POV-Ray : Newsgroups : povray.binaries.images : Sascha/Escher Waterfall Illusion [~175kb Jpg] Server Time
15 Jun 2026 19:19:06 EDT (-0400)
  Sascha/Escher Waterfall Illusion [~175kb Jpg] (Message 11 to 20 of 20)
Subject: Re: Sascha/Escher Waterfall Un-Illusion [~24kb Jpg]
Date: 15 Mar 2000 03:22:17
Message: <38cf4839@news.povray.org>
"Alan Kong" <ako### [at] povrayNO-SPAMorg> wrote in message
news:q1aucs0qhjda8o3vvqfhrqftcmcdir030f@4ax.com...
|   I wonder how Sascha's scene would look as a cross-eyed stereogram?
Really neat of course.  Problem is how to go about it, since it uses the
'orthographic' camera.  I was about to try that anyway eventually just to see if
it could be done by shifting the clipping objects a little and using a very
zoomed in perspective camera.
Will let you know if it can be.
Date: 15 Mar 2000 06:52:26
Message: <38cf797a@news.povray.org>
> >Okay.  Interesting, isn't it?  Hope this small rendering shows it okay.
> >My hard work would only be that this illusion can be rendered in one go,
rather
> >than the two it took before which was what Sascha Ledinsky had to do in
order to
> >get the illusion to work.
I dont know if it would work correctly , worth a try tho (might give you
more headaches than it worth tho!)
Very good un-illusion :)
Subject: Re: Sascha/Escher Waterfall Un-Illusion [~102kb Jpg]
Date: 15 Mar 2000 11:14:45
Message: <38cfb6f5@news.povray.org>
And here it is... 3D in 3D.  The only headaches might be from trying to look at
it.
I was very surprised to see the illusion didn't actually breakdown, although the
foreground building seems to have moved considerably and I set the mandelbrot
fractal background the same for both renders.  All it really took to make this
stereogram was to rotate the camera (zoomed in with 'angle 0.5') a degree and
rotate the clipping objects a little too.  Well, I did have to lower the camera
a bit, but I'm not exactly sure why; orthographic to perspective change of some
kind.
Cross-eyed for the left and center, diverged-eyes for the right and center.
"Rick [Kitty5]" <pov### [at] dialpipexcom> wrote in message
news:38cf797a@news.povray.org...
Download 'waterfallillusion3D.jpg' (77 KB)
Preview of image 'waterfallillusion3D.jpg'
Date: 15 Mar 2000 18:24:42
Message: <8r60dsgunhk84lj2cagjaqjc18qh092v2e@4ax.com>
On Wed, 15 Mar 2000 10:12:41 -0600 "Bob Hughes"
  Cool. Thanks a bunch, Bob!
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 15 Mar 2000 18:55:54
Message: <38D0221E.3B4D3708@faricy.net>
If you look real closely you can see the overlap.
This is really just a double-tribar, isn't it...
Everything seems to have that tribar somewhere if you look.
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 16 Mar 2000 03:48:37
Message: <38d09fe5@news.povray.org>
news:8r60dsgunhk84lj2cagjaqjc18qh092v2e@4ax.com...
You are certainly welcome.
Date: 16 Mar 2000 03:55:17
Message: <38d0a175@news.povray.org>
I wasn't sure so I looked it up in one of my Escher books.  It's actually three
tribars.  The overlap for this one wasn't accounted for as much as in the first
non-stereogram images, I just wasn't going to spend as much time on it for these
quick smaller renders.  The other isn't perfect either.
news:38D0221E.3B4D3708@faricy.net...
Date: 16 Mar 2000 08:53:02
Message: <38d0e73e@news.povray.org>
whoa !
that is 3d poster material, really cool
(nice 3 image sewuence - but cross eye is the only way to go)
"Bob Hughes" <omn### [at] hotmailcom?subject=PoV-News:> wrote in message
news:38cfb6f5@news.povray.org...
look at
> it.
although the
mandelbrot
this
and
camera
some
> kind.
center.
> Bob
Date: 16 Mar 2000 17:06:05
Message: <38D159DE.AAD3225E@faricy.net>
I'm not talking about it being lined up. I mean I can actually see where the depth
changes.
Date: 17 Mar 2000 06:58:44
Message: <38d21df4@news.povray.org>
You see better than me then... but that's usually a given.
news:38D159DE.AAD3225E@faricy.net...
three
first
these
depth
| changes.
