POV-Ray : Newsgroups : povray.binaries.images : Shield Technology [19KB] Server Time
20 Sep 2025 15:19:50 EDT (-0400)
  Shield Technology [19KB] (Message 1 to 10 of 10)
Subject: Shield Technology [19KB]
Date: 2 Feb 2000 19:29:05
Message: <3898cbd1@news.povray.org>
Hi all,
I've been working on an idea to give my various spaceships "shields" via a
shield macro. You should find three attachments:
1) Shield_off.jpg - the test object without shield.
2) Shield_on.jpg - the test object with shield. (In this example the shield
is filled with emission/absorption media with values to enhance the
visibility of the edges.)
3) shield.zip - zipped copy of shield.pov
example uses the solid mesh capabilities of MegaPov to fill the generated
mesh with media.
Justin
Download 'shield_off.jpg' (5 KB) Download 'shield_on.jpg' (6 KB) Download 'shield.zip' (3 KB)
Preview of image 'shield_off.jpg'
Preview of image 'shield_on.jpg'
Subject: Re: Shield Technology [19KB]
Date: 2 Feb 2000 20:53:03
Message: <3898df7f@news.povray.org>
Super_Kewl
Thanks a lot,
Peter Warren
war### [at] hotmailcom
Date: 3 Feb 2000 03:50:26
Message: <38994152@news.povray.org>
Innovative, as Bill Gates might say.  Seems the ship is getting obscured a lot,
shouldn't it be more visible?  Other than that this is great.
"Justin Whitton" <jus### [at] bigfootcom> wrote in message
news:3898cbd1@news.povray.org...
| Hi all,
| mesh with media.
| Justin
Date: 3 Feb 2000 07:13:08
Message: <chrishuff_99-47BBDD.07135703022000@news.povray.org>
In article <3898cbd1@news.povray.org>, "Justin Whitton"
<jus### [at] bigfootcom> wrote:
> Hi all,
> via a shield macro. You should find three attachments:
> shield is filled with emission/absorption media with values to
> enhance the visibility of the edges.)
> The macro relies on the trace() function in MegaPov, the
> Shield_on.jpg example uses the solid mesh capabilities of MegaPov to
> fill the generated mesh with media.
This is one of the things I designed my proximity pattern for...it is
included in the latest release of MegaPOV, you might want to have a look
at it. It is probably slower than this method, though...
Chris Huff
e-mail: chr### [at] yahoocom
Date: 3 Feb 2000 09:21:53
Message: <38998f01@news.povray.org>
Bob Hughes wrote in message <38994152@news.povray.org>...
lot,
The macro creates a mesh surrounding the object. The visibility is then
defined by what texture and interior you apply to the mesh. In the examples
posted I filled the interior with a media that enhanced the viewing edges of
the mesh to show the shape.
When I render with more "shieldish" textures the shape is not readily seen.
(Most shields/forcefields don't appear to have an interior.)
Justin
Date: 3 Feb 2000 09:21:54
Message: <38998f02@news.povray.org>
Chris Huff wrote in message ...
Chris,
I didn't see the proximity pattern when I did my glance through of features
in MegaPov 0.4. I could have saved myself all that coding by using the
proximity pattern as a pigment function in an ISO surface to get exactly
what I was after. (I was trying to get a real surface around the object,
although the proximity pattern will do when I only need an apparent surface
created from media.) Time to do a speed check and to see if I understand the
proximity docs properly.
Oh well, another short lived POV coding high for me.
Justin
Date: 3 Feb 2000 10:47:52
Message: <3899a328@news.povray.org>
It's too slow for any practical use... at least on my computer. It chugs
away at very slooow speeds, like the old media. Can't you do something to
speed it up? I haven't been able to finish any of the demo files included.
Date: 3 Feb 2000 18:43:27
Message: <chrishuff_99-02D3FA.18441903022000@news.povray.org>
In article <38998f02@news.povray.org>, "Justin Whitton"
> features in MegaPov 0.4. I could have saved myself all that coding by
> using the proximity pattern as a pigment function in an ISO surface
> to get exactly what I was after. (I was trying to get a real surface
> around the object, although the proximity pattern will do when I only
> need an apparent surface created from media.) Time to do a speed
> check and to see if I understand the proximity docs properly.
I still haven't done a test of using the proximity pattern in an
isosurface, I am a bit afraid of how slow it might be.
One thing, media doesn't require as many proximity samples as an
ordinary texture, since things get smoothed out along the media samples.
An isosurface would probably need it as smooth(many samples) as possible
for the solver to make any sense of things.
And your trace() + mesh technique certainly has possibilities...don't
give up on it yet. :-)
Chris Huff
Date: 3 Feb 2000 18:55:10
Message: <chrishuff_99-F99178.18560203022000@news.povray.org>
In article <3899a328@news.povray.org>, "TonyB"
What processor are you on? I have a 266 MHz PowerPC G3, and although it
was slow, it wasn't too slow to be practical.
The demo scenes had a very high samples value, a lower value can lead to
graininess but is much faster. Also, there are 3 different methods of
shooting the rays: one is very slow for points far from the target
object, but is the most accurate. Another one is faster, but doesn't
give an even distribution of samples. The third one switches between the
other two depending on where the point being evaluated is. It is faster
outside the object bounding box and more accurate inside, but can
sometimes leave artifacts around the boundary between the two types.
And I can't really do anything about the speed...it figures out how far
it is from the parts of the object by shooting a bunch of rays at it.
For simple things like spheres, this isn't a good method(spherical works
fine), and many other objects could be approximated with function
patterns, but it is needed for complex CSG's and other objects.
Someone else who knows more advanced math might be able to find a better
way...
Something I just thought of-you could use the trace function to place
blob components for my blob pattern on the surface of the object. If you
get the placement right, you could get a pretty good approximation of
the proximity pattern. And although the blob pattern is still
un-optimized, it would be faster.
Chris Huff
Date: 7 Feb 2000 11:38:04
Message: <slrn89tnt6.1no.sjlen@zero-pps.localdomain>
It'd be interesting to see an animated morph.
  3:00pm  up 23:38,  3 users,  load average: 1.01, 1.06, 1.03
