POV-Ray : Newsgroups : povray.binaries.images : Facehugger 2 (47kb) Server Time
15 Jun 2026 10:05:13 EDT (-0400)
  Facehugger 2 (47kb) (Message 11 to 14 of 14)
Subject: Re: Facehugger 2 (47kb)
Date: 10 May 2000 06:51:03
Message: <39193f17@news.povray.org>
"Peter Houston" <hou### [at] inamecom> wrote in message
news:39190fce@news.povray.org...
| > I really like the scene overall though.  Do you use the adaptive aa or
| just
| > more aa method 1?  Asking because of the jaggies in the diagonal lines.
| You've lost me here, I am just using the default aa settings, 0.3 I think.
My mistake.  I should have said recursive aa since both methods are actually
adaptive.
Well, I've found recursive aa, or +am2 as it's known on the command-line,
really helps smooth straight yet diagonal lines (any line running off of vertical
or horizontal).  And even if aa depth (+r5 for example) is raised while using +a0.1
with default sampling method (+am1) it can still tend to be unsmooth.
Your mileage may vary  ;-)  but my favorite settings still are +a0.2 +r2 +am2 for
average renders, and +a0.1 +r4 +am2 for finals if time permits.
Date: 10 May 2000 06:59:24
Message: <3919410c@news.povray.org>
Not large enough arrays then (number of sources(?), not size).
'adaptive' could be increased too.
Hmm, just realized now.  If those shadow bands are from one 'area_light'
then that would explain why also.  Very wide separations if so, and that
takes all the more sources in an array to circumvent the mottling when
'jitter' is used.
I had thought you used a large number of really small area lights in there
before.  Wondered why you weren't exaggerating those more to show
soft shadow lines  :-)
news:39191022@news.povray.org...
| Bill DeWitt  wrote >
| >     For some reason, this is starting to look like a charcoal drawing.
| Maybe
| > you need jitter on your area lights?
| I tried adding jitter but it looked like the whole scene was sprayed with
| black paint spots.
| Regards,
| Peter H.
Date: 10 May 2000 20:19:03
Message: <2lujhs091fbls4oh9b4vppbftdat6ecilo@4ax.com>
On Wed, 10 May 2000 08:37:10 +0100 "Peter Houston"
<hou### [at] inamecom> wrote:
>I tried to get similar lighting as appear in the film Alien, the med lab in
>that is bright and the light source seems to be the entire ceiling.  If I
>put lights on the scanner I may try lighting the whole scene with just
>those.
  Hi, Peter. If you're using MegaPOV, you might try illuminating the
room with ceiling panels and radiosity. Warp made some nice demo images
last year using radiosity in UVPov (and MegaPOV?) where the room was lit
with an object.
  Keep in mind that in the movie "Alien" the director of photography and
cinematographer can use all sorts of lighting 'tricks' that are not
visible in the film frame. You might be able to use things like
shadowless lights, if that is your goal.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 22 May 2000 06:59:00
Message: <392912f4$1@news.povray.org>
Henry <htp### [at] maccom> wrote in message
news:htp-862CEB.23332509052000@news.povray.org...
> In article <3918082d@news.povray.org>, "Peter Houston"
> I'm also having trouble trying to visualise where the display is.  Is it
> located 20cm above the patient's head, or is it back about a metre?
> Regardless, it is in a location which would *always* get in the way.
> Why not relocate it to that curved bulkhead-type-thing-with-the-dial?
  You know, I didn't notice that untill you mentioned it, and all of the
sudden it looks like an Echer pic to me.  The thing it's mounted on *LOOKS*
to be above the patient, but the screen looks like it's 1 meter back.
