POV-Ray : Newsgroups : povray.binaries.images : ridges Server Time
15 Jun 2026 22:00:17 EDT (-0400)
  ridges (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: ridges
Date: 6 Mar 2000 14:10:14
Message: <38C2B371.F7718FCA@earthlink.net>
I like the vein effect in the mountains... most realistic... the misty mountain
lake is beautiful where is the waterfall...??
Mick Hazelgrove wrote:
> An experiment with ridged multifractels,isosurfaces and the trace function.
> The landscape is a ridged multifunction, the trees are isosurface cones with
> noise added and the rocks are spheres with noise added.
> The whole lot placed with the trace function.
> Mick
>        http://www.minda.swinternet.co.uk/index.htm
Subject: Re: ridges
Date: 6 Mar 2000 15:00:27
Message: <38c40e5b@news.povray.org>
Hi all
This was just an experiment - not meant as a finished piece. The ridged
multifractal is slow to render - this is 2 ridged multifractals added
together and takes, with everything else, about six hours to render. The
biggest problem was scaling trace to trace a surface bigger than one unit.
It would be possible to make the landscape much bigger. The waterfall is a
good idea and I agree the sky would need lots of work if I was ever to
finish this piece. It was posted to give people an idea of what they might
do with the ridged multifractal.
Mick
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-C9F81A.11222506032000@news.povray.org...
> In article <38C3CE4F.58AD268A@peak.edu.ee>, Margus Ramst
> <mar### [at] peakeduee> wrote:
> > That's a lot of isosurfaces... Won't it be slow?
> Not necessarily...the speed of an isosurface can vary a lot. Some are
> faster than most of the other shapes available(isosurface
> superellipsoids are faster than ordinary superellipsoids, for example).
> Others are extremely slow. In my experience, avoiding functions with
> high slope helps a lot. These seem pretty simple, noise3d() displaced
> cones, spheres, etc. They should render pretty fast if only one
> noise3d() is used. I don't know about the ridged multifractal though...I
> have never used it.
> Chris Huff
> e-mail: chr### [at] yahoocom
> Web page: http://chrishuff.dhs.org/
Subject: Re: ridges
Date: 6 Mar 2000 16:43:25
Message: <38c4267d@news.povray.org>
Mick Hazelgrove skrev i meddelandet <38c40e5b@news.povray.org>...
What's a ridged multifractal?
--ll
Subject: Re: ridges
Date: 6 Mar 2000 17:29:02
Message: <38C4307A.B0981BD6@faricy.net>
I agree, but I think they're way to pointy. Those peaks would weather down pretty
fast.
___     ________________________________________________________________
 | \     |_                           <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine                         http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Subject: Re: ridges
Date: 6 Mar 2000 17:32:02
Message: <38C4312D.6B150756@faricy.net>
The pointiness is kind of neat but not very realistic. Those peaks will wear
down with time!
I don't like the trees, but as just a sample pic I imagine you can do a lot more
with them.
Ground fog is excellent!
Subject: Re: ridges
Date: 6 Mar 2000 17:40:59
Message: <chrishuff_99-1F42FF.17424106032000@news.povray.org>
In article <38C4312D.6B150756@faricy.net>, David Fontaine
> will wear down with time!
Maybe it is a newly terraformed planet, and the water cycle hasn't
existed long enough to weather the rocks very much. :-)
Chris Huff
Subject: Re: ridges
Date: 6 Mar 2000 19:36:38
Message: <slrn8c8eg5.7r3.sjlen@zero-pps.localdomain>
That is nice.
 10:40pm  up 3 days, 22:53,  6 users,  load average: 1.23, 1.20, 1.08
Subject: Re: ridges
Date: 6 Mar 2000 19:39:07
Message: <38C44F5E.E658F5F0@stud.ntnu.no>
Intriguing. Never used those multifractals. Any chance to have a peek at the
source?
sig.
Subject: Re: ridges
Date: 6 Mar 2000 19:41:19
Message: <38C450A5.E6D92739@peak.edu.ee>
The
I'm not sure I understand this?
Margus
Subject: Re: ridges
Date: 7 Mar 2000 05:20:35
Message: <chrishuff_99-FAB583.05221607032000@news.povray.org>
In article <38c40e5b@news.povray.org>, "Mick Hazelgrove"
<mha### [at] mindaswinternetcouk> wrote:
> The biggest problem was scaling trace to trace a surface bigger than
> one unit.
I'm not sure I understand this...trace() is not scale dependant. It
takes a starting point, an object, and a direction, and intersects the
ray defined by the start point and direction with the object. The size
of the surface or distance of the intersection don't matter.
Hmm, you could probably do a nearly infinite flying animation by moving
the containing box for the landscape along with the camera, and using
the noise3d() function instead of rand() to place the rocks and trees.
Or you could just make a really big landscape...
Chris Huff
