POV-Ray : Newsgroups : povray.binaries.images : Late Saturday Night Abstract (~73kau) Server Time
15 Jun 2026 15:12:02 EDT (-0400)
  Late Saturday Night Abstract (~73kau) (Message 21 to 21 of 21)
Subject: Re: Late Saturday Night Abstract (~73kau)
Date: 27 Apr 2000 08:03:48
Message: <39082C96.4C52DBAA@iname.com>
TonyB wrote:
> The emission is set at rgb 1/3. Mind you, if you're looking to get nice
> results, you'll have to use at least samples 15,15 and intervals 15 (at
> least I did, perhaps there is a better, lower setting).
	I got a decent result (the monitor I've got here is *very*
bad, so I can't be sure it's really good, but it didn't look
worse than yours) with the following settings:
samples 20,20 intervals 1 jitter 0.01 aa_level 7
aa_threshold 0.1
	Remember that:
* "samples s,s intervals i" is nearly equivalent to "samples
i*s, i*s intervals 1" except that it should render slightly
faster and give slightly better results
* the max number of samples in method 3 can be approximed
with samples^aa_level therefore increasing aa_level can do
wonders for the quality without increasing render time too
much (although in some cases it won't do any good)
* a slight jitter can sometimes help a lot
		Jerome
PS: when I seemed to imply that the pic looks bad, this is
only due to the screen I've got here, I've seen pics that
looked much worse here and were pretty good when viewed on a
decent monitor...
