POV-Ray : Newsgroups : povray.binaries.images : Infernal blasted image maps Server Time
18 Jul 2026 06:31:10 EDT (-0400)
  Infernal blasted image maps (Message 1 to 7 of 7)
Subject: Infernal blasted image maps
Date: 26 Mar 2000 22:01:26
Message: <38decf06@news.povray.org>
Dang! These things make no sense. I've got two images that I want to use
as rotoscopes as I tweak my blob character.
The image maps are violating the laws of physics. (using mega 0.4).
Why is one map unnaturally stretched? Yes, it's tall and thin, but why
isn't there an option in povray to get planar straight up mapping?
box{<0,0,0>,<1,1,0.001>
                pigment{
                        image_map{
                                tga "c:\My Documents\frontpos2.tga"
                                once
                finish {ambient 1 diffuse 0}
                translate <-0.5,-0.5,-0.05>
                scale 21
                translate -1.5*y  +3*z       -4*x
        box{<0,0,0>,<1.,1,0.001>
                pigment{
                        image_map{
                                tga "c:\My Documents\left2.tga"
                                once
                scale 14
                translate -17*x -1.5*y  +3*z
Download 'thebody11rebuild.jpg' (14 KB)
Preview of image 'thebody11rebuild.jpg'
Subject: Re: Infernal blasted image maps
Date: 26 Mar 2000 23:20:14
Message: <38dee17e@news.povray.org>
'image_map {map_type 0' is always going to be a POV Unit square.  Is that where
it's wrong?  Unless you have a square image to start with you'll need to scale
the image or object it's on proportionately to what you have to start with.
Preserving aspect ratio in other words.  So your only overlooking the obvious is
all.
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:38decf06@news.povray.org...
|                 pigment{
|                         image_map{
|                                 once
|                 scale 21
|                 pigment{
|                         image_map{
|                                 once
|                 scale 14
Date: 27 Mar 2000 07:50:06
Message: <38DF5802.32786C20@my-dejanews.com>
Nope. I once tried changing the size of the box to fit the aspect ratio of the
image, and still got something stupidly distorted.
Do we have to beg for a fix in mega 0.5, or isn't there SOME way to get pov to
'decal' this without crazy distortions?
> all.
> Bob
> |                 pigment{
> |                         image_map{
> |                                 once
> |                 scale 21
> |                 pigment{
> |                         image_map{
> |                                 once
> |                 scale 14
Date: 27 Mar 2000 09:10:43
Message: <38df6be3@news.povray.org>
Greg M. Johnson wrote in message <38DF5802.32786C20@my-dejanews.com>...
the
Did you change the size before or after applying the image
to
It's not a bug.
Please assume that img1.gif is 100*500 pixels.
box {
 <0,0,0>,<1,5,0.01>  // box starts with correct ratio
  image_map {
    gif "img1.gif"
  scale <1,5,1>  // scaling the pigment
The above code hasn't been tested, but I think it's right.
Gail
* gsh### [at] monotixcoza              * Reality.dat not found         *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* Document program code? Why do you think it's called code?        *
Date: 27 Mar 2000 09:20:21
Message: <38DF6D27.7E7FBD8E@my-dejanews.com>
My memory is a bit foggy of all the things I tried. I probably should go home
for lunch and post to this ng the actual tracings, but the problem went
something like this:
///THIS IS WICKEDLY DISTORTED
                pigment{
                        image_map{
                                once
                scale 14
// CHANGE  If my aspect ratio were 0.126  : 1.0 x:y, then
   box{<0,0,0>,<0.126 , 1.0  ,0.001>
didn't work either!  Help!
Let's fix this in mega 0.5!!!!!!
> the
> to
> It's not a bug.
> box {
>  pigment {
>   image_map {
>     gif "img1.gif"
> Gail
Date: 27 Mar 2000 15:24:15
Message: <38DFC39F.702AD5C0@spiritone.com>
See my post on your second thread for a similar solution. Bob and Gail are right,
this isn't a bug, but it isn't the clearest idea in the docs sometimes.
Josh
>                 pigment{
>                         image_map{
>                                 once
>                 scale 14
> > the
> > to
> > It's not a bug.
> > box {
> >  pigment {
> >   image_map {
> >     gif "img1.gif"
> > Gail
Josh English
eng### [at] spiritonecom
Date: 28 Mar 2000 05:14:17
Message: <38e085f9@news.povray.org>
Greg M. Johnson wrote in message <38DF6D27.7E7FBD8E@my-dejanews.com>...
home
Yes, it will be
>                pigment{
>                        image_map{
>                                once
                           // add this here
                           scale <0.126,1,1>
>                scale 14
It will if you add the line scale <0.126,1,1>
As I indicated, it is NOT a bug.
Gail
