POV-Ray : Newsgroups : povray.binaries.images : A Quandary Server Time
19 May 2026 06:47:12 EDT (-0400)
  A Quandary (Message 20 to 29 of 29)
Subject: Re: A Quandary
Date: 7 Feb 2000 15:14:02
Message: <389DD83E.E61B875C@earthlink.net>
Are the spheres reflecting the point light(s) to the ground...?
Is the checkered plane transparent...?
Mark Wagner wrote:
> Matt Giwer wrote in message <389BD097.7720A07E@ij.net>...
> >Mark Wagner wrote:
> >> Note the colors of the spheres.
> >> Note the colors on the ground.
> >> How was this done?
> >    Colored lights layed out with the color of the
> >light a mirror image of the colors of the spheres.
> No.  The spheres are all white.
> Mark
Date: 7 Feb 2000 17:01:33
Message: <slrn89ug27.v8.ron.parker@ron.gwmicro.com>
>>> How was this done?
I assume you used light groups.  The "red" sphere is set to interact with
the red light (and the yellow and magenta lights) and set to block light
from all but the red light.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 7 Feb 2000 19:48:24
Message: <kE+fOMYLhc1fn=OzmkHQM0SMigXL@4ax.com>
On Sun, 6 Feb 2000 00:37:03 -0500, "Mark Wagner"
<mar### [at] gtenet> wrote:
>Peter Popov wrote in message ...
>>The spheres have no_shadow and there are 7 spotlights (one is
>>negative) of equal radius and falloff?
>No, only point lights were used.
>Mark
intersection
  union
    sphere { 2*x, 1 pigment { Red } }
    sphere { 2*x, 1 rotate 60*y pigment { Yellow } }
  plane { y, 0 }
  pigment { White }
This should report the CSG as a single infinite object (untested).
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 8 Feb 2000 01:12:47
Message: <389fb3df@news.povray.org>
Ron Parker wrote in message ...
Close, but no cigar.
Mark
Date: 8 Feb 2000 01:12:48
Message: <389fb3e0@news.povray.org>
Simen Kvaal wrote in message <389eefc9@news.povray.org>...
>You used six lights whose colors add up to 1 and placed them above the
>spheres, so that the spheres appear to be transparent when you look at the
>shawows. Right?
Wrong.
Mark
Date: 8 Feb 2000 01:14:37
Message: <389fb44d@news.povray.org>
>intersection
>  union
>  plane { y, 0 }
>  pigment { White }
Yes, it is reported as a single object.  No, it is not reported as infinite.
No, this is not how I did it.
Mark
Date: 8 Feb 2000 04:41:28
Message: <FeSfOAJidJ0V6RMRF70ZfOlBlOIQ@4ax.com>
On Tue, 8 Feb 2000 01:16:26 -0500, "Mark Wagner"
I am sure someone with more math brains than myself can come up with
an isosurface function to colorise the floor plane in this way.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 9 Feb 2000 17:41:16
Message: <38A1ED0D.67A5CA8@spiritone.com>
sphere { <1,0,0> 0.5 pigment { rgb 1 } light_group "one" }
light_source { <1,3000,0> rgb <1,0,0> groups "one"
                      projected_through { sphere { <1,0,0> 0.51 } light
group "one" }
This at least creates the same effect, but the colors get washed out.
Perhaps you fix this with radiosity?
> How was this done?
> Mark
Josh English
eng### [at] spiritonecom
Date: 10 Feb 2000 01:09:06
Message: <38a25602@news.povray.org>
Josh English wrote in message <38A### [at] spiritonecom>...
>group "one" }
Get rid of the projected_through and you've got it.
The source:
sphere{<2,0,0>, 1 light_group "A" pigment{rgb 1} rotate y*60}
sphere{<2,0,0>, 1 light_group "B" pigment{rgb 1} rotate y*120}
sphere{<2,0,0>, 1 light_group "C" pigment{rgb 1} rotate y*180}
sphere{<2,0,0>, 1 light_group "D" pigment{rgb 1} rotate y*240}
sphere{<2,0,0>, 1 light_group "E" pigment{rgb 1} rotate y*300}
sphere{<2,0,0>, 1 light_group "F" pigment{rgb 1} rotate y*0}
sphere{<0,0,0>, 1 light_group "G" pigment{rgb 1} }
plane{y, -6 pigment{checker rgb 1, rgb .9 }}
light_source{ <100,300,0>*100, red 1   groups "C,D,E,G"  rotate y*240}
light_source{ <100,300,0>*100, green 1 groups "E,F,A,G"  rotate y*0}
light_source{ <100,300,0>*100, blue 1  groups "A,B,C,G"  rotate y*120}
camera{ location <0,5,10> look_at y*-2}
/* The colors come from color addition and color subtraction.*/
/* Mark */
Date: 10 Feb 2000 12:07:08
Message: <38A2F047.77972134@spiritone.com>
OOOOH.. I was so close. Projected_through was the only way I could get the
shadow to be colored properly, with out it the colors of the shadows seemed
to be rotated 180*y under their spheres....
I personally want to thank you for posting a challenge that forced me to
look into the newer features of MegaPov that I probably wouldn't have looked
at before. It was a learning experience.
> >group "one" }
> The source:
> /* Mark */
Josh English
