POV-Ray : Newsgroups : povray.binaries.images : Towards a procedural tree macro (62kbbu) Server Time
6 May 2026 19:06:26 EDT (-0400)
  Towards a procedural tree macro (62kbbu) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Towards a procedural tree macro (62kbbu)
Date: 25 Mar 2000 23:39:42
Message: <38dd948e$1@news.povray.org>
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:38dd88f2@news.povray.org...
> I've seen some tree makers here which are breathtaking in their visual
> beauty.  I think that the coolest alorgithm for a tree, however, would
> be procedural and not involve lots of translate & rotate statements.
    Not too shabby! Looks like an Orange Grove.
    I haven't tried to play with your code yet... looks like fun...
Date: 25 Mar 2000 23:57:38
Message: <38DD98EB.B5596E93@gci.net>
Could you tell us what the value for gent you used in the posted scene?
All my attempts have given bad results, not at all like yours.
Thanks.
> Here's my first stab at a procedurally derived tree.  Further
> experimentation underway.  Feel free to take this and improve it.
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 26 Mar 2000 11:00:33
Message: <38de3421@news.povray.org>
    Again, not too shabby. But I think that starting from this it will be
hard to improve it much. I would rather see something that is more like the
lparser system that can start from a basic trunk and then divides into
branches and twigs. Then you could use trace or something to put leaves on
it...
    I am really interested in this and am pounding away at it. But I have
little hope of accomplishing it. I can't get a division, not even a simple
Y... once I get that the rest should just be tedium.
Date: 26 Mar 2000 12:32:39
Message: <38de49b7@news.povray.org>
ZERO.
I initially thought I could get it to given randomized appearance of each
tree, but then realized that I was too lazy to code it that way. Lemme know
if zero gives you trouble.......
> Thanks.
Date: 26 Mar 2000 12:47:10
Message: <38de4d1e@news.povray.org>
I chose the noise3d function because it has its own 'branchability' built into
it.
See the following image, with a slightly higher threshold, and a cross section
through the branches.
> it...
Download 'noiseforest02.jpg' (43 KB)
Preview of image 'noiseforest02.jpg'
Date: 26 Mar 2000 16:36:13
Message: <38DE858D.B0B3FCF5@aol.com>
I'm thinking a marriage between standard pov objects for branches, and
isosurfaces for leaves might be the best we can do to make good, and hopefully
fast-rendering trees. I might have to try it. :)
> #declare rag=function{ 1/(x^2+y^2+z^2)^0.5*5}   // 35;
> #macro Treegent(gent,tx,ty,tz)
> //gent is currently useless randomizer,  translate to tx, ty, tz
> union{
>  isosurface{
>          function{
> noise3d((x+gent)/rag,(y+gent)/rag,(z+gent)/rag)&(-y-1) }
>                 accuracy .001
>                 threshold  .01
>          contained_by {sphere{0,15} }
>          bounded_by   {sphere{0,2 } }
>  isosurface{
>          function{  noise3d((x+gent)/rag,(y+gent)/20/rag,(z+gent)/rag)}
>                 accuracy .001
>                 threshold  .08
>          contained_by { sphere{0,5} }
>          bounded_by   { sphere{0,1} }
>  pigment{
>          spherical
>   pigment_map{
>                  [0      Green]
>                         [.2     Brown]
>                         [1     Brown]
>                 scale 12
>         finish{ambient 0.1}
>         translate <tx,ty,tz>
>   #end
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Date: 26 Mar 2000 19:31:41
Message: <38DEAD4C.78E3@aol.com>
These trees would look just great in a background, I think; not as good
in the foreground, though.
Two small suggestions:
1) Turbulate the x, y, and z values just slightly based on their
distance from the center. This will give the trees a less hemispherical
look.
2) Change all n^2 to sqr(n) and n^0.5 to sqrt(n). As far as I can tell
from the function code, these should always be faster than using an
exponent.
I think I might give this a try in an old scene (where I wanted
background trees but settled for a textured height field) and see what
happens.
Lummox JR
Date: 26 Mar 2000 20:49:32
Message: <38debe2c@news.povray.org>
Howdoya  turbulate?
> look.
> exponent.
> happens.
> Lummox JR
Date: 27 Mar 2000 11:54:16
Message: <slrn8dv2kc.dc4.sjlen@zero-pps.localdomain>
I like the look of this.  I don't know anything about isosurfaces,
but I'll have a play with the code.
  2:19pm  up 8 days,  9:54,  5 users,  load average: 1.95, 1.95, 1.88
Date: 27 Mar 2000 19:09:00
Message: <chrishuff_99-553FDE.19111427032000@news.povray.org>
In article <38debe2c@news.povray.org>, "Greg M. Johnson"
<"gregj;-)56590\""@aol.c;-)om> wrote:
> Howdoya  turbulate?
You could turbulate an isosurface object by using it's function in a
pigment function, and using the pigment function for the actual
isosurface.
#declare TreeFn =
function {
    pigment {function {...}// use the tree function as pigment pattern
        color_map {[0 rgb 0][1 rgb 1]}
        warp {
            turbulence 0.35
isosurface {
    function {TreeFn(x,y,z)}
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
