POV-Ray : Newsgroups : povray.binaries.images : Re: Shrine to Light (41k) Server Time
30 Mar 2026 21:22:05 EDT (-0400)
  Re: Shrine to Light (41k) (Message 1 to 4 of 4)
Subject: Re: Shrine to Light (41k)
Date: 18 Mar 2000 18:26:58
Message: <38d410c2@news.povray.org>
Could use some brightening of the orange glow so that the shadows from the
columns appear more distinct.  I had to really look hard to see them.
Very neat image.
"Kari Kivisalo" <kar### [at] kivisalonet> wrote in message
news:38D### [at] kivisalonet...
| A splash screen for my website. Nothing special how it looks.
| It's a sum of 4 images: front light, back light, glow light
| and glow light + media. The idea is to separate each light source
| to it's own layer in photoshop so that their intensity and color
| can be adjusted _after_ render with full res aa image. It's also
| nice to be able to smooth the media in photoshop and use fewer
| samples :) Works only with non-gamma corrected images because
| gamma is non-linear operation.
| Read more about it from
| Grafica Obscura/Synthetic Lighting for Photography
| http://www.sgi.com/grafica/synth/index.html
| BTW, Photoshop doesn't seem to have ADD as layer mode so I used
|      SCREEN which looked close enough. To do these operations
|      properly for gamma corrected output would require 48 bit images,
|      ADD layer mode and preview gamma layer (which can be done in
|      photoshop with CURVES adjustment layer). I first developed
|      the image with gamma correction and when I started to use the
|      layer magic it was quite obvious 24 bits just isn't enough
|      because the images must be de-corrected before layer operations
|      and corrected again after.
| Kari Kivisalo                                          www.kivisalo.net
Date: 20 Mar 2000 06:16:51
Message: <38d608a3@news.povray.org>
Really good image, the contrast between the pillars and the orange glow work
so well, this i really like
Date: 20 Mar 2000 14:56:43
Message: <38D682A2.9B89074D@inapg.inra.fr>
This seems a very interesting technique and the result is very smooth.
How would the image look without it, I mean if it was rendered directly ? Just
curious.
G.
Date: 27 Mar 2000 23:08:22
Message: <38E02F2A.85F9926@faricy.net>
Possibly the best image I have seen today.
The effect is awesome!
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
