POV-Ray : Newsgroups : povray.binaries.images : Torus problem (69KB) Server Time
6 May 2026 16:36:49 EDT (-0400)
  Torus problem (69KB) (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Torus problem (69KB)
Date: 21 Apr 2000 17:35:45
Message: <3900C9CE.ECF0E25E@hotmail.com>
Mike Metheny wrote:
> I think the texture difference; while perhaps unintended, looks very cool :>
Heh! :)
I was so focused on the problem that I did not see that!
Thank you.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 21 Apr 2000 22:13:00
Message: <39010aac@news.povray.org>
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:3900C930.F7039ED4@hotmail.com...
| I have now tried to replace the difference with an
| intersection of a sphere and a torus with the
| 'inverse' keyword. (Is this what you meant?)
| ==> Same result. No change in the reflections. :(
Nope.  I was talking about the torus surface itself, maybe if it's inversed then
perhaps the reflection will right itself by then being on the "outside".
Realize though that by turning the torus inside-out then the CSG will
change too.  I think that a inverse used in the intersection or difference
should cancel that change.
Rather than try and make guesses I just tried to make such a thing myself
and I couldn't even see any reversed (or whatever) reflection:
light_source { <-5,10,-10> color rgb 1.5
  location  <-1,1,-10>
  angle 25
  look_at   <0, 0, 0>
sphere {0,1
        pigment {gradient y color_map {
                [0,1 color rgb <.9,.2,.1> color rgb <.2,.4,.8>]
        }} scale 30
#declare Connector=
union {
difference { // torus core, capped
        sphere {0,1}
        torus {1.5,1}
      translate -y*.6615 // approximation only
difference { // torus anti-core
        torus {1.5,1}
        sphere {0,1 inverse}
      translate y*.6615 // approximation only
        pigment {rgb <.25,1,.25>}
        finish {reflection .5}
object {Connector
         scale <.5,2,.5> rotate <-30,70,-90> translate -y
object {Connector
         scale <.5,2,.5> rotate <30,-70,90> translate y
Date: 22 Apr 2000 10:56:34
Message: <3901BDA8.C6F8691D@hotmail.com>
First: Thank you very much for trying to help me!
I'm quite frustrated, because I need the reflections from this
middle "cigar" shape to behave correctly(?) in other scenes.
I have now included some of my source code below so that you can see
what I'm actually doing.
Note that my convex "cigar" shape is made with a torus that has a
greater minor radius than major radius.
And I now wonder if this could cause the odd change in reflections?
(As I understand from your code, you are making a similar shape by
scaling a sphere along an axis.)
Regards
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.1;
#include "textures.inc"
#declare v3Origo = <0, 0, 0>;
#macro Pythagoras(hyp, kat)
 sqrt(hyp*hyp - kat*kat)
#end // macro Pythagoras
#declare RadW = 1.0; // Max Radius for Wide   part (Cigar Shape)
#declare RadN = 0.5; // Min Radius for Narrow part (Spoke shape)
#declare RadMinC = 26; // Minor Radius for Cigar shape
#declare RadMinS = 26; // Minor Radius for Spoke shape
#declare HoleClearing = 0.1;
#declare RadMajC = RadMinC - RadW; // Major Radius for Cigar shape
#declare RadMajS = RadMinS + RadN; // Major Radius for Spoke shape
#declare ss = Pythagoras(RadMinC + RadMinS, RadMajC + RadMajS);
#declare tt = ss*RadMinS/(RadMinC + RadMinS);
#declare DistBetween = 2*ss; // RadW + RadN
#declare Cigar =
difference {
  sphere { v3Origo, Pythagoras(RadMinC, RadMajC) }
  torus { RadMajC, RadMinC }
  cylinder { (RadW + RadN)*x, -(RadW + RadN)*x, RadN + HoleClearing }
//  plane {  y, tt - ss }
//  plane { -y, tt - ss }
#declare Spoke =
difference {
  sphere { v3Origo, vlength(<RadMajS, RadMinS>) }
  torus { RadMajS, RadMinS }
  plane {  y, -tt }
  plane { -y, -tt }
//#declare SpkCig =
merge {
  object { Cigar translate +ss/2*y }
  object { Spoke translate -ss/2*y }
  texture { Soft_Silver }
  pigment { color Red }
Date: 22 Apr 2000 20:02:16
Message: <39023d88$1@news.povray.org>
I checked out what you had there and also didn't see any way of getting the inside to
become outside, which is the case for that torus with the larger minor radius than
major.
Not that it was going to be possible using inverse or variations thereof (I even gave
scale -1 a try), but as it turns out I couldn't even get the MegaPov
'interior_texture' to
put it right.
This means to me that something goes wrong with that torus.  Not a complete surprise
either since it's been said before by other people how that particular shape isn't
reliable.
The problem is in the inner part of the torus, even though usually an outer surface,
ends
up inside itself.  So the raytracer must be confusing it entirely.
Date: 24 Apr 2000 21:40:28
Message: <3904F7A6.AF260EC3@hotmail.com>
> reliable.
ends
So it is the "ciagar" shape that messes up the
reflections.
That's a pity. =(
Is this to be considered as a bug ?
And if so, do you know if the other people you
mentioned have posted a bug report on the subject?
I have also noticed that this shape is hollow.
And therefore it doesn't behave in CSG operations.
Tor Olav
Date: 24 Apr 2000 21:55:43
Message: <3904fb1f@news.povray.org>
I don't know if it's a mathematic problem with the torus and if not then it must be
related to the raytracer.
Maybe there's a possible fix but I'm not one who could even begin to guess the answer.
I think it might have been said to be a "bug", but again I couldn't say.  Straining to
remember
I think people were conceding it to be a problem with the raytraced surface and might
not
be
easily fixed.  Takes those math geniuses out there (and here) I'm sure.
news:3904F7A6.AF260EC3@hotmail.com...
surprise
| > reliable.
surface,
ends
| reflections.
| That's a pity. =(
| Tor Olav
| http://www.crosswinds.net/~tok/tokrays.html
Date: 24 Apr 2000 22:10:03
Message: <chrishuff_99-1B983E.21130124042000@news.povray.org>
In article <3904F7A6.AF260EC3@hotmail.com>, Tor Olav Kristensen
> reflections.
> That's a pity. =(
I think the reason you end up with a "cigar" shape at all is a bug. As I
recall, this is because the bounding gets messed up by the radius
settings, I think someone was working on a fix for it...which wouldn't
give a cigar shape, but the actual torus shape.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 24 Apr 2000 22:38:52
Message: <39050553.8CB4B93F@hotmail.com>
As far as I remember you do get the torus shape if you do not
subtract it from another shape.
Btw: Are there other shapes that intersects with themselves
like this?
(Maybe one could introduce a new "self_intersection" keyword ? :)
> As I recall,
But, but, but ...
...How are we supposed to model such cigar shapes then?
(Scaling a sphere along an axis gives a shape that's round
at the ends, while this cigar shape ends in a sharp point.)
Tor Olav
Date: 24 Apr 2000 23:54:49
Message: <390516B5.CA6D79B1@pacbell.net>
Tor Olav Kristensen wrote:
> But, but, but ...
A lathe can do it with ease and can also be used in CSG operations.
Date: 25 Apr 2000 06:47:55
Message: <chrishuff_99-D8FB78.05505325042000@news.povray.org>
In article <390516B5.CA6D79B1@pacbell.net>, lin### [at] povrayorg
> > But, but, but ...
You can also do it with the poly or quartic objects, and it is quite
easy to do with the isosurface object.
