POV-Ray : Newsgroups : povray.binaries.images : Hands Server Time
6 May 2026 20:40:13 EDT (-0400)
  Hands (Message 41 to 42 of 42)
Subject: Re: Patch Request? was Re: Hands
Date: 17 Apr 2000 13:13:03
Message: <slrn8fmevq.7ep.sjlen@zero-pps.localdomain>
On Sat, 15 Apr 2000 12:09:08 -0500, Chris Huff wrote:
>Sorry, but I don't think this is possible...at least, not with the type
>of blob POV uses(are there other kinds that would make this possible?).
>A blob object is just an isosurface, all points where the sum of the
>field of all of the components is equal to a certain threshold value. I
>don't think it is possible to exclude components based on the "branch"
>they are in.
How about adding a threshold identifier so that you could specify which
object another will blob with, and if you specify two in the same object
it will blob with the other two within the block that have the same
identifiers eg:
blob {
      ThresholdIdentInit{FRED,JIM} //Initialises the Threshold Identifiers
      sphere{<0,0,0>, 0.7, 0.8
             ThresholdIdent{FRED}
      sphere{<0,0.5,0>,0.7 ,0.8
             ThresholdIdent {FRED,JIM}
      sphere{<0.5,0.5,0>,0.7 ,0.7
             ThresholdIdent {JIM}
      sphere{<0.5,0.5,0.5>,0.7 0.6
             ThresholdIdent {JIM,FRED} // the order shouldn't make a difference.
     }  // End of blob.
If a component doesn't have a ThresholdIdent it acts as normal and if a blob
doesn't have a ThresholdIdentInit at the beginning then the blob acts as
normal.
My logical thinking says that this should be possible but I've never looked
at the pov code and I'm not much of a programmer so the rest is up to the
experts.
  4:07pm  up 13 days, 18:42,  4 users,  load average: 1.25, 1.07, 1.02
Date: 17 Apr 2000 21:52:57
Message: <chrishuff_99-701749.20554417042000@news.povray.org>
In article <slr### [at] zero-ppslocaldomain>,
> identifiers eg:
> blob {...}
> a blob doesn't have a ThresholdIdentInit at the beginning then the
> blob acts as normal.
> looked at the pov code and I'm not much of a programmer so the rest
> is up to the experts.
I don't think this would be any different from having multiple blob
objects with some identical components. And I don't understand your
reasoning in calling it a "threshold identifier", since it doesn't seem
to have anything to do with the threshold...a possible sign that I
completely misunderstood what you were trying to say. :-(
And anyway, you still have the problem of determining which set of blob
components to use. The components are not blobbed together one by one
and the results rendered, their contributions to a point are added
together and the equation solved for each ray. How do you decide which
components to use in the solving process when you have a ray, or even a
point, as the starting information?
The only way I can see something like this being possible is by making a
new type of blobby object which takes components that are turned into a
mesh, and blobbed together one by one in a tree structure. Then the mesh
object would be rendered...of course, this has all the problems of
tesselating into triangles(probably even harder because of the specific
order the components would be combined in).
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
