POV-Ray : Newsgroups : povray.binaries.images : Highlight/Midtone/Shadow post-process example (40 kbu) Server Time
18 May 2026 17:54:22 EDT (-0400)
  Highlight/Midtone/Shadow post-process example (40 kbu) (Message 1 to 7 of 7)
Subject: Highlight/Midtone/Shadow post-process example (40 kbu)
Date: 27 Apr 2000 13:05:54
Message: <390873DA.74AEAD43@inapg.inra.fr>
See my post in p.unofficial.patches.
Below is an example of a highlight/midtone/shadow post-processing (done
with Micrografx Picture Publisher, but I used to do that in Paintshop
Pro). The image on the left is the original (an image made with POV 1.0
in october 1993) and the other one is post-processed. Note that this is
different from increasing color saturation (which would make the dark
part redder, not darker).
G.
Download 'wolf.jpg' (39 KB)
Preview of image 'wolf.jpg'
Subject: Re: Highlight/Midtone/Shadow post-process example (40 kbu) (0/1)
Date: 28 Apr 2000 01:11:06
Message: <bxgJOUQlwRAZjNon5CpBS1iEe=yq@4ax.com>
On Thu, 27 Apr 2000 19:07:39 +0200, Gilles Tran <tra### [at] inapginrafr>
>with Micrografx Picture Publisher <SNIP>
What you seem to have done is to simply raise the contrast of the
image. In most image manipulation programs this would actually require
both an increase in contrast, and a general darkening of the image.
If this doesn't make sense to anyone, why you need to perform two
simple tasks to achieve one simple effect, I can explain. Most image
manipulation programs don't rotate the slope of the response curve
about it's midpoint, but rotate it around the 0 point. Looking at the
charts I attached to this post might explain what I mean by that.
I have attached my recreation of your effect. I have also included
pictures of curves that represent what I did to the tonal range of the
image, labeled "before" and "after." In keeping with my earlier
listing of formulas for such effects, here are the formulas used:
    Rout = (Rin*1.6)-0.3
    Gout = (Gin*1.6)-0.3
    Bout = (Bin*1.6)-0.3
My version looks pretty darn close to yours, and we would need to work
with a lossless image format to really get any closer. If you want to
post a PNG, I'll send back a PNG to match yours. Then we won't have to
worry about how much precision we might be losing through JPEG
compression.
If this sort of effect is what you want, it can be achieved with
"iso-functions" applied to tonal response.
Later,
Glen Berry
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Subject: Re: Highlight/Midtone/Shadow post-process example (40 kbu) (1/1)
Date: 28 Apr 2000 01:11:20
Message: <ch0JORPYWjYYlFtzgwGIDdIeBJwh@4ax.com>
Download 'wolf_gb.jpg' (23 KB) Download 'before.gif' (2 KB) Download 'after.gif' (2 KB)
Preview of image 'wolf_gb.jpg'
Preview of image 'before.gif'
Preview of image 'after.gif'
Date: 28 Apr 2000 01:19:27
Message: <uh4JOZkxX53qz9pX8wqZozQxykRN@4ax.com>
On Fri, 28 Apr 2000 01:11:13 -0400, Glen Berry <7no### [at] ezwvcom>
>wrote:
Oops. I think one of those GIF's didn't have its background color set
correctly. When I viewed my own post in a web browser, the legend of
one of the charts disappeared into the background. I'm sending out two
new GIF's that should be fixed this time.
Sorry,
Glen Berry
Download 'before.gif' (2 KB) Download 'after.gif' (3 KB)
Subject: Re: Highlight/Midtone/Shadow post-process example (40 kbu) (0/1) - GraphFunc.jpg (1/1)
Date: 28 Apr 2000 09:56:53
Message: <chrishuff_99-CE6CBE.08594628042000@news.povray.org>
In article <bxgJOUQlwRAZjNon5CpBS1iEe=yq@4ax.com>, Glen Berry
Hmm, so it could be done by using these two filters in order:
multiply {rgb 1.6}
add {rgb -0.3}
Hmm, I think a different but very similar effect could be done by using
a polynomial curve. Something like this would enhance either the lower
or the upper ranges, depending on val, and would be centered around 0.5:
for rgb values below 0.5:
R = 0.5*(abs(2*r-1)^val) + 0.5;
G = 0.5*(abs(2*g-1)^val) + 0.5;
B = 0.5*(abs(2*b-1)^val) + 0.5;
for rgb values above 0.5:
R = 0.5 - 0.5*(abs(2*r-1)^val);
G = 0.5 - 0.5*(abs(2*g-1)^val);
B = 0.5 - 0.5*(abs(2*b-1)^val);
This would give a smooth curve rather than a clipped linear effect. See
the attached image.
Nearly anything could be accomplished with isofunctions, I will have to
take a closer look at the source to see how to implement it.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Download 'GraphFunc.jpg' (11 KB)
Preview of image 'GraphFunc.jpg'
Date: 29 Apr 2000 06:07:19
Message: <I7IKOZJ7A2wTtHHioSX7sPQbSOTB@4ax.com>
Date: 29 Apr 2000 10:30:44
Message: <chrishuff_99-802F7F.09334929042000@news.povray.org>
