POV-Ray : Newsgroups : povray.binaries.images : Baseball, 24kbu Server Time
31 Dec 2025 00:25:23 EST (-0500)
  Baseball, 24kbu (Message 1 to 10 of 33)
Subject: Baseball, 24kbu
Date: 20 Feb 2000 09:08:03
Message: <38AFF53B.4A483B33@stud.ntnu.no>
Here is my current project and two questions:
* Why can't I get blobs blobby? This is my first attempt with blobs, and as you
can see there is a sharp edge where the bump making spheres intersects the ball
sphere.
* How do I prevent the image maps from appearing at the reverse side? I've
tried gradient texture maps, but was told that texture maps couldn't be used in
layered textures. (or something)
sig.
Download 'baseball.jpg' (24 KB)
Preview of image 'baseball.jpg'
Subject: Re: Baseball, 24kbu
Date: 20 Feb 2000 10:18:52
Message: <38b005dc@news.povray.org>
"Sigmund Kyrre Aas" <as### [at] studntnuno> wrote in message
news:38AFF53B.4A483B33@stud.ntnu.no...
> with blobs, and as you can see there is a sharp edge
> sphere.
> the reverse side? I've tried gradient texture maps, but
> was told that texture maps couldn't be used in layered
While I can't answer your first question, here's a link to a tutorial
dealing with your second:
http://members.xoom.com/yang4yang/pov/imap1.html
Good luck.
Eric
"The whole problem with the world is that fools and fanatics are always so
certain of themselves, but wiser people so full of doubts."
--Bertrand Russel
Date: 20 Feb 2000 10:27:13
Message: <38b007d1@news.povray.org>
Are you enclosing the ball sphere and the bump spheres in a single blob{}
statement? If you have them in separate blob{} statements, they won't blob
together when they intersect.
Paul Vanukoff
van### [at] primenetcom
Sigmund Kyrre Aas wrote in message <38AFF53B.4A483B33@stud.ntnu.no>...
you
ball
>sphere.
Date: 20 Feb 2000 11:50:48
Message: <38B01B76.9AB0BDE7@stud.ntnu.no>
Yes. Here it is:
blob {
    threshold .8
    sphere {<0, 0, 0>, R*3.05, 1.004 }
    $a=0;
    $AntKuler=500;
    $d=1/AntKuler;
    #while (a<1)
        $Her=eval_3d_spline("Seam",a);
        $Der=eval_3d_spline("Seam",a+d);
        $Retn=vnormalize( Der-Her);
        $Tvers=vnormalize(vcross(Retn,Her) );
        $Norm=vnormalize(Her);
        sphere { 0, .25 ,1.2 scale <.33,1,1>  // bulk utover
            matrix <Norm.x,Norm.y,Norm.z,
                    Retn.x,Retn.y,Retn.z,
                    Tvers.x,Tvers.y,Tvers.z,
                    0   ,0   ,0    >
            translate Her*.99
                    Tvers.x*.2,Tvers.y*.2,Tvers.z*.2,
                    0   ,0   ,0    >
            translate Her*1.02
                    0   ,0   ,0    >
            translate Her*1.04
        $a=a+d;
    texture{pigment {Green}}
    texture{pigment {Svart}}
    texture {pigment {Batter}}
    texture {pigment {Logo}}
    texture {pigment {Major}}
    finish {specular .1 roughness .05}
    normal { granite 0.5  scale .01 }
Date: 20 Feb 2000 13:02:25
Message: <38B02C3E.D0BC1000@stud.ntnu.no>
Nice tutorial, but it didn't solve my problem.
Now I've tried material maps too, but I get the same message when I try to use
them in layers: "Cannot layer a patterned texture over another"
sig.
Date: 20 Feb 2000 18:46:10
Message: <38b07cc2@news.povray.org>
'threshold .8' might be a little tight, perhaps lower that.  'blob' hardly ever
loses it's creases between components completely though.
news:38B01B76.9AB0BDE7@stud.ntnu.no...
| Yes. Here it is:
| blob {
|     threshold .8
|     $a=0;
|     $AntKuler=500;
|     $d=1/AntKuler;
|     #while (a<1)
|                     0   ,0   ,0    >
|             translate Her*.99
|                     0   ,0   ,0    >
|             translate Her*1.02
|                     0   ,0   ,0    >
|             translate Her*1.04
|         $a=a+d;
|     #end
Date: 20 Feb 2000 18:58:53
Message: <38B0801E.6B62C4C3@istar.ca>
I can't answer either of your questions, but I am mightly impressed with the ball.
Could you post the texture you used for the leather? Very nice!
Simon
Date: 20 Feb 2000 23:24:57
Message: <38B0BD23.2107814A@fci.net>
> sphere.
First, decrease your threshold to .1.  As for the intersections, you should make
multiple copies of the objects you wish to blob. Make the components increase in
diameter, and decrease the component power.  This "feathers" the edges, resulting
in a much smoother edge.
This actually works just fine. The texture on my sports car is entirely dependent
on this working just fine. my suggestion is to experiment.
H.E. Day
Date: 21 Feb 2000 03:46:28
Message: <38b0fb64@news.povray.org>
news:38B02C3E.D0BC1000@stud.ntnu.no...
> same message when I try to use them in layers:
> sig.
Here's a code snippet from a drinking glass I made using a different
technique.  Basically you create a second object (slightly larger than the
original and hollow), apply the logo image map to it, and chop off the back
half by differencing it with a box.
// make a drinking glass from the difference
// of two cylinders
#declare GlassMain = difference {
  cylinder {
    <0,0,0>,
    <0,Hite,0>
    Rad
  cylinder {
    <0,0.1,0>,
    <0,Hite+1,0>
    Rad*0.9
  material {GlassMat}
// make another hollow cylinder with a slightly larger
// radius than the drinking glass and chop off the back
// of it by differencing it with a box
#declare Logo = difference {
  cylinder { // main cylinder
    <0, -0.7, 0>,
    <0,  0.7, 0>
    Rad+0.00002
  cylinder { // cut-out
    <0,-0.71,0>,
    <0,0.71,0>
    Rad+0.00001
  box { // chop off the back half of the cylinder
    <-Rad-0.1,-0.71,0>,
    <Rad+0.1,0.71,Rad+0.1>
      image_map {
        gif "logo_image.gif"
        transmit 209, 1.0 // make the background of the image transparent
        once
        map_type 0
        interpolate 2
    // scale the logo to fit
    translate <-0.5,-0.5,0>
    scale <224/167,1,1>
    scale 1.4
  // position the logo cylinder on the drinking glass
  translate <0,3.75,0>
  rotate y*11
#declare DrinkingGlass = union {
  object {GlassMain}
  object {Logo}
Eric
--Bertrand Russel
Date: 21 Feb 2000 05:16:24
Message: <38B10675.86A069B@stud.ntnu.no>
Thanks! It's quite simple actually. I got it pretty much at first attempt:
$Green=
pigment { bozo
    colour_map {
        [0 rgb <255,249,227>/255]
        [0.5 rgb <233,255,227>/255 ]
        [0.8 rgb <219,205,150>/255 ]
        [1 rgb <255,249,227>/255]
$Svart=
pigment { ripples
    colour_map {
        [0 rgb 1]
        [0.8 rgbf <131,105,55,90>/255 ]
        [1 rgbf 1]
(see previous posting for the rest)
sig.
