POV-Ray : Newsgroups : povray.binaries.images : Layered texture vs. material_map Server Time
1 Feb 2026 13:16:22 EST (-0500)
  Layered texture vs. material_map (Message 1 to 3 of 3)
Subject: Layered texture vs. material_map
Date: 22 Mar 2000 12:13:46
Message: <38D8FF29.C886F44C@stud.ntnu.no>
These images illustrates the "Cannot layer over a patterned texture" problem
(or the lack of a finish_map) brought up on a few occations here.
In layered.jpg there are 3 layered textures. This produces the effect I want on
the image_map, since it's partly transparent.
material_map.jpg uses a patterned texture and basically two
pigment {rgb x}/{rgb 0} textures in a material_map. Here I get the desired
appearance on the aluminum with a variation in the highlight, but I can't use a
layered texture for the image_map-part.
Using a patterned texture in material_map causes MegaPov to crash, so this is
all official pov. I'll post the source for material_map.jpg in p.b.s-f.
sig.
Download 'layered.jpg' (15 KB) Download 'material_map.jpg' (17 KB)
Preview of image 'layered.jpg'
Preview of image 'material_map.jpg'
Subject: Re: Layered texture vs. material_map
Date: 22 Mar 2000 16:16:50
Message: <38d93842$1@news.povray.org>
Sigmund Kyrre Aas <as### [at] studntnuno> wrote...
is
FYI, that bug will be fixed in MegaPov 0.5.
-Nathan
Date: 22 Mar 2000 17:47:40
Message: <38D94D7E.60700E58@stud.ntnu.no>
> is
Oki, I didn't find any reports on it. Also the official version is much faster
than Megapov: 94 vs. 45 seconds..
