POV-Ray : Newsgroups : povray.binaries.images : Home page (64kbu) (not an advertisment !) Server Time
6 May 2026 17:40:46 EDT (-0400)
  Home page (64kbu) (not an advertisment !) (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Home page (64kbu) (not an advertisment !)
Date: 3 Apr 2000 17:26:23
Message: <38e90c7f@news.povray.org>
38E8B0D4.602C1475@netvision.net.il...
> Neat
Thanks
> how about changing the background color? Try very light wood, or just
> plain white, with area lights producing soft shadows of the objects
Tried that (wood)... but the file is much heavier (135k in plain res.)
> (make a scene with a high-diffuse white plane behind each object and
> render, then cut each object with its shadow, and in the HTML document
> put the pics and make the background white).
That's nearly what I'm doing :-)
> How about english?
Well... My actual page is french and english... but it is such a job to do updates
correctly...
Maybe later...
FD
Date: 3 Apr 2000 17:27:28
Message: <38e90cc0@news.povray.org>
38E8C8BA.5522DD05@online.no...
> I like your background and the "hand-written" font beside the knobs.
Thanks.
[Snip]
> Maybe your page will improve if you reduce the number of
> font variations(?)
Done.. just 2 fonts now..
> And it's also wise to choose fonts that "fits" each other.
> (I'm not sure if all of the fonts on your page are "in harmony"
> with each other.)
Ouch... I don't know. I'm just using Kristy and Arial...
FD
Date: 3 Apr 2000 17:27:30
Message: <38e90cc2@news.povray.org>
a$R9iFAqXN64Ew4S@econym.demon.co.uk...
> Wasn't it Freddy D. who wrote:
> >- the background just contains bar-title and left and right plates...
> But doesn't that mean that if someone chooses to ignore your advice to
> set their screen to 800 x 600, the relative positions of everything goes
> haywire? Or if they open their "favourites" or "history" panel. Or use
> an obscure browser such as Fresco. Or use WebTV. Or print the page out
> with "print background" enabled.
Yes... I'm not that good in html... :-(
.. but I am doing some changes, so I will try... :-)
> An additional advantage to removing foreground objects from the
> background is that you might be able to re-use some of the components on
> other pages, and significantly reduce the amount of graphic reloading
> when changing page.
Yes. but I have only 2 big pics : title pic and the background. These two are loaded
by the browser and re-used for each page if necessary, no ???
FD
Date: 3 Apr 2000 17:27:47
Message: <38e90cd3@news.povray.org>
slr### [at] zero-ppslocaldomain...
> Looks good, now I've got ideas of making pov buttons for my
> site, no I can't do it, it'll make loading a lot slower.
Thanks...
The buttons are 4700 to 5100 bytes heavy in jpg...
FD
Date: 4 Apr 2000 00:55:52
Message: <38E975F8.BB08D786@hotmail.com>
What mail/news prog are U using and how do U get to do that
Date: 4 Apr 2000 13:12:44
Message: <4b71LTABwZ64Ewf$@econym.demon.co.uk>
>> when changing page.
>loaded
Well, yes, but only if you manage to write the text and other contents
of each page so that they are the same length. I find it useful to have
some pages that have significantly more content than others. If you use
the same fixed length background on a longer page then the text would
start to write across the top of a second copy of the background tile.
Mike Williams
Gentleman of Leisure
Date: 4 Apr 2000 17:37:56
Message: <0F=qOGB=aJS9wBCl3D8nFYfGFemm@4ax.com>
On Tue, 4 Apr 2000 08:38:41 +0100, Mike Williams <mik### [at] nospamplease>
Why?
<BODY STYLE="background-image: url('image.gif'); background-repeat:
no-repeat;">
Peter Popov ICQ : 15002700
Date: 4 Apr 2000 18:45:56
Message: <38ea70a4@news.povray.org>
4b71LTABwZ64Ewf$@econym.demon.co.uk...
Yes... I've done a (really good) background that just can repeat itself...
I've even tried to put my browser in 1024*768 and it works...
Maybe you can see by yourself ;-)
http://www.profd.com/index-new.htm
.. and thank you for tips...
FD
Date: 5 Apr 2000 01:02:40
Message: <aOYt+DAPWs64EwLn@econym.demon.co.uk>
Well, yes, putting your text in a separate frame on plain white
background is *one* solution. It's a bit of a drastic change from what
you originally posted here.
I've put an example of what I was thinking of at
  http://www.econym.demon.co.uk/profd/
(Or there will be an example there, as soon as the web server refreshes
it. It shouldn't take long.)
Notice that this looks quite like what you originally posted (except I
had to use one of my own tiles in the background because I couldn't
extract a tileable one from your original image) but the various
components automatically adjust to sensible positions when the size of
the screen changes. Try un-maximising your browser window and adjusting
the size. Everything stays in the same relative position and things only
go wrong when the window is smaller than the width of the title image.
If there were more text, the bottom graphics would move down in the same
way.
It's all done with tables, rather than frames.
Mike Williams
Date: 5 Apr 2000 14:26:54
Message: <38eb856e@news.povray.org>
aOYt+DAP### [at] econymdemoncouk...
It is now gray.. Gray70 exactly...
Yes.. been there.. (it's very surprising to see my stuff on an other server.. :-))
But I've seen that the background was overwhelming all the page (it's too grey or
strange or..)
A plain gray is imho suffisant...
Yes yes... I haven't use a tile for the background, just plain pov-ray, normal with
bumps, and 6 light_sources..
> but the various
> way.
Done that.. cool !.. Why am I unable to do this simple thing ?...
I've noticed that pictures don't exactly touch the edge of screen... I want that...
Why should people tell me that frames are bad ?... :-))
btw : last version of home page is uploaded, with extra stuff
(I'll post a screen-shot later here if you or someone are interested...)
.. and thanks a lot !...
> Mike Williams
FD aka Freddy D. aka Prof D.
Pro### [at] wanadoofr
http://profd.est-ici.org
