sig
ICQ 74734588
Date: 29 May 2000 07:05:15
Message: <39324EF6.DF6CC853@kyrre.net>
> Uhm, I'm not sure if I should tell you this, but my PIII 650 Mhz took 24
> minutes to render ed this image...
what causing the hole. I guess it should have a flat tip since Tor Olav
obviously has done good research on this.
The dispersed light has a strange dirty look. Not sure I can see photons
either.. I guess an ior of 2.4 spreads light a lot so you may want to place
the diamonds closer to the floor.
Just noticed: this scene uses fade_power 1000; that is to turn on a new
attenuation formula in MegaPov. Official Pov should use sub 2 fade_power.
I'm surprised of the speed. I made a triangle mesh for my diamond because I
thought csg would be slow.
sig
ICQ 74734588
Date: 29 May 2000 07:50:02
Message: <slrn8j4crr.anl.sjlen@zero-pps.localdomain>
Now that one does look good.
  9:29am  up 3 days, 20:23,  1 user,  load average: 2.00, 2.00, 2.00
Date: 29 May 2000 22:44:18
Message: <39332047.BFE121B2@hotmail.com>
> I does not look like it is an ideal cut. It seems like there is a "hole"
> in the culet of the diamond. This hole should not be there.
My understanding is that the small facet at the
bottom of the diamond is called the culet.
There seems to be many opinions about what is the
best cut for a brilliant diamond.
I now think that I made the culet a little too big.
To make the culet facet smaller one would have to
increase the 8.2 value a bit in the plane { -y, 8.2 }
statement in the Brilliant declaration.
To remove the culet facet, just delete this plane
statement.
If the culet is made smaller or removed, then the
-8.3 value in the bounded_by statement in should
be lowered (more negative).
When I made this diamond shape, I spent much time
searching the internet for information about the
geometry of diamonds.
I found most of the data I needed, but there were
some data I could not find back then.
Therefore I'm not yet sure if all the facets are
"right".
> See attached
> image. I played with photons and dispersionsettings until I was happy.
> What do you think?
Thank you for rendering it with photons.
Now I'm sure that I like Photons very much !
I especially like the "fire" that appears
within the diamonds in your rendering.
I'm curious about how the code looks now.
Could you please post the code with your
modifications for Photons ?
I read that Sigmund suggests placing the
diamond closer to the floor to see the
Photons.
Maybe it would then be wise to lower the
reflection value for the blue "ground"
plane so that the reflected diamond image
does not destroy the caustics.
No, no, no, you shouldn't have told me that !
Tor Olav
mailto:tor### [at] hotmailcom
Date: 29 May 2000 22:50:01
Message: <393321A1.5159BA66@hotmail.com>
Well, thanks for trying anyway.
I hope Sigmund will post his "Photon" modifications to my code.
Tor Olav
Date: 29 May 2000 22:57:17
Message: <39332357.DF697AD8@hotmail.com>
Sigmund Kyrre Aas wrote:
... snip 8< ....
I didn't know that. I was a little in doubt about that high number.
And I see now from the POV documentation that it was way to high for
an official POV-Ray rendering.
Thank you for clarifying.
... snip 8< ....
Tor Olav
Subject: Re: Crown of diamond [150kb]
Date: 30 May 2000 16:06:44
Message: <39341E56.33456085@dod.no>
Yes, you're right. I didn't study the drawings and descriptions closely
enough.
I does look like it is a little bigger than it is supposed to be, yes.
Also, a brilliant cut diamond is supposed to have 58 facets, and not 74
facets as in your diamond?
Your welcome, I've traced a new version with radiosity and a little
different settings.
The fire is caused by a dispersion setting of 0.75 in the interior
statement.
But of course.
There are some caustics visible with the current settings. Have a look
at the attached image.
  +47 90 62 71 78          DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
  azo### [at] dodno, Ducati M600              Ubesudlet: Aldri eid en J&%#PS.
Download 'crown_of_diamond_smooth_large.png' (146 KB)
Preview of image 'crown_of_diamond_smooth_large.png'
Date: 30 May 2000 16:11:03
Message: <39341F60.D8060BF5@dod.no>
Yes, I was wrong, he is right ... the tip should be flat, but it is
exaggerated in the model.
I belive that the dirty looks comes from the pigment settings of the
diamond texture. I tried to set it to rgbf <1.0, 1.0, 1.0, 0.95> to see
if it improved things, but I will not know before another ... ohh, 20
hours or so. :-) If I bother to trace the image.
Well, the quality settings weren't that good. The last image I traced,
the one with radiosity, took about 22 hours.
Date: 31 May 2000 21:29:22
Message: <3935bc72@news.povray.org>
Oh!  Wow!
Date: 1 Jun 2000 11:24:53
Message: <3936803C.11BA1A74@hotmail.com>
In my shape there are 16 small facets that make
up the girdle line.
I don't think that these usually are counted
in the total.
To get a diamond without these facets, then
just remove these two lines from the Brilliant
declaration in the source code:
MCircleSpread(plane { y, 0 rotate  -90*z }, 6.20, FacetSides, 1/4)
MCircleSpread(plane { y, 0 rotate  -90*z }, 6.20, FacetSides, 3/4)
(Also increase the 6.20 number in the bounded
by statement.)
> different settings.
It looks less noisy now.
Thank you for this too.
> But of course.
Thanks.
I'm looking at it now trying to figure out what
is happening.
Tor Olav
