POV-Ray : Newsgroups : povray.binaries.images : Media air - HOW? Server Time
30 Jun 2026 00:33:54 EDT (-0400)
  Media air - HOW? (Message 1 to 10 of 15)
Subject: Media air - HOW?
Date: 3 Apr 2000 16:12:16
Message: <38E8FA5B.5FC655C4@netvision.net.il>
The scene file in included, but here is the code of the media I used:
media
  intervals 10
  samples 5, 5
  confidence 0.9
  variance 1/128
  ratio 1
  scattering {1, rgb <0.1,0.1,0.1> extinction 1}
help! The white stuff covers the whole image, denser when there is
something closer. I also included the image without media.
Download 'lando.pov.txt' (2 KB) Download 'lando.inc.txt' (2 KB) Download 'lando.jpg' (26 KB) Download 'lando1.jpg' (28 KB)
Preview of image 'lando.jpg'
Preview of image 'lando1.jpg'
Subject: Re: Media air - HOW?
Date: 3 Apr 2000 16:38:29
Message: <chrishuff_99-5CE96F.15405403042000@news.povray.org>
In article <38E8FA5B.5FC655C4@netvision.net.il>, Lewis
> media
>   intervals 10
>   samples 5, 5
>   confidence 0.9
>   variance 1/128
>   ratio 1
Well, first, your media isn't contained by any object. This makes it
somewhat unpredictable, and doesn't work well for the background areas,
so I put it in a sphere.
Second, you seem to be using MegaPOV, so you might as well use method 3
media. You can get smoother results with lower settings and much faster
rendering this way.
Finally, your media is *way* too dense. I decreased it to 1/20th of what
it was. Here is my version of the media, you might want to fine-tune the
density and extinction:
sphere {<0,0,0>, 1 scale < 1000, 150, 1000>
        pigment {color rgbf <1,1,1,1>}
    interior {
        media {
            intervals 1
            samples 5, 5
            confidence 0.9
            variance 1/128
            ratio 1
            scattering {1, rgb 0.005 extinction 0.6}
            method 3
            aa_level 4 aa_threshold 0.1
    hollow on
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Date: 3 Apr 2000 16:47:36
Message: <38E902CF.BDE7D62D@netvision.net.il>
Thanx, man! I never thought about the sphere thing, and...and... well
just plain thanx.
> > media
> >   intervals 10
> >   samples 5, 5
> >   confidence 0.9
> >   variance 1/128
> >   ratio 1
> rendering this way.
>     texture {
>     interior {
>         media {
>             intervals 1
>             samples 5, 5
>             confidence 0.9
>             variance 1/128
>             ratio 1
>             method 3
>     hollow on
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Web page: http://chrishuff.dhs.org/
Date: 3 Apr 2000 17:11:43
Message: <WAfpOI0UfFOUxTH=g2Zfs+K5CYlI@4ax.com>
On Mon, 03 Apr 2000 22:09:00 +0200, Lewis <nle### [at] netvisionnetil>
wrote:
>Hi,
>media
>  intervals 10
>  samples 5, 5
>  confidence 0.9
>  variance 1/128
>  ratio 1
Can't tell much without seeing the whole source (or at least the
lights and camera setup), but one thing is sure. I'd use scattering
type 4 for air. Other than that, keep in mind that if you use a
realistic extinction (i.e. 1) the range in which you can vary the
scattering is very small. I'd suggest you change <0.1,0.1,0.1> to 0.1
because it's easier to change and means the same. I'd also suggest you
used MegaPOV if you could, to take advantage of Nathan's sampling
method 3. Lastly, if you're about to encounter media, make yourself a
pint of coffee and be prepared for a long journey :)
Peter Popov ICQ : 15002700
Date: 3 Apr 2000 17:50:31
Message: <38E91186.43294299@netvision.net.il>
Well, I know, but - a PINT of coffee? First of all, I don't drink coffee
at all (it's verrrrry unhealthy, really!). Secondly, a PINT?!!
Date: 3 Apr 2000 17:57:10
Message: <38e913b6@news.povray.org>
Hell yeah :)
I use one of those old fashioned A&W root beer mugs for my coffee mug.
That's 1/3 of a pot :)
Date: 3 Apr 2000 18:02:15
Message: <38E9161E.285CF362@unforgettable.com>
Make it a gallon.
My "wilderness" scene, recently posted here, took ten hours and eleven
minutes to render, not counting parsing time. With the sky turned off,
the same scene renders in several seconds.
Xplo Eristotle
http://start.at/xplosion/
Date: 3 Apr 2000 18:51:52
Message: <38e92088$1@news.povray.org>
Hmmm... ten hours - do you think the POVRay team has a stake in at Intel???
Mike
wk: mik### [at] pyxiscom  www.pyxis.com
hm: mwe### [at] sciticom  www.geocities.com/mikepweber
"Xplo Eristotle" <inq### [at] unforgettablecom> wrote in message
news:38E9161E.285CF362@unforgettable.com...
> Make it a gallon.
> Xplo Eristotle
Date: 3 Apr 2000 20:44:34
Message: <38E93AB3.73155332@faricy.net>
Nah, it stunts your growth, but if you don't drink it till you're an adult
it's not that bad for you. You become dependent on it to get you going in
the morning, but it does help you stay alert.
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 3 Apr 2000 23:02:18
Message: <38e95b3a@news.povray.org>
Charles Krause <ckr### [at] telusplanetnet> wrote in message
news:38e913b6@news.povray.org...
I use a Zojirushi mug for my morning coffee. The stainless steel vacuum
keeps the coffee hot for hours and hours.
David
"The bridges between our dreams and
reality are built upon the three P's.
Patience, Planning, and Perseverance."
