POV-Ray : Newsgroups : povray.binaries.images : Torus problem (69KB) Server Time
6 May 2026 18:04:51 EDT (-0400)
  Torus problem (69KB) (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Torus problem (69KB)
Date: 24 Apr 2000 22:10:03
Message: <chrishuff_99-1B983E.21130124042000@news.povray.org>
In article <3904F7A6.AF260EC3@hotmail.com>, Tor Olav Kristensen
<tor### [at] hotmailcom> wrote:
> So it is the "ciagar" shape that messes up the
> reflections.
> That's a pity. =(
> Is this to be considered as a bug ?
> And if so, do you know if the other people you
> mentioned have posted a bug report on the subject?
> I have also noticed that this shape is hollow.
> And therefore it doesn't behave in CSG operations.
I think the reason you end up with a "cigar" shape at all is a bug. As I
recall, this is because the bounding gets messed up by the radius
settings, I think someone was working on a fix for it...which wouldn't
give a cigar shape, but the actual torus shape.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 24 Apr 2000 22:38:52
Message: <39050553.8CB4B93F@hotmail.com>
As far as I remember you do get the torus shape if you do not
subtract it from another shape.
Btw: Are there other shapes that intersects with themselves
like this?
(Maybe one could introduce a new "self_intersection" keyword ? :)
> As I recall,
But, but, but ...
...How are we supposed to model such cigar shapes then?
(Scaling a sphere along an axis gives a shape that's round
at the ends, while this cigar shape ends in a sharp point.)
Tor Olav
mailto:tor### [at] hotmailcom
Date: 24 Apr 2000 23:54:49
Message: <390516B5.CA6D79B1@pacbell.net>
Tor Olav Kristensen wrote:
> But, but, but ...
A lathe can do it with ease and can also be used in CSG operations.
Date: 25 Apr 2000 06:47:55
Message: <chrishuff_99-D8FB78.05505325042000@news.povray.org>
In article <390516B5.CA6D79B1@pacbell.net>, lin### [at] povrayorg
> > But, but, but ...
You can also do it with the poly or quartic objects, and it is quite
easy to do with the isosurface object.
Date: 25 Apr 2000 18:01:25
Message: <a40cgso5faq571fcitr6litaijcvm8lfeq@4ax.com>
>> But, but, but ...
 I have been having exactly the same problem with the chimney of a loco that I
am modelling.  I was using a cone with the fillet radii being produced by the
outside surface of two tori.  These fillets have a different texture to the rest
of the chimney, presumably because of the normal being the wrong way.
A lathe object should solve this problem, but at the expense of a much more
involved definition requiring a bezier_spline definition.
David
dav### [at] hamiltonitecom
http://www.hamiltonite.com/
Date: 25 Apr 2000 18:09:38
Message: <3906173C.3C11324C@pacbell.net>
This is one of the areas where I will always used an external utility.
Hand coding splines is a waste of time when you can use a utility to
simply point and click your shape definition.
Date: 28 Apr 2000 20:40:44
Message: <390A2FC0.338AB835@hotmail.com>
Thank you. I did not think of that.
(But it would still be nice to have a basic shape like
this one. Because then I wouldn't have to calculate
the co ordinates for the appropriate quadratic_spline or
cubic_spline.)
Btw.: Will such a lathe render slower than my "cigar" shape ?
Tor Olav
Date: 28 Apr 2000 20:47:45
Message: <390A3169.9A2EE8C@hotmail.com>
I have been thinking about that, but I have not found the
proper equation for that yet.
(Where the minor and major radii are a part of the equation.)
Any suggestions?
And would it be possible to use a quartic object (and an
isosurface) in a CSG expression?
Tor Olav
Date: 28 Apr 2000 20:53:55
Message: <390A32DC.3ADF862B@hotmail.com>
Do you have any suggestions on how to calculate a set of co-ordinates
for a bezier_spline lathe that models such a "cigar" accurately?
Tor Olav
Date: 28 Apr 2000 20:56:08
Message: <390A3364.5028AD4@hotmail.com>
But I can not tell my macros to go and use an external utility...
... Or can I ? :)
Tor Olav
