POV-Ray : Newsgroups : povray.binaries.images : Tripods Again (81kb) Server Time
15 Jun 2026 14:53:57 EDT (-0400)
  Tripods Again (81kb) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Tripods Again (81kb)
Date: 12 Apr 2000 13:34:38
Message: <38F4B414.4B86609E@osu.edu>
one thing I'd like to comment on. I thinkt he tripods and the
explosions/ray are pretty good (although a death ray like the one that
glass elephant had a while back would look way cool), but the buildings
need work. They just look like plastic toys and it is really holding the
entire scene back.
Maybe, even if you keep these buildings the same, but change from day to
night lighting. throw in a couple street lights or something with a low
glow around them, but primarily have the explosions light the entire
scene.
just some ideas,
ross.
Date: 12 Apr 2000 16:19:38
Message: <38F38B68.95C50704@earthlink.net>
Not sure but look at the post by SamuelT. "Volumetric Non-Media..."
I thought it looked like a much better example of smoke or smog than clouds
and w/ a little effort... Who knows...
Just a few posts away...
I still like the old explosion better... It was original and looked more to be
what a death ray would cause... Like an atomic blast...???
Peter Houston wrote:
> Using v.05 of HE Days Real Explosion, I converted it to a macro, as this
> scene uses about 4 altogether.  This version is a definite improvement, it
> even renders faster :) this image took about 2/3 the time of the last one.
> I would still like to put some black smoke clouds in the background, I
> thought of using media in a column of hollow spheres or a blob, but I
> haven't had much experience with media and even less with MegaPOV media,  I
> would really appreciate the help.
> Or if anyone knows how to do it with textures or isosurfaces (I wish I
> understood them).
> Regards,
> Peter H.
Date: 12 Apr 2000 16:40:04
Message: <38F4D1E7.E8630602@aol.com>
Hey, wouldn't a heat ray just melt something. I mean, metal does not just blow
up from heat. Gas does, but not metal or concrete. So shouldn't the building
be, melting?
(hint hint)
"Yub-Yub!" Lt. Kettch
Date: 12 Apr 2000 16:49:37
Message: <c4o9fsgp6hh7bbdbqvo84917dbikfqtcv1@4ax.com>
On Wed, 12 Apr 2000 13:36:20 -0400, Ross Litscher <lit### [at] osuedu>
>entire scene back.
Guess what, that glass elephant's fire used H.E.Day's fire code
(though quite modified) :)
Peter Popov ICQ : 15002700
Date: 12 Apr 2000 18:07:24
Message: <lks9fsktnkr2f4aan1g29b0ndod1r1lc1e@4ax.com>
On Wed, 12 Apr 2000 11:43:36 -0800, "Lt. Kettch" <AKK### [at] aolcom>
>be, melting?
Depends on the amount of heat involved. If enough heat is transferred
to the building with sufficient speed, the whole of it will start
burning at once, and the gases released in the process will expand
rapidly, thus an explosion will take place. Like in Stephen Kings'
"Firebringer"
Date: 12 Apr 2000 19:46:42
Message: <38f50ae2$1@news.povray.org>
> "Firebringer"
    I am -not- a Steven King fan, but wasn't that "FireStarter"?
Date: 12 Apr 2000 19:54:46
Message: <38F50C31.E6708A0D@fci.net>
I suggest that you lower the diffuse on the explosion to < .25 .  Also,
lowering the "Detail" to < .01 .
This should increase the believability of the scene.
Keep 'em coming!
H.E. Day
Date: 12 Apr 2000 23:14:12
Message: <38F53B27.6B9D3343@faricy.net>
It is better than the last explosion, but I agree with Ross about the
buildings.
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 13 Apr 2000 06:28:00
Message: <s78bfss5lbk80akn0dekrgng2r07k6gv9c@4ax.com>
On Wed, 12 Apr 2000 19:44:56 -0400, "Bill DeWitt"
>> "Firebringer"
You're probably right, I've only read it in Bulgarian, and the title
they gave it was "The Living Torch". Gee...
Date: 17 Apr 2000 12:23:15
Message: <benboomREMOVE_THIS_PART-DACEBE.09200317042000@news.povray.org>
In article <38f44a5b@news.povray.org>, "Peter Houston"
> it
> one.
> I
Actually, I preferred the last version's explosion. Hey, what do I know?
