POV-Ray : Newsgroups : povray.binaries.images : Rad. not Rad. Server Time
29 Dec 2025 21:10:15 EST (-0500)
  Rad. not Rad. (Message 1 to 10 of 11)
Subject: Rad. not Rad.
Date: 18 May 2000 00:20:04
Message: <392220B4.A9F94FD1@earthlink.net>
These two images illustrate the default settings for radiosity in the:
#1 Official
#2 My Mega compile w/ Official GUI
Personally i like the way the official came out and the way it
calculated extra light in small areas due to more inner reflection i
guess... ( the lighter blue in the cuts and crevices ) The mega looks
exactly the same as if i did not use rad. =(
Download 'blomb.o.jpg' (5 KB) Download 'blomb.jpg' (5 KB)
Preview of image 'blomb.o.jpg'
Preview of image 'blomb.jpg'
Subject: Re: Rad. not Rad.
Date: 18 May 2000 00:31:10
Message: <3923720e@news.povray.org>
Moon47 <rdm### [at] earthlinknet> wrote ...
> #1 Official
In defense of MegaPov, I have to say that it produced the more realistic
image.  I would not expect much light to be coming from diffuse interaction,
since there are no objects surrounding the object to provide diffuse
reflection of light, and the object won't reflect much light back on itself.
The official version has a tendancy to greatly exaggerate diffuse
interaction in scenes where a black background is used.  Thus, you could
probably multiply the radiosity "brightness" by 10 in MegaPov to achieve a
similar effect.
-Nathan
Date: 18 May 2000 03:18:11
Message: <39239933@news.povray.org>
In article <392220B4.A9F94FD1@earthlink.net> , Moon47 <rdm### [at] earthlinknet>
> #1 Official
What did you do to turn on radiosity? Did you add a radiosity block to
POV-Ray or did you just use the Render Settings switch?  Only with the
radiosity block in the scene it should turn on, and the switch is useless
with MegaPOV, if I remember it correctly...
     Thorsten
e-mail: tho### [at] trfde
Date: 18 May 2000 04:41:43
Message: <3923ACB9.34453FE1@umh.ac.be>
I did some mistake with megapov, in the beginnig, I used
radiosity block but without ini_option "+QR" so you see
the mosaique but no radiosity were calculated. Check to
see if Megapov really calculate radiosity.
Fabian.
> #1 Official
>  [Image]  [Image]
Date: 18 May 2000 14:08:32
Message: <3924332C.C18898C9@unforgettable.com>
> > #1 Official
If I'm not mistaken the way it works is this: without the block, the
switch won't turn radiosity on, but with it, it will turn it off.
Xplo Eristotle
http://start.at/xplosion/
Date: 18 May 2000 15:59:45
Message: <3922FCF7.3232A202@earthlink.net>
I used both the switch and the default global_settings { radiosity {} } to
turn the affects on then turned both off and the bottom image was the result
for both in MegPov. The official also added to the surface normal/texture to
give it more of a tarnished or dirty look this is what i was after...
> > #1 Official
>      Thorsten
Date: 18 May 2000 16:04:06
Message: <3922FDFB.AA69D57F@earthlink.net>
No offense to MegaPov meant i am glad to have all the new features especially
the functions and the media method...
I simply like the exaggerated affects the official radiosity produced... It
made for more of an interesting affect in my opinion...
> > #1 Official
> similar effect.
> -Nathan
Date: 18 May 2000 16:09:49
Message: <3922FF4F.E8966C2F@earthlink.net>
How do i check to see if radiosity was calculated...?
Yes i see the "mosaique" (splng?) and get the .rca file before the final
render...
It works in other scenes just not the way i am accustomed...
> Fabian.
> > #1 Official
> >  [Image]  [Image]
Date: 18 May 2000 16:32:30
Message: <1eaubzg.1o5lf5y9xsk14N%smellenbergh@skynet.be>
Simply turning on radiosity can be done in two ways:
either put in the global settings:
  ini_option "+QR"
or turn on the switch near the quality popup (official or unofficial GUI
Macintosh versions)
Further settings are done in the radiosity block.
Smellenbergh
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Date: 18 May 2000 20:49:34
Message: <39249128.DAF823BB@unforgettable.com>
Increasing the brightness in your radiosity block, as Nathan suggested,
will produce this exaggerated effect.
Xplo Eristotle
"And then one day you find ten years have got behind you
No one told you when to run, you missed the starting gun"
    -Pink Floyd
