POV-Ray : Newsgroups : povray.binaries.images : blur Server Time
29 Apr 2026 10:37:00 EDT (-0400)
  blur (Message 1 to 10 of 10)
Subject: blur
Date: 3 Feb 2000 22:54:30
Message: <389A4DD0.371BDA32@powersurfr.com>
what is this specual blur i hear so much about latly
Subject: Re: blur
Date: 4 Feb 2000 01:26:17
Message: <389a7109@news.povray.org>
Similar to camera blurring, but done after the render completes instead of while
rendering.  Much faster.  Basically it's like smoothing or blurring in a
external image processing program except that it uses the 3D info from the scene
file.  The MegaPov html or help document tells how to use it.
"Noah A" <vip### [at] powersurfrcom> wrote in message
news:389A4DD0.371BDA32@powersurfr.com...
Subject: Re: blur
Date: 4 Feb 2000 07:19:43
Message: <389ac3df@news.povray.org>
Good question.
Good answer.
Just MHO,
Peter Warren
war### [at] hotmailcom
Subject: Re: blur
Date: 4 Feb 2000 19:45:26
Message: <389A2354.A2F629C2@earthlink.net>
MegaPov creates two images or just rewrites the first ??
> Bob
Subject: Re: blur
Date: 4 Feb 2000 21:12:39
Message: <389b8717@news.povray.org>
Either way that is two images, yes  :-)
If you use +FN for a Png file type you will get 2 images but the post process
won't write the change to the file.
You can pause the render during post processing (if you can catch it in time)
and copy the output file (Tga, not Png) elsewhere then let POV continue and
you'll have a pair that way.
"Ryan Mooney" <rdm### [at] earthlinknet> wrote in message
news:389A2354.A2F629C2@earthlink.net...
Subject: Re: blur
Date: 4 Feb 2000 23:46:26
Message: <389BD642.A1943B3A@mindspring.com>
That brings up a new question:  is this considered illegal post-processing under
IRTC rules?  It is all done within the renderer, and no external programs are
used, but would it be considered legal?
Subject: Re: blur
Date: 5 Feb 2000 00:51:17
Message: <389bba55@news.povray.org>
Richard wrote in message <389BD642.A1943B3A@mindspring.com>...
under
are
From the IRTC Stills FAQ:
[1.1.10] My renderer can do lens flare, motion blur, etc.--is that legal?
     Yes, generally. If it is something that the renderer does as part of
producing the image, and not something you run against the image file as a
separate process, then it is legal. The judges look very closely at such
effects, however, so use them with caution.
[1.1.11] Exactly what do you mean by "post-processing"?
     That means running any image-manipulation program on the image after it
is rendered. Paint programs, photo manipulation programs, and the like are
generally not allowed, except for a few explicit exceptions. We want the
image to be the output of a renderer, not a human or special-effects
program. One guideline that has been mentioned is that any process which
affects every pixel in the image is usually okay, but that's not a hard and
fast rule--it's just used to encompass gamma correction, resizing,
conversion to JPEG format, and so forth, all of which are legal. Another
guideline is, don't do anything to the image that you wouldn't be prepared
to do for every frame of a 30-minute animation.
Since the post-processing is done after the rendering, but it is done by the
renderer, it would appear that this issue is up to the IRTC Admins.
Mark
Subject: Re: blur
Date: 5 Feb 2000 01:40:37
Message: <389bc5e5@news.povray.org>
Ah, but it's a post =rendering= process actually, and not really a post process
per se.  Since it is using the scene file info to do it then I can't see why it
wouldn't be legal for IRTC submission.  It's very much the same as any other
in-render effect only done separately, kind of like moving the reflection
raytracing outside of the usual loop and applying it afterward (if that was a
possibility).
That's how I see it anyway.  Well, 'soft_glow'  could very well be illegal since
it doesn't use scene info I suppose.  If anything I believe Nathan Kopp will
have to be the ultimate judge on this by giving an account as to what is done in
a raytrace/rendering sort of way or not.  Same about the proposed lens flare
post process and whatever else of future versions that might be done in this
fashion.
Mainly it's probably going to be more a voting issue than anything else, with
points lost on using such a feature.  I don't think that should be so if a
permission is passed on it for example.
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:389bba55@news.povray.org...
| under
| are
| Mark
Subject: Re: blur
Date: 5 Feb 2000 02:48:04
Message: <389BD5EA.9675E71D@ij.net>
> guideline is,
    Gamma correction is a bad term I picked up. It is better termed gamma
normalization. It will generally improve a scene's viewability that is too hard
to get exactly right in POV. But it will also turn a moonlit scene into a
daylight scene.
    Photoshop now has scripting. Time to rephrase the rule.
The question is not, "Who will let me do it?"
The question is, "Who will stop me?"
Offering an apology is easier than getting permission.
Subject: Re: blur
Date: 5 Feb 2000 02:57:45
Message: <389BD82E.E9CD2DEA@ij.net>
> possibility).
    But where does on draw the line?
Here? <img src="http://giwersworld.org/artii/nraol.jpg"> All Photoshop and plugins.
> fashion.
    I do question lens flare by someone else's macro vice from PS or the like. What
is really the difference? I am certain a descent image can be made entirely of OPMs,
other people's macros. How to score that? 1 technical I would guess  but the rest?
