POV-Ray : Newsgroups : povray.binaries.images : blob question, 5k gif Server Time
29 Jun 2026 20:52:09 EDT (-0400)
  blob question, 5k gif (Message 1 to 6 of 6)
Subject: blob question, 5k gif
Date: 2 May 2000 15:22:33
Message: <390f2af9@news.povray.org>
Hi, i'm currectly trying to do some hand coding, especially blobby blobs. I
can get the general shape I want, but it has ribs in it. how can I go about
getting rid of these? I found negative strength to do what I want on the top
part, that was way cool, i like it a lot. Is there some way I can get rid of
those ribs though? the ones that are on the downward pertruding part of the
object.
by the way, this is not at all supposed to be a golf tee :) i'm serious, so
don't think so! you'll see when i'm done. i'm going to try to hand code an
entire scene so it might be next year when i'm finished.
anyway, thanks for the helparoo.
ross
Download 'blob2.gif' (5 KB)
Preview of image 'blob2.gif'
Subject: Re: blob question, 5k gif
Date: 2 May 2000 16:07:09
Message: <390f356d@news.povray.org>
It'd help to see the code. Beyond that, I'd suggest playing around with the
threshold a bit, or increasing the number of components between the
base-point and the top. Maybe run them through a loop. ie:
#declare YTran=0;
#declare Scaler=1;
blob {
 threshold 0.65
 #while (YTran <= 10)
  sphere {0,1,1
   scale Scaler
   translate YTran*y
  #declare YTran=YTran+0.25;
  #declare Scaler=Scaler+0.1;
 pigment {rgb <0.65,0.8,0.65>}
The more components you use, the smoother the transition.
David
Date: 2 May 2000 18:04:19
Message: <390f50e3@news.povray.org>
In doing such shapes I guess the old saying "nothing's ever easy"
would apply.
I wanted to check out what David H. has said here and came up with
the following:
#declare YTran=0;
#declare Scaler=<1,.5,1>;
blob {
 threshold .5
  sphere {0,1,1
   scale Scaler
   translate YTran*y
   *(pow(YTran, .5 / 1)*.5); // borrowed from clockmod.inc
  sphere {0,1,-2
   scale Scaler*<.6,.8,.6>
   translate YTran*y*1.25
  translate -6*x
// rotate a 2-D outline of points around the Y axis to create a 3-D shape
lathe {
  cubic_spline
  12, // number of points
   // the list of <u,v> points
  <0, 0>, // keep end closed
  <0, 0>,
  <.5, 1>,
  <1, 4>,
  <2, 7>,
  <4.5, 10.25>,
  <4, 11>,
  <3.25, 10.5>,
  <2.75, 10.33>,
  <2, 10>,
  <0, 10>,
  <0, 10> // keep end closed
  translate 6*x
#declare LCX = 0;
#declare LCY = 20;
#declare LCZ = -30;
light_source { <LCX,LCY,LCZ> color rgb <1.5,1.5,1.5>
camera{
  location  <LCX,LCY,LCZ>
  angle 40
  look_at   <0,7,0>
To make a long story short, I figured a lathe would be better suited
for doing this sort of object.  I could never get the negative strength
blob component to do what Ross had there already.
The lathe can be some trouble sometimes to get the curvatures
correct but it does seem the lesser of the two evils to me.
"David Heys" <sou### [at] gcinet> wrote in message news:390f356d@news.povray.org...
| #declare YTran=0;
| #declare Scaler=1;
| blob {
|  threshold 0.65
|   sphere {0,1,1
|    scale Scaler
|    translate YTran*y
|  #end
| David
Date: 2 May 2000 18:17:35
Message: <390f53ff$1@news.povray.org>
Thanks, i figured i'd add a normal, agate is what i tried, to see how it
interacts with real unwanted bumps. it makes things less noticeable atleast,
and for my purposes, adding a normal makes sense. in other cases, it might
not though.
I don't know anything about writting code for lathes, so i'm going to stick
to blobs. i might try using some componants that are scaled heavily in the y
(up/down) direction, or maybe a cylinder componant going all the way down
the middle to see if that smooths things some. i don't know anything about
cylinder componants either :) so we'll see.
thanks for the help,
ross
Bob Hughes wrote in message news:390f50e3@news.povray.org...
> would apply.
> the following:
::snip::
> Bob
Subject: Reworked Blob (12.2 KB b/u)
Date: 2 May 2000 19:50:53
Message: <390f69dd@news.povray.org>
k.o., I'll post the source in p.b.s.f.
It's not exact to your original, but it's close enough that you can tweak
and play with things to get what you need.
David
Download 'golftee.jpg' (13 KB)
Preview of image 'golftee.jpg'
Date: 5 May 2000 23:30:07
Message: <391242F4.1CAF4A2A@earthlink.net>
While loops work best.
With several components it looks better and gets slower...
Happy Blobing (,)(,)
