POV-Ray : Newsgroups : povray.binaries.images : Tuesday Evening Enigma (mazepigm.jpg 83.3k bu) Server Time
19 May 2026 07:51:39 EDT (-0400)
  Tuesday Evening Enigma (mazepigm.jpg 83.3k bu) (Message 1 to 10 of 20)
Subject: Tuesday Evening Enigma (mazepigm.jpg 83.3k bu)
Date: 8 Feb 2000 21:51:30
Message: <38A0D839.371F1B4E@aol.com>
Hello everybody. Attached is an image showing off a new pigment I found
today. I've been wanting to create a maze-like pigment for some time
now. Can you guess how it was done?
Here are some hints:
    It was made totally in PovRay; no paint programs were used.
    It was made with MegaPov (Superpatch works too).
    It's not a huge, complex iso function, although it uses small
functions for simple tasks you could already do in pov (so the functions
really don't matter).
Good evening~
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
Download 'mazepigm.jpg' (83 KB)
Preview of image 'mazepigm.jpg'
Subject: Re: Tuesday Evening Enigma (mazepigm.jpg 83.3k bu)
Date: 9 Feb 2000 00:08:11
Message: <38a0f63b@news.povray.org>
"SamuelT." <STB### [at] aolcom> wrote in message
news:38A0D839.371F1B4E@aol.com...
> today.
    Oooo...
    Not a chance. I don't see any repeats, are there any?
Date: 9 Feb 2000 01:26:00
Message: <slrn8a21so.v8.ron.parker@parkerr.fwi.com>
It looks kinda like this, but mine doesn't have all the loops, and it
has a definite diagonal tendency.
camera {location 20*y sky y look_at <15,0,15>}
light_source {20*y rgb 1}
plane {y,0
    crackle solid metric 1
    pigment_map {
      [.5 gradient x color_map{[.5 rgb 0][.5 rgb 1]} warp{repeat x}]
      [.5 gradient z color_map{[.5 rgb 1][.5 rgb 0]} warp{repeat z}]
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 9 Feb 2000 01:49:35
Message: <slrn8a238u.v8.ron.parker@parkerr.fwi.com>
Or this version, slightly loopier but with the odd broken piece:
plane {y,0
    bozo
    pigment_map {
      [.5 gradient x
          color_map{[.25 rgb 0][.25 rgb 1][.75 rgb 1][.75 rgb 0]}
          warp{repeat x} scale sqrt(2) rotate 45*y ]
      [.5 gradient x
          warp{repeat x} scale sqrt(2) rotate -45*y]
    scale 100
    warp {repeat x offset 50*y}
    warp {repeat z offset 60*z}
    warp {reset_children}
Date: 9 Feb 2000 02:26:34
Message: <38a116aa@news.povray.org>
All I know is that pigments can be made into new patterns but I don't see how
you got a seemingly infinitely changing maze out of it.  It's great, never seen
one before.
"SamuelT." <STB### [at] aolcom> wrote in message news:38A0D839.371F1B4E@aol.com...
| Good evening~
| Samuel Benge
Date: 9 Feb 2000 10:39:04
Message: <38a18a18@news.povray.org>
Excellent - at first I thought it was a bitmap repeated - but I didn't see
any repeating patterns.
Will you be sharing your pigment code with the rest of us?
Mike
> Good evening~
> Samuel Benge
Date: 9 Feb 2000 11:02:04
Message: <38A18F85.4081BC69@spiritone.com>
I'm almost thinking that you found a way to randomize a checke pattern with
limiting the steps to 90 degree turns when caclulcation the tubulence... but
I'm probably way off.
> Good evening~
> Samuel Benge
Josh English
eng### [at] spiritonecom
Date: 9 Feb 2000 12:14:46
Message: <slrn8a383r.11r.ron.parker@ron.gwmicro.com>
Okay, I'm going to assume this is pretty much it until you say otherwise:
#macro MazePigment(Pig1,Pig2)
  #local Pig3=pigment {
    gradient x
    pigment_map {[.25 Pig1][.25 Pig2][.75 Pig2][.75 Pig1]}
    warp {repeat x} scale sqrt(2) rotate 45*y
  function { noise3d(floor(x)+.5,floor(y)+.5,floor(z)+.5) }
  pigment_map {
    [.5 Pig3 ]
    [.5 Pig3 rotate 90*y ]
camera {location 80*y sky z look_at 0}
light_source {80*y rgb 1}
plane {y 0
    MazePigment(pigment{color rgb <.5,.5,1>}, pigment {color rgb 0})
Date: 9 Feb 2000 22:33:28
Message: <38A233D7.C56EB241@aol.com>
It does repeat.
Ron, your' guesses were excellent! You had the basic idea down, but not
the procedure. I like your first try at it best, although it does have a
diagonal tendancy, and I could not remove it. Best thing about yours is
that it doesn't repeat. I didn't know metric did that to crackle.
Well, here's mine in macro form. It may need to be edited if you paste
it into pov.
// Maze( M_Dim, M_Complex, M_Randseed )
// M_Dim is the dimensions for the tile. '4' would let you place it on a
// 4-unit square cube
// M_Complex is how complex you want it. Values range from 0 to 2.
// good values are from 1 to 2
// M_Randseed is just the seed value for the maze. Enter any value to
// see different patterns
#version unofficial MegaPov .3;    // needed for MegaPov .4 users
camera{ location<0,10,-15> look_at 0 angle 40 rotate y*-30 }
light_source{ <100,200,100>,1 }
background{ <.4 .7 1> }
#macro Maze( M_Dim, M_Complex, M_Randseed )
 #local M_Dim=M_Dim*8;
 #local M_Rand=M_Dim/20
 #local M_Pat=
  function{
   pigment{
    image_map{
     pattern M_Dim, M_Dim{ function noise3d(x,y,z) scale( .25/M_Rand
)/M_Complex translate y*rand( seed( M_Randseed ) ) }
     map_type 0    //include 'once' to test the tiling
    translate<-.5, -.5, -.5> rotate x*90 scale M_Dim/4
 #local M_Pigm=
  function{
   pigment{
    function M_Pat( x, y, z ) scale .5
    pigment_map{
     [.5 function x*2 sine_wave color_map{ [.5 rgb 0][.5 rgb 1] } ]
     [.5 function z*2 sine_wave color_map{ [.5 rgb 0][.5 rgb 1] } ]
 function{ M_Pigm( x, y, z ) }
box{<-4,-1,-4>,<4,1,4>
 pigment{ Maze( 8, 1.25, 13598 ) }
Samuel Benge
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Date: 10 Feb 2000 04:00:39
Message: <38a27e37@news.povray.org>
That is so neat.  And a-mazing you could ever come up with a similar pattern as
well as that too.
Only thing I can see unmaze-like about both Sams and Rons is they have many
closed paths.  Most mazes I've ever seen don't a completely sealed off sections
like these do.  But who cares, it's a great pattern.
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] rongwmicrocom...
|     gradient x
|   pigment_map
|     [.5 Pig3 ]
| #end
| plane {y 0
|   pigment {
