POV-Ray : Newsgroups : povray.binaries.images : Outrun! Or the little hovercraft that could (not?) [~24KB Jpeg] Server Time
29 Jun 2026 21:20:44 EDT (-0400)
  Outrun! Or the little hovercraft that could (not?) [~24KB Jpeg] (Message 1 to 8 of 8)
Subject: Outrun! Or the little hovercraft that could (not?) [~24KB Jpeg]
Date: 12 May 2000 11:06:34
Message: <391c1dfa@news.povray.org>
Thought I'd try once again to render a still image of my Martian Dust Storm
animation after tweaking on the media some more.  Only a one hour render
here but it got too boring for me to keep seeing what I wasn't happy with
over and over.  So this may be final unless I stumble into a better "dust".
I could paint this up better in a epaint program I think  :-)
Btw, I've also redone the animation and removed the other ones:
http://members.aol.com/persistenceofv/mdc_pan1.mpg  [629KB Mpeg]
omniVerse http://users.aol.com/persistenceofv/all.htm
Download 'mdc159.jpg' (18 KB)
Preview of image 'mdc159.jpg'
Subject: Re: Outrun! Or the little hovercraft that could (not?) [~24KB Jpeg]
Date: 12 May 2000 12:07:42
Message: <391C2D18.50280EB@osu.edu>
the only problem i see with the dust is that the boundaries are much too
prominant.
Date: 12 May 2000 12:21:01
Message: <391c2f6d@news.povray.org>
Yep, need a blob pattern like MegaPov has except for using with media.
If that can be done already I'm missing out then.  Maybe I should check on
that.
"Ross Litscher" <lit### [at] osuedu> wrote in message news:391### [at] osuedu...
| prominant.
Date: 12 May 2000 16:34:59
Message: <chrishuff_99-9A0D0E.15382312052000@news.povray.org>
In article <391c2f6d@news.povray.org>, "Bob Hughes"
> check on that.
The blob pattern and blob pigment were originally intended for use with
media...and they are still most useful as media densities.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 12 May 2000 17:28:31
Message: <391c777f@news.povray.org>
I knew I should have paid more attention to it the first time I heard of it.
Thing is that I was seeing it as a new pigment pattern specifically for blobs
and not for anything else like media.
Thanks so much for clarifying that.  I read about it in the documentation
and overlooked the media I guess, thinking it was all about pigment or texture
being applied to follow blobs better.
Now I'm going to have to dig into something I don't know and redo this thing
yet again.
You still have my thanks though.
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-9A0D0E.15382312052000@news.povray.org...
| > check on that.
| TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
| TAG Web page: http://tag.povray.org/
Date: 12 May 2000 17:53:52
Message: <chrishuff_99-EEE67D.16571712052000@news.povray.org>
In article <391c777f@news.povray.org>, "Bob Hughes"
> of it. Thing is that I was seeing it as a new pigment pattern
> specifically for blobs and not for anything else like media.
> documentation and overlooked the media I guess, thinking it was all
> about pigment or texture being applied to follow blobs better.
Actually, I doubt it would be very useful for blobs...at least, not when
using the same blob components as the blob object. The current texture
blending works just as well, and you would have to go to special effort
to make sure the pattern lined up properly.
I posted a couple media "fire worm" images here when I was developing
it, you might look at those. Another thing it is useful for is as an
isosurface pigment function, which is especially interesting when used
with turbulence.
Date: 12 May 2000 18:01:03
Message: <391c7f1f@news.povray.org>
news:chrishuff_99-EEE67D.16571712052000@news.povray.org...
Oh well, worth a try to see what all it can do anyhow.
And yep, I remember the examples of that now.  Thought all that was
something to do with particle-making instead.
As a isosurface that could get interesting for sure, although I could probably
forget about animation if both isosurface and media were used.  For now anyway.
| with turbulence.
Date: 13 May 2000 08:33:34
Message: <chrishuff_99-B08069.07365913052000@news.povray.org>
In article <391c7f1f@news.povray.org>, "Bob Hughes"
Well, that was one of the uses I was thinking of, using blob components
in the pattern to represent particles and using the whole thing in a
media density.
> probably forget about animation if both isosurface and media were
The isosurfaces using this pattern were actually fairly fast rendering,
especially when compared to some other patterns. It is one of the few
patterns that works fine as-is instead of mostly being useful as a
displacement pattern. Still, with media, even with method 2 or 3...I
guess it depends on the size of your animation.
