POV-Ray : Newsgroups : povray.binaries.images : ridges Server Time
15 Jun 2026 22:00:15 EDT (-0400)
  ridges (Message 11 to 15 of 15)
Subject: Re: ridges
Date: 6 Mar 2000 17:40:59
Message: <chrishuff_99-1F42FF.17424106032000@news.povray.org>
In article <38C4312D.6B150756@faricy.net>, David Fontaine
<dav### [at] faricynet> wrote:
> The pointiness is kind of neat but not very realistic. Those peaks
> will wear down with time!
Maybe it is a newly terraformed planet, and the water cycle hasn't
existed long enough to weather the rocks very much. :-)
Chris Huff
e-mail: chr### [at] yahoocom
Subject: Re: ridges
Date: 6 Mar 2000 19:36:38
Message: <slrn8c8eg5.7r3.sjlen@zero-pps.localdomain>
On Mon, 6 Mar 2000 05:28:26 -0000, Mick Hazelgrove wrote:
>An experiment with ridged multifractels,isosurfaces and the trace function.
>The landscape is a ridged multifunction, the trees are isosurface cones with
>noise added and the rocks are spheres with noise added.
>The whole lot placed with the trace function.
That is nice.
 10:40pm  up 3 days, 22:53,  6 users,  load average: 1.23, 1.20, 1.08
Subject: Re: ridges
Date: 6 Mar 2000 19:39:07
Message: <38C44F5E.E658F5F0@stud.ntnu.no>
Intriguing. Never used those multifractals. Any chance to have a peek at the
source?
sig.
Subject: Re: ridges
Date: 6 Mar 2000 19:41:19
Message: <38C450A5.E6D92739@peak.edu.ee>
The
> biggest problem was scaling trace to trace a surface bigger than one unit.
I'm not sure I understand this?
Margus
Subject: Re: ridges
Date: 7 Mar 2000 05:20:35
Message: <chrishuff_99-FAB583.05221607032000@news.povray.org>
In article <38c40e5b@news.povray.org>, "Mick Hazelgrove"
<mha### [at] mindaswinternetcouk> wrote:
> The biggest problem was scaling trace to trace a surface bigger than
> one unit.
I'm not sure I understand this...trace() is not scale dependant. It
takes a starting point, an object, and a direction, and intersects the
ray defined by the start point and direction with the object. The size
of the surface or distance of the intersection don't matter.
> It would be possible to make the landscape much bigger.
Hmm, you could probably do a nearly infinite flying animation by moving
the containing box for the landscape along with the camera, and using
the noise3d() function instead of rand() to place the rocks and trees.
Or you could just make a really big landscape...
Chris Huff
